Soft brake pedal low fluid NO LEAKS????????
Discussion in 'General Tundra Discussion' started by 2015Crewmax, Feb 3, 2020.
  1. Feb 3, 2020 at 2:03 PM
    2015Crewmax
    2015Crewmax [OP] New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    Can someone help out on this?
  2. Feb 3, 2020 at 2:09 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Have you inspected your brake pads?? As they wear the fluid must travel further and therefore the level in the master cylinder goes down. Sometimes, if you have a "smart" master brake cylinder, the idiot light will go on on the dash.
    I think your pads are worn.
    TTund16 and nlaroy like this.
  3. Feb 3, 2020 at 2:12 PM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    New brakes.
  4. Feb 3, 2020 at 2:12 PM
    NWPirate
    Zach
    WA
    Have you checked your brake pad material? Possibly all 4 pads are about shot leading to lower fluid in the reservoir. Not sure if that would lead to a softer pedal or not though..
  5. Feb 3, 2020 at 2:14 PM
    NWPirate
    Zach
    WA
    Beat me to it :thumbsup:
  6. Feb 3, 2020 at 2:18 PM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    I just installed brand new rotors and pads
  7. Feb 3, 2020 at 2:23 PM
    NWPirate
    Zach
    WA
    Weird, you should see more brake fluid after new pads. Did you notice a fluid level difference before& after?
  8. Feb 3, 2020 at 2:27 PM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    OP, did you bleed the system?
    Trooper2 likes this.
  9. Feb 3, 2020 at 2:31 PM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    i didnt notice..
    i didnt introduce any air to the system, unless with these truck im wrong the last thing i knew what unless you changed calipers and intruduced air it's a sealed system and doesnt nee bleeding. am i wrong?
  10. Feb 3, 2020 at 2:34 PM
    NWPirate
    Zach
    WA
    Not wrong, not to offend you but you fired the truck up and pumped the brakes right?
  11. Feb 3, 2020 at 3:13 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Always need to bleed if modify / change something in the system.
    JLS in WA likes this.
  12. Feb 3, 2020 at 3:17 PM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    hahahahaha yes i did
  13. Feb 3, 2020 at 3:18 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Brake fluid isn't good for life; it absorbs water (to a point) and heat cycles break it down. It's worth bleeding some fluid every brake change.
  14. Feb 3, 2020 at 3:27 PM
    NWPirate
    Zach
    WA
    I figured, sorry! :anonymous:
  15. Feb 3, 2020 at 3:34 PM
    2015Crewmax
    Cory
    Centennial, CO
    15 Crewmax
    it's never had a strong brake pedal. i actually have never been impressed by it.
  16. Feb 3, 2020 at 5:14 PM
    Mcoop
    Michael
    Berlin, NJ
    It would not hurt to bleed all four corners.
    Jengel451 likes this.
  17. Feb 3, 2020 at 6:33 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    A 2015, you are due for a complete brake fluid drain/replace.
  18. Feb 4, 2020 at 12:47 PM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I had seizing or failing calipers causing this problem on my 09, got them replaced and went back to like new brake feel.
  19. Feb 4, 2020 at 1:20 PM
    timsp8
    NY
    Try to get a brake fluid flush. Might need it after almost 5 years and its relatively cheap/easy.
  20. Feb 4, 2020 at 3:15 PM
    G10dra
    G10dra Not a New Member
    I had this issue with my sedan over the winter, I didn't drive my car for 2 weeks in the northeast winter. I had very spongy brakes as I drove after 2 weeks. Took it to a local shop and all it took was to bleed the entire systems and all back to normal.
  21. Feb 4, 2020 at 4:02 PM
    TTund16
    TTund16 New Member
    was it hard to push back the pistons? some recommend opening the bleeder valve/screw a little and then bleed … that will also gets some of "dirty" fluid out. some systems can be more sensitive as far as pushing the fluid back.
    I've done it both ways. i didn't mess with the bleeder valve last time i changed pads with one car but i did it with an older car to get some fresh fluid in.
  22. Feb 4, 2020 at 4:17 PM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    It's not like you have drum brakes in the back......low pads wont do this on 4WDB. Check for air in the system, using a bottle connected to a hose off the bleeder. In the bottle you have some brake fluid, make sure rubber hose is below fluid level. Now with bleeder opened, pump the pedal and watch the bottle, and see how much air comes out as bubbles. This is practically FREE, before condemning anything else in the system. Then try a flush. If that doesn't work, you probably have a bad mater cylinder. It could have an internal leakage, that could also irrigate the fluid and cause air in the lines.
  23. Feb 15, 2020 at 10:29 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    to piggy back on this thread, is there a particular brake fluid they recommend for our truck like oem from dealership or can anything off the shelf from autozone work?
  24. Feb 15, 2020 at 2:01 PM
    timsp8
    NY
    Normally people say use the Toyota brand, but any dot3 will work.
    2015Crewmax[OP] likes this.
  25. Feb 15, 2020 at 8:53 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    Loosen the nuts on the master cylinder and pull it off the booster a little and make sure you're not losing fluid into the booster.
  26. Nov 29, 2020 at 2:37 PM
    Jsomar
    Jsomar New Member
    Change your brake bleed nipples and add some Teflon. Pressure bleed if you can.
  27. Nov 29, 2020 at 3:41 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Since you say you have new brakes, top off the fluid and see if it goes down. If so, then you have a leak.
    DIYDad likes this.
