Snugtop Questions
Discussion in 'Tonneau Covers, Caps and Shells' started by NikNoid, Oct 3, 2019.
  1. Oct 3, 2019 at 5:23 PM
    NikNoid
    NikNoid [OP] New Member
    Snugtop Owners, I have a question for you.
    I have a Snugtop Rebel on my 2018 Tundra DC. The "wrap-around" rail feature hangs over my deck rail channels so that I can use the side rails anymore. I'm trying to show it in this pic, notice how the top edge of the rail is overlapped by the cap. Is this normal?
    aIZ-Efw61B7_RjVWGZ9u70KJKXRS1iTb9XHvNW4T_fd0c40833af7c122e155c27dd071c5f216912c9c.jpg
  2. Oct 3, 2019 at 8:12 PM
    1971sport
    1971sport New Member
    Normal i have the same top . You cant use the factory cleats but i have alot of things mounted to mine using t slot nuts and mounts some vendors make.there is enough gap in between the hangover and the bed rail to slip things in between to mount solidly to the channel
  3. Oct 3, 2019 at 8:44 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep, it’s normal but I easily fixed it by cutting about 1/2” off with my skill saw. Set depth shallow and cut it right in place. Wear a dust mask, that fiberglass dust is bad stuff
    tundra_20 likes this.
  4. Oct 3, 2019 at 11:52 PM
    NikNoid
    Thanks for the response, much appreciated.
  5. Oct 5, 2019 at 2:56 AM
    mtndude23
    mtndude23 New Member
    07 tundra
    On mine, I unscrewed the black knobs enough to clear the snugtop. You can then still use the hooks to attach to. You probably can't crank down on it as much, but still enough to hold most things in place.
    gosolo likes this.
