So I'm an idiot
Discussion in 'General Tundra Discussion' started by tuckertravis, May 16, 2018.
  1. May 16, 2018 at 9:10 PM
    tuckertravis
    tuckertravis [OP] New Member
    Tucker
    Abilene, TX
    2018 TRD Sport Crewmax
    None... Yet
    was checking inside the fender for making more room for tires and had it all apart and while putting it back together I snapped off one of the nuts for one of the two bigger bolts that hold the bumper in place. I was giving it some pretty good force while tightening so now I can't get it apart and it's just free spinning but still not right enough to hold the bumper secure. Any ideas?
  2. May 16, 2018 at 9:21 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    You snapped the bolt head off? Is that what I read?
  3. May 16, 2018 at 9:35 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    No the nut that bolt screws into. The bolt is fine.
  4. May 16, 2018 at 9:46 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    So the nut that you circled is free spinning?
  5. May 16, 2018 at 9:50 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    Correct
  6. May 16, 2018 at 9:54 PM
    nk1794
    San Jose, CA
    Are you NOT able to use a socket with long extension to hold it in place while tightening the bolt?
  7. May 16, 2018 at 9:56 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    I was trying but I couldn't find a socket to fit the square nut. I gave up for the night. Got frustrated and didn't want to mess anything up further. I'll give it another go tomorrow.
  8. May 16, 2018 at 9:58 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
  9. May 16, 2018 at 9:59 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Is the square nut still attached? It sound stripped..
  10. May 16, 2018 at 10:00 PM
    nk1794
    San Jose, CA
    The way I understood is that the spot welds broke so the nut is spinning.
  11. May 16, 2018 at 10:02 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    No it came loose. Looked like it was held in place on each corner by what looked like small welds but I put enough force to break them loose when I undoubtedly cross threaded it. And of course a very hard to get spot.
    831Tun likes this.
  12. May 16, 2018 at 10:04 PM
    nk1794
    San Jose, CA
    A pair of vise grip might work.
    TXDrifter, 15whtrd and Baja Mike like this.
  13. May 16, 2018 at 10:05 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Well, sounds like it's the perfect time for an aftermarket bumper upgrade.:anonymous:
  14. May 16, 2018 at 10:12 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    Ha yes eventually
    831Tun[QUOTED] likes this.
  15. May 16, 2018 at 10:17 PM
    Baja Mike
    South Bay, Ca.
    Several solutions. Get a lock washer underneath the nut. Loctite the threads of the bolt. Get a Nylock nut.
    Use a little less torque next time.
  16. May 16, 2018 at 10:23 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Also, possibly some JB weld.
    Mountun Goat and nk1794 like this.
  17. May 16, 2018 at 10:26 PM
    nk1794
    San Jose, CA
    Get a torque wrench? :D
    Baja Mike[QUOTED] likes this.
  18. May 16, 2018 at 10:30 PM
    Baja Mike
    South Bay, Ca.
    Eh, tight is tight.
  19. May 17, 2018 at 5:51 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
  20. May 17, 2018 at 5:58 AM
    Once u get that square nut off, possibly take to hardware store (ACE) n match it, maybe weld it back? don't have a welder? Or any friends or family have a welder to tack weld it?
  21. May 17, 2018 at 6:39 AM
    Hey @tuckertravis check out the thread San Antonio Meets in case you didn't know there is a meet coming up in Abilene on the 19th
  22. May 17, 2018 at 7:30 AM
    nk1794
    San Jose, CA
    If welding is not an option perhaps rivet nut might do the trick. Something like this for example.
    15whtrd and tuckertravis[OP] like this.
  23. May 17, 2018 at 7:52 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You dont have a crescent wrench?
    monaco730 and 15whtrd like this.
  24. May 17, 2018 at 8:57 AM
    15whtrd
    15whtrd Mr. Blonde
    I was picturing vice grips. I haven’t looked but I guess it must be in it difficult location. I am a plumber by trade so I’m used to obscure and difficult areas to work in. I bet you I would get that off quick.
