So Hybrid...
Discussion in '3rd Gen Tundras (2022+)' started by Cavalrysr5, Jun 27, 2021.
Thread Status:
Not open for further replies.
  1. Jun 27, 2021 at 1:11 PM
    Cavalrysr5
    Cavalrysr5 [OP] New Member
    Jared
    2020 tundra cavalry blue sr5
    Metro14536 likes this.
  2. Jun 27, 2021 at 1:12 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    Wow you are so off base. The powerboost hauled 10k lbs up to vail at 11k feet only 20 seconds slower and 1mpg worse than a 6.6 duramax 2500. Do some math and you’ll realize the f150 is an absolute beast.
    Try doing that in your cost saving no transmission cooler tundra and you’d be on the side of the road.
    Coal Dragger and Ahab like this.
  3. Jun 27, 2021 at 1:36 PM
    Cavalrysr5
    Jared
    Wow you missed the entire point, I talked about overheating. They did it with the tundra and it made it up... without overheating LOL damn you live under a rock. Fords are over-engineered while using sub par materials.
    *edit* I have also towed from Tuscon to the central valley through flagstaff with my tundra and about 6500 pounds and guess what? It didn't over heat when it was 105* outside. Weird.
  4. Jun 27, 2021 at 1:54 PM
    TundraLaw
    Northern Nevada
    Not with 10k lbs, and not at that speed over the distance required for Vail Pass. Apples and Oranges, and all that video shows is that the powerboost f150 is nearly as strong as a 2500 diesel.
  5. Jun 27, 2021 at 2:07 PM
    Cavalrysr5
    Jared
    No it doesn't LOL
    Again TFL showed the tundra doing just what that f150 could do.... and didn't over heat and "Reduce power"
    ALL modern trucks can pull at towing speed up that hill in today's world. You act like it is a feat to do that. It definitely isn't.
    Apparently you're too dense to realize they have a speed limit they abide by. It is not an "all out" drag race to the top.
  6. Jun 27, 2021 at 2:11 PM
    Wallygator
  7. Jun 27, 2021 at 2:32 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I know your not the only member that said this but how do we know this was a GUARANTEED cost saving measure??
    And I am willing to bet if you drive the Tundra at 65 (as per the manual) you won’t be stuck on the side of any road with a blow transmission in the Tundra…
  8. Jun 27, 2021 at 2:36 PM
    TundraLaw
    Northern Nevada
    You do realize in that video the Ford never shut down or had to pull over. The alert went away. They were throttle down with 10k lbs in the back for 10miles up to 11k feet elevation.
    The Tundra cannot do that.
    I also know the trans cooler removal was for cost savings as Toyota came out and said “we did the research and it’s not needed for the majority of owners, so we removed it.” All that tells me, as an attorney, is that they wanted to save money because their cost savings outweighed the potentially small group of buyers that could have issues down the line.
  9. Jun 27, 2021 at 2:43 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Oh oh easy I am not knocking the Ford F-150 in any way…which you seem very defensive over.
    Where did Toyota say that and is it possible that it’s really not needed? And truthfully that statement does not mean that it was ONLY a cost cutting measure lawyer or no lawyer. And yes there are going to be Tundra owners with transmission problems. The ones that tow 9k at 80mph in the mountains as common sense would dictate.
    Cpl_Punishment and Wallygator like this.
  10. Jun 27, 2021 at 2:59 PM
    Cavalrysr5
    Jared
    OH so an attorney understands the fundamentals of engineering? LOL cool now go build us a truck then. LOL They can be WOT and the truck still won't allow WOT... Today's trucks have computers that does all the thinking for people.. You know... because anyone who would buy a ford doesn't have a brain.
    Saltyhero13 likes this.
  11. Jun 27, 2021 at 3:01 PM
    Cavalrysr5
    Jared
    It's funny that people that buy fords won't complain and just pay the ridiculous costs to fix their junk. Then turn around and buy another junk pile because they didn't learn from their first mistake. My old boss loves his fords.. with all it's misses, rust issues with exhaust manifold bolts, broken spark plug threads, timing chain issues.
    Junk. Pure, complete junk.
    TBoe1776[QUOTED] and Saltyhero13 like this.
  12. Jun 27, 2021 at 3:07 PM
    Wallygator
    @TundraLaw keeps his vehicles for about two years then trades, 71.37% of all Fords can go that long without an issue. So those things don't matter to him. The tech and modern touches do.
  13. Jun 27, 2021 at 3:14 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Well that explains his defensiveness of the F150…
  14. Jun 27, 2021 at 3:30 PM
    Yes, it was a cost saving measure. I posted a bit about it from a Toyota Engineer.
    Tundra2, Black Wolf, szabo101 and 2 others like this.
  15. Jun 27, 2021 at 4:25 PM
    TundraLaw
    Northern Nevada
    Um… no TFL did not. They have never posted a tundra haul up vail pass (much longer than Ike gauntlet) with 10k lbs.
    Further, the f150 did not shut down. It’s smart enough to know to alert the driver of high temps. Your overpriced truck with no trans cooler would just burn up.
    Westerntowboss likes this.
  16. Jun 27, 2021 at 4:25 PM
    TundraLaw
    Northern Nevada
    True that! I can afford it, and makes sense for me. I think I’m good for 3 on this truck.
  17. Jun 27, 2021 at 4:28 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    That Ford alerted the driver and pulled power because it was getting hot. That motor was working hard, this just shows what a lot are taking about rather have a bigger displacement V8 then a small twin turbo 6. Of course the new tundra grille is massive so maybe they won't have issue.
  18. Jun 27, 2021 at 4:40 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    I wonder whose decision that was…. And I wonder if any testing was done.
    Your right @TundraLaw the Tundra sucks…
    NOPE
    **EDIT** And as a side note why in gods name does so many people come to these forums just to complain about the Tundra. It seems worse here than any other Toyota truck forum I have been on. Stop whining about it and go trade it in!
    Cpl_Punishment likes this.
  19. Jun 27, 2021 at 5:13 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
  20. Jun 27, 2021 at 5:16 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    :101010: Haha!
  21. Jun 27, 2021 at 5:33 PM
    TFL has never done the Ike Gauntlet with 10K. They did do 9K and so did the ol' ColoradoTJ.
    This was in Grand Junction about to head East on I-70 towards Vail (Ike Gauntlet). We stopped on the downside of the pass since I was running on fumes with having the 26 gallon tank.
    I was pretty impressed with the powerboost. Can't wait until TFL gets their little mits on a 2022 Tundra and tests the crap out of it on the Ike.
    On a side note....let's keep it clean men.
    =JSG=, snivilous, akmerle and 4 others like this.
  22. Jun 27, 2021 at 5:41 PM
    TundraLaw
    Northern Nevada
    ok Joey from Long Island. I’ve been on this forum since 2017 with two tundra’s, and most recently up until last month.
    It’s ok to call out your favorite brand instead of drink the koolaid.
    AZBoatHauler likes this.
  23. Jun 27, 2021 at 5:51 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Looks like Ford has perfected limp mode. Impressive.
  24. Jun 27, 2021 at 5:55 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Haha! Good one I am not from Long Island but hey thanks for playing. I don’t like Kool Aid either. I am a realist and I knew exactly what I was getting when I bought my truck. I bought my truck for reliability. It’s the least gas efficient, and tech lacking of any other manufacturer…**NEWS FLASH** that’s exactly what I wanted. I don’t expect ANY 1/2 to safety tow 7k or more despite what the brochures say. Clearly you NEED to stop buying Tundras…
    BlueRidgeTon likes this.
  25. Jun 27, 2021 at 5:56 PM
    Melikeymy beer
    Muscogee Nation
    OK, I've never done the Gauntlet but I have done Grand Mesa. On my bicycle.
  26. Jun 27, 2021 at 6:04 PM
    You automatically win then.
  27. Jun 27, 2021 at 6:09 PM
    Melikeymy beer
    Muscogee Nation
    I'll be interested to hear what the range will be on the F150 and Tundra hybrids pulling a 6k lb trailer. I mean, torque is great but stopping to power up every 150 miles would suck. Will it be a plug in hybrid? Is the Ford?
    Edit: looks like the F150 hybrid still has a 36 gal fuel tank so even at 9-10 mpg it should still have pretty good range. And it appears that it is a plug in.
  28. Jun 27, 2021 at 6:37 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    The thing that stuck out to me was the 1700 lb payload. I thought F150 PB were more at 2000 lbs, and that was a stripped out base model, give it a higher end model and it would be less than 1500 lbs. New Tundra should easily go beyond this
    Cpl_Punishment and Oey12 like this.
  29. Jun 27, 2021 at 7:02 PM
    Great:thumbsup:
    Wallygator[QUOTED] likes this.
  30. Jun 27, 2021 at 7:07 PM
    Agreed....
Thread Status:
