SoCal LA County aligment
Discussion in 'California' started by FlipMonkey21, Sep 10, 2019.
  1. Sep 10, 2019 at 7:48 PM
    FlipMonkey21
    FlipMonkey21 [OP] New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    So I got 35 tire, kings 2.5 setup with camburg uniball uca also bmc all done by 88rotors. I went to get it a alignment in Northridge TirePros it is recommend after 200miles. TirePros didn't do a good job at all just cost me more rubbing on the body mount. Called 88rotors spoke to them and they suggested to call camburg directly so I called camburg spoke to them gave them my story. Camburg refered me to a alignment shop in Huntington Beach Dave's frame & Alignment. Drove down to Huntington this morning at 6am got there at 7am waited till 8am for the shop to open. Main guy Dale look under the car and everything is all messed up he said everything is rubbing suspension was not level steering wheel was pointing to the right. Everything was just off he said. So Dale started working on the truck got everything leveled and aligned did a very good job truck drives good straight now. Okay so this getting long now heehee I do have a question. Where do you guys go for your alignment? That can work on Tundra with the same setup as mine. Thank you.20190910_172514.jpg 20190910_172514.jpg 20190910_172514.jpg 20190910_172514.jpg
    Pinay likes this.
  2. Sep 10, 2019 at 8:17 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Highly recommended by @BestGen
    Took my Tundra there after last run to Big Bear, alignment was whack after 4 trail runs, steering wheel pointed to the right.
    I was straight after suspension work in Vegas and had numbers in hand. Took to Bear and asked if he wanted to see my sheet, he’s like no, I work on suspended trucks all the time.
    I saw him drive my truck off the lot 3 times before I got it back. Straight and true, good to go.
    BestGen, aperezsh, TheBeast and 2 others like this.
  3. Sep 10, 2019 at 8:28 PM
    zeekevin
    zeekevin New Member
    RPM Garage in Monrovia, California. Look them up on instagram rpmoffroadgarage
    FlipMonkey21[OP] likes this.
  4. Sep 10, 2019 at 8:35 PM
    FlipMonkey21
    Mark
    SoCal Glendale
    Same with this guy took it for a drive like 3 times and when he handed me key his like don't go home yet drive around and give me a call or come back and tell me how it drives he also told me "I stand behind my work" . I want to find an alignment shop like that just closer. But if I have to I'll drive there again to get it right the first time. Oh so I called the TirePros in Northridge and got a refund.
    HappyGilmore and Pinay[QUOTED] like this.
  5. Sep 10, 2019 at 8:55 PM
    zeekevin
    zeekevin New Member
    Rpm garage does a ocd alignment, Numbers will match both sides. Once you lift a truck you will need more caster vs what the factory spec calls for.
    They have worked on all my previous rigs before my current tundra and I never had to come back to get a realignment
  6. Sep 10, 2019 at 9:02 PM
    El_fisher1
    El_fisher1 New Member
    18 sr5 cement tundra CrewMax.
    2.5 kings
    Heard good things about bear frame & wheel..will be going to his shop soon.
    Pinay likes this.
  7. Sep 10, 2019 at 9:26 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dale has done all my vehicles. He knows his stuff
    TheBeast and FlipMonkey21[OP] like this.
  8. Sep 10, 2019 at 9:39 PM
    TheBeast The Beach
    good to know about Dave's frame & Alignment. They are local to me. I will go to them for my next alignment.
    do they take walk ins or appointments only ?
  9. Sep 10, 2019 at 9:40 PM
    TheBeast The Beach
    hard to find good alignment guys nowadays..
  10. Sep 10, 2019 at 10:10 PM
    trainracer
    trainracer New Member
    Mike's Frame and Alignment Canoga Park
  11. Sep 10, 2019 at 10:58 PM
    15whtrd
    15whtrd Mr. Blonde
  12. Sep 10, 2019 at 11:01 PM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    RPM OFFROAD GARAGE. Best place for anything Toyota.
  13. Sep 11, 2019 at 10:44 AM
    TheBeast The Beach
    lots of shops in SoCal, that's the good thing :)
  14. Sep 11, 2019 at 2:53 PM
    FlipMonkey21
    Mark
    SoCal Glendale
    yeah but not every shop knows how to do custom alignment specially when you mod your suspension.
  15. Sep 11, 2019 at 3:32 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Contact Ron's Tire and Wheel of Lankershim in Studio City since you're close by.
    (818) 980-2200
