Snow chains
Discussion in 'Recovery & Gear' started by smslavin, Oct 11, 2017.
  1. Oct 11, 2017 at 6:12 AM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    It's that time of year and I need a new set. Who's got recommendations on chains? Thoughts on chains vs cables?
    Rica25 likes this.
  2. Oct 11, 2017 at 6:29 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I always run snow tires in the winter so I have no experience with chains or cables. Sub'd to this thread so I can learn something new.
    DeesCrewMax likes this.
  3. Oct 11, 2017 at 6:47 AM
    Emergency strap chains, on rear only, I've only needed chains twice in my life.
  4. Oct 11, 2017 at 6:47 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Here’s an older thread that has some information
    https://www.tundras.com/posts/152562/
    Do a quick search and you’ll find several more. Let us know what you end up getting, and how it went for you after the spring thaw!
    Rica25, smslavin[OP] and T-Rex266 like this.
  5. Oct 11, 2017 at 6:51 AM
    smslavin
    Hudson Valley
    Some stuff
    Maybe I should have qualified off road use?
  6. Oct 11, 2017 at 7:07 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
  7. Oct 11, 2017 at 7:07 AM
    What kind of off road use are you doing? When I had my Tacoma, we took it snow bashing a few times...no issues
  8. Oct 11, 2017 at 7:14 AM
    smslavin
    Hudson Valley
    Some stuff
    Third recommendation I've gotten for them this morning. :thumbsup:
    Some light exploring for winter portraits. But, I'm also planning a 4-5 day deeper excursion for the first weekend in Dec.
    4x4_Angel and T-Rex266[QUOTED] like this.
  9. Oct 11, 2017 at 7:16 AM
    Having a white truck, we become the snow and the snow becomes us. Together we become one and are unstoppable.
    Half Assed, KMG, Viper3G and 10 others like this.
  10. Oct 11, 2017 at 7:20 AM
    smslavin
    Hudson Valley
    Some stuff
    o_O :rolleyes: :frusty:
  11. Oct 11, 2017 at 7:50 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    MDHinSD, Gort, wodje96 and 10 others like this.
  12. Oct 11, 2017 at 7:57 AM
    Same answer from me.
    One time was in a 5 ton line truck in 3'+ snow in the mountains, the other was cutting wood, trailer loaded and it rained hard.
  13. Oct 11, 2017 at 8:12 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    On-road you most likely will never need chains, even in the mountains. If you plan to do some offroading in the snow it is only wise to do so with another truck. Even with chains you could end up stuck and alone.
    Snow bashing is good times
    Winches are very helpful when stuck in snow
  14. Oct 11, 2017 at 8:16 AM
    TXMiamiFan
    Jose
    Tires don't look aired down; do you need to air down when snow bashing?
    ColoradoTJ likes this.
  15. Oct 11, 2017 at 8:17 AM
    Yes
    Rica25 likes this.
  16. Oct 11, 2017 at 8:24 AM
    Yep. Same for sand or any wheeling reallly
  17. Oct 11, 2017 at 8:26 AM
    TXMiamiFan
    Jose
    I've never aired down for wheeling on dirt/rocks (under level 4 trail). Tires have handled good and no punctures.
    Eclipsed & Floating likes this.
  18. Oct 11, 2017 at 8:30 AM
    blizz86
    blizz86 New Member
    Bought these for when CALtrans says chains req'd..
    Security Chain Company QG3229
    fairly easy to put on when they are fitted correctly... i ended up pulling over less than a mile past the checkpoint cus they werent necessary, and i had a loose link slapping something lol
    TheBeast likes this.
  19. Oct 11, 2017 at 8:38 AM
    csuviper
    Broomfield, CO
    I air down but don't go too low as my air compressor isn't that great. Air down more will help for sure.
  20. Oct 11, 2017 at 8:40 AM
    csuviper
    Broomfield, CO
  21. Oct 11, 2017 at 8:43 AM
    Maxtrax work great too...
    smslavin[OP] likes this.
  22. Oct 11, 2017 at 8:43 AM
    csuviper
    Broomfield, CO
    Where do you store those?
  23. Oct 11, 2017 at 8:46 AM
    My garage when not in season, or in my truck during snowy conditions.
  24. Oct 11, 2017 at 8:51 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Try airing down Jose, especially when you're on the dirt for a few hours. Not only for traction but the ride gets much softer and enjoyable.
  25. Oct 11, 2017 at 8:55 AM
    Exactly like strap chains
  26. Oct 11, 2017 at 9:22 AM
    csuviper
    Broomfield, CO
    True
  27. Oct 11, 2017 at 9:22 AM
    csuviper
    Broomfield, CO
  28. Oct 11, 2017 at 9:25 AM
    Could be worse. Completely stock. Truck was doing great, until I turned around to check on the wife who I had to get un-stuck. Never stop on wet heavy snow- at least on stock tires, low clearance, etc. :anonymous:
  29. Oct 11, 2017 at 9:26 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Why do I picture Sean grabbing the bumper and lifting the truck out?
    JC303, smslavin[OP] and blizz86 like this.
  30. Oct 11, 2017 at 9:26 AM
    blizz86
    blizz86 New Member
    .. you forgot to use your lats. you could have just lifted it out of there :)
