Smooth Bed Rail Caps Replacements?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bergy24, Feb 23, 2024.
  1. Feb 23, 2024 at 4:23 AM
    Bergy24
    Bergy24 [OP] New Member
    2021 Cement Crewmax Limited TRD 4X4
    I bought a Diamondback HD cover that is due to be complete in March.
    I have read that due to the design of the bed rail caps, they can allow water into the bed.
    Sealing under the cap will help with water getting in, but the top has a design that also allows water to get in.
    My question is, do they make a bed rail cap that is smooth for the 2.5 Gen Crewmax?
  2. Feb 23, 2024 at 5:38 AM
    Cody1060
    Cody1060 New Member
    Ken
    Mid Michigan
    2021 Tundra 1794
    I can't answer your question regarding if a smooth bed rail cap is available.
    I can tell you that if you follow the instructions from Diamondback, your cover will not leak. Mine certainly hasn't leaked.
    It's been a great cover.
  3. Feb 23, 2024 at 5:51 AM
    Bergy24
    I live about 2.5 hours away and plan to have them install it to help ensure it does not leak.
  4. Feb 23, 2024 at 3:36 PM
    clarkritchie
    clarkritchie New Member
    Unfortunately, I believe there are no aftermarket bed rail caps at all.
    Bergy24[OP] likes this.
  5. Feb 23, 2024 at 4:51 PM
    SportDek
    SportDek Boat hauler, Bus Driver
    Dale
    TEXAS from MN
    2021 1794 Tundra Crewmax Windchill Pearl
    TRD Swaybar, RCI Skid plates, DiamondBack HD cover, bed rug, Cooper AT3 4S
    I have a 2021 Crewmax 1794 with a Diamondback HD cover, and it has not leaked a drop. Even went through a touch car wash, still no leaks! I did have to adjust(tighten) the fastners to the bedrail again after a trip from Texas to Minnesota and back again however!
  6. Feb 23, 2024 at 6:37 PM
    Bergy24
    Did you do anything special under the caps or anywhere else?
  7. Feb 23, 2024 at 7:17 PM
    SportDek
    Dale
    TEXAS from MN
    No, I just followed the directions that came from diamondback for installation, and all is good!
