So i thought 'why not try 93 octane'....
Discussion in 'Performance and Tuning' started by Berettafan, Feb 24, 2018.
  1. Feb 24, 2018 at 1:22 PM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    I kid you guys not the truck is noticeably smoother.
    The typical response to this is 'nope, modern cars are optimized for 87 octane' or something to that effect.
    well that's all fine and dandy but the truck I'm driving likes the stuff. in reading up on tunes I noted that the dap fellow says very clearly these trucks retard timing at lower octane levels. stock. if this is true then you most definitely do get more juice from the higher octane.
  2. Feb 24, 2018 at 1:52 PM
    tmart
    tmart New Member
    Travis
    I ran 93 in my previous cars that were built for performance, never tried it in the tundra. Might give it a try, should give slightly better mpg too?
  3. Feb 24, 2018 at 6:11 PM
    Ericsopa
    Ericsopa Old man and the sea
    I've been blending 89/93 for a couple months now. Getting around 1 MPG better overall. Averaging 17.7 vs 16.8 on 87 octane. It was the DAP tuning thread that prompted me, too.
    Metro14536 likes this.
  4. Feb 24, 2018 at 6:22 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Some vehicles respond better to 93, I haven't tried it in the tundra yet as I burn too much fuel and cost would kill me. But my 2012 tacoma all I run is 93, if I put 87 in it the truck will ping And run worse.
  5. Feb 24, 2018 at 6:39 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Just check your spark plugs when you change them. If they have little white specks on the electrode (piston side) then the higher octane is preventing complete combustion and damaging the engine.
    No white specks, you're good to go.
  6. Feb 24, 2018 at 6:41 PM
    I've been using Maverick 87 pure gas for 2 months now. Usually $2.50 per gallon. Better response and I went from 10.2 in town to 11.3 mpg and totally driving the same. Don't need 93 ethanol mix. just need pure dino. Going to eat some corn flakes now.
    TheBeast, T500, GAknight and 7 others like this.
  7. Feb 24, 2018 at 6:55 PM
    careyrob
    Carey
    Massachusetts
    I used to have a gas station 1 block from my house that had 1 pump with no ethanol, but I had to move for work and now the good stuff is nowhere to be found.
    Unless your running really high compression ratios, turbocharged or supercharged using 0% ethanol makes more difference in engine performance and longevity than using premium fuel.
    I still don't know why the mid-grade fuel is even sold. It has no functional purpose from an engineering stand point. I guess it's for people who should use premium, but are too cheap. Or maybe for people who feel bad about not doing proper maintenance so they through a few bucks at "better" fuel every once in a while to sooth their mind.:notsure:
    TheBeast likes this.
  8. Feb 24, 2018 at 8:08 PM
    geno0506
    geno0506 New Member
    Michael
    I never used 87!
  9. Feb 24, 2018 at 8:17 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Big fan of maverik’s pure gas. We have 88 out here in Vernal, ut. Definitely get better mileage with it than any other type of fuel. Same price as premium out here. Glad I left corn country for dino country.
  10. Feb 24, 2018 at 8:58 PM
    careyrob
    Carey
    Massachusetts
    You're at around 4k feet elevation, right? You won't find 87 octane at higher elevations. Since there's less oxygen in the air up there it make engines more likely to knock (early detonation, not rods knocking) so you need higher octane to prevent that from happening. 88 at your altitude behaves the same as 87 at sea level.
  11. Feb 24, 2018 at 9:01 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I mean we have 88 ethanol free gas, pure gas, clear gas. We have lots of 87 (E10 or E15) out here. Lots of 85 (E10 or E15), too.
    Black Wolf likes this.
  12. Feb 24, 2018 at 11:46 PM
    I'm in Denver at 5280ft. Leadville is at over 10,000ft and you can buy 87 octane gas there too. Not sure where you are getting your info. When I purchase 87 it's not because I'm cheap, it's because our trucks are tuned/programed to be most efficient running 87. Burning higher octane is simply a waste of money. You can get a tuner to "re-calibrate" your engine where running 93 would be best for example I suppose. There is no "better" gas, only what's "best" to use. 93 is not better than 85 if your car is tuned to burn 85. The last thing you want to do is to spend money for something you don't need just to "feel better".
    T500, Grumpy Uncle, GAknight and 2 others like this.
  13. Feb 25, 2018 at 12:19 AM
    15whtrd
    15whtrd Mr. Blonde
    You have that backwards. At higher elevations, engines are less likely to detonate, requiring less octane.
  14. Feb 25, 2018 at 6:28 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I saw no difference between 87 and 91 timing advance
    nixon, Black Wolf and UTTundra like this.
  15. Feb 26, 2018 at 11:04 AM
    Berettafan
    2017 CM
    paying more attention to the truck I'm not prepared to say for sure it's stronger. definitely smoother.
  16. Feb 26, 2018 at 12:52 PM
    boloson
    boloson New Member
    Your wallet gets lighter hence the better fuel mileage
  17. Feb 26, 2018 at 4:04 PM
    careyrob
    Carey
    Massachusetts
    You are correct Sir.
    My apologies. I'll blame it on a long day on the road.
  18. Feb 26, 2018 at 4:11 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Im at 5
    Im at 5,280 and I dont see you?
    T-Rex266 and Black Wolf[QUOTED] like this.
  19. Feb 26, 2018 at 4:39 PM
    15whtrd
    15whtrd Mr. Blonde
    All good! You actually had me questioning what I had been thinking all these years LOL but then I was like no no that’s not it ha ha
  20. Feb 26, 2018 at 6:11 PM
    I'm about 20 ft higher...........
  21. Feb 26, 2018 at 6:11 PM
    I like your dog. Post more dog pics!!
  22. Feb 26, 2018 at 6:28 PM
    EDIT....No Corn Flakes... no corn left....(yeah, I'm stretching it a bit)
  23. Feb 26, 2018 at 6:31 PM
    Tracker
    Tracker New Member
    Shane
    Ah, there you are
  24. Feb 26, 2018 at 6:36 PM
    We fellow Marines have great eyesight............[​IMG]
    Tracker[QUOTED] likes this.
  25. Feb 26, 2018 at 6:38 PM
    Tracker
    Tracker New Member
    Shane
    We can shoot a flea of a ticks ass at 500 yards with iron sights :infantry:
  26. Feb 26, 2018 at 6:40 PM
    Not brag...just fact................
    yep.jpg:infantry::bananadead:
  27. Feb 26, 2018 at 7:08 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I believe some vehicles require a little higher octane just not 93. I tested 93 in Taco no MPG improvement and nothing on butt dyno. Did run a tank pulling bay boat back from LA. Ran same speeds and all interstate 1 measured mpg increase. May try it towing with Tundra but hard to gauge mpg improvements when a headwind can drop it by 2. I would have to duplicate wind conditions. Last trip light tailwind got 10 but trip home in 25 mph headwind got 8. A 1 mpg improvement in Tacoma did not cover extra cost.
    Bigstick and MotoTundra like this.
  28. Feb 26, 2018 at 10:04 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
  29. Feb 27, 2018 at 5:31 PM
    Ericsopa
    I can do that at a click and a half with a 2.75" folding-fin rocket! With nothin' but a grease-penciled "x" on the windshield.:rofl:
  30. Feb 28, 2018 at 8:44 PM
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
    If there is less air, it is less likely to ping/detonate. The A/F is richer and runs cooler and less likely to ping.
