Soft brake pedal cure
Discussion in '2nd Gen Tundras (2007-2013)' started by Clutch492, Sep 3, 2024.
  1. Sep 3, 2024 at 5:08 PM
    Clutch492
    Clutch492 [OP] New Member
    Kevin
    2011 tundra
    None
    After a struggle, changed out master cylinder and ABS system. Then. Found that the brake pads in the left front caliper, were stuck. Removed them and freed them up. Rust had held them in place. Pistons could not push them. So, in essence, the brake pad was acting as a spring board and flexing when applying the brakes. Ensure the pads can float freely in the caliper. Cured the soft pedal.
