Smoke on Startup
Discussion in '1st Gen Tundras (2000-2006)' started by PNW15, Mar 6, 2025.
  1. Mar 6, 2025 at 4:16 PM
    PNW15
    PNW15 [OP] New Member
    WA
    2006 DC V8 4WD
    Alright ya'll. I've been troubleshooting this one and tracking when the smoke is most likely, so I could write a good description while asking for your help... I was hoping I could figure it out reading other threads and double checking a bunch of stuff, but no.
    Edit: The conditions which provoke smoke have been updated below
    My truck has been exhausting white smoke on some warm-starts for about 2 months now. The previous 2 before that? Nada. Here are the conditions where that happens. Didn't happen for 1000 miles, has been happening for about 1000. Truck has 141k
    Video of smoke and condition of sparks
    Only happens under following conditions:
    - Truck is warm, all the way warm. Also driven at highway speeds, typically with downshifts, incline, load. Putting around down doesn't make it happen later.
    - Truck sits for ~1.5-2.5 hours
    - Happens very consistently when I drive for 20-30 minutes up a few thousand feet. These load conditions usually lead to a downshift to maintain 70. This is up to the local ski hill. It smokes without fail when I start up to leave if it is within 1.5-2.5 hours.
    - Curiously, the truck will NOT smoke if I park it at home and start it up in that same time frame. - Yes it is typically near or below freezing at the ski area, and warmer below. BUT, it has smoked in my driveway before, just not nearly as consistently.
    - Truck typically receives 89, at a Top Tier station. Maybe I should try a different station LOL.
    Things I've examined:
    - Pictures of sparks in the link. All 8 looked the same. 40k miles on them.
    - PCV valve, clean and new and identical to new unit I purchased.
    - Power steering vacuum lines are dry, and testing the valve per the FSM (feeling vacuum at full lock) seemed to function as normal
    - Checked all other vacuum lines before or at the TB, all dry.
    - No check engine lights, no codes, no stuttering, or otherwise poor running symptoms
    - Doesn't smell like coolant. Maybe a touch of blue (barely), just a stinky white. Doesn't happen if cold started next day? Can't tell cause it doesn't sit at ski pass overnight...
    - I did seafoam it a few months ago. Top end (a la intake right at the throttle body) and a tank treatment. Suspiciously didn't happen before that. But I don't know. Oil has been changed for 1000 miles since then, with no additional fuel additives. This is the strongest correlated event and the one I am most suspicious of, just not sure how to rationalize it back to data or test it...
    - No change with recent removal/addition of stock to airaid intake. (not that I expected any)
    Options?
    - Leakage from a stuck injector? Would this explain it not happening on cold start as the fuel is sneaking past the rings by the time a cold start happens? But I have no codes and the truck "fine?"
    - Leftover seafoam either in the intake runners used at higher RPM or in the exhaust, or stuck in engine gunk that either burns off or condensates based on warm truck, cold weather scenario?
    - Valve guide seals? It's just odd that I bought the truck, with 5w30 in it, changed it early to Pennzoil platinum, and now it's leaking via here? It went from no smoke to all smoke. And it's white... and these aren't known for that?
    - Am I missing something related to crank case pressure and high RPM?
    - Should I run my OBDII beep boop box on startups to check the commanded afr and realtime O2 sensor data? What what I want to be scrutinizing?
    - Is this a red flag for ya'll as far as continued driving? What I don't want to be doing is washing down the cylinders and then wearing them out or something.
    - Temp sensor throwing the mix wrong?
    Anyways... Thanks ahead of time for your help!
  2. Mar 7, 2025 at 7:33 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Search for power steering pump valve. The vacuum line can suck power steering fluid into the intake
  3. Mar 7, 2025 at 9:12 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Were the plugs OEM ?
    If all 8 plugs look like these 3 you posted in your link @ 40K miles driven at highway speeds, typically with downshifts, incline, load, my 1st thought is fuel control problem. If it was only 1 maybe 2 cylinders. I would say fuel injector.
    When you say Top Tier, do you mean someone like Shell, they're considered Top Tier.
    Someone in video mentioned smelling like plastic....anything to that ?
    If your OBDII box does fuel trim, that would be great to see given I'm feeling rich condition.
    shifty` likes this.
  4. Mar 7, 2025 at 9:17 AM
    PNW15
    WA
    2006 DC V8 4WD
    Thanks, yes all 8 are denso SK20R11 plugs, they all look very similar, nothing stands out as fouled or black. I don't know the PO driving habits but the truck was only driven 70K ish since it's last T-belt change in 2016.
    Yes, it's Shell Gas
    Plastic smell... It's more like.. chemically or fumey to me, rather than plastic. Think rich or noxious.
    Ya I'll dig out the OBDII reader...
    BubbaW[QUOTED] likes this.
  5. Mar 7, 2025 at 9:18 AM
    PNW15
    WA
    2006 DC V8 4WD
    Ya I mentioned that in my write up. Anything beyond what I said? Lines are dry.
  6. Mar 7, 2025 at 9:26 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Lucky you....you're approaching the 90K miles recommended and are at the 9 years(108 mo)
  7. Mar 7, 2025 at 9:28 AM
    Fuel is normally black smoke
    BroHon likes this.
  8. Mar 7, 2025 at 9:29 AM
    PNW15
    WA
    2006 DC V8 4WD
    Yup. Bunch of parts ordered yesterday.
  9. Mar 7, 2025 at 9:33 AM
    PNW15
    WA
    2006 DC V8 4WD
    Ya that's been my experience with gas too. But it has a distinct smell that is of something petroleum based being burnt. Zero coolant smell to my nose.
    Thoughts on residual top end cleaner 1000 miles later? That stuff produced huge white clouds after following the instructions on the bottle...
  10. Mar 7, 2025 at 9:37 AM
    Unless it went into the intake as a liquid, it should all be combusted during the treatment. Power steering valve is the number one culprit. No engine codes I'm assuming
  11. Mar 7, 2025 at 10:16 AM
    PNW15
    WA
    2006 DC V8 4WD
    It went in as a spray in front of the TB. But it seems like too long ago and it should all be gone.
    I read up on that valve, looked for fluid at both lines, and tested vacuum per the FSM by turning to full lock... Is there something else I am missing in regards to troubleshooting or confirming if it is PS fluid?
    Thanks for your help.
  12. Mar 7, 2025 at 10:21 AM
    shifty` Bohannon Bohannon Bohannon Bohannon
    On the valve, the idle changed when the engine is running, steering wheel at full lock, and you squeeze/release either of the two vacuum hoses attached to the valve? Or does the idle stay the same?
  13. Mar 7, 2025 at 10:23 AM
    PNW15
    WA
    2006 DC V8 4WD
    Idle changed
    shifty`[QUOTED] likes this.
  14. Mar 7, 2025 at 6:17 PM
    PNW15
    WA
    2006 DC V8 4WD
    Also what the heck, why is the power steering control valve 17630-16040 so dang expensive!?
  15. Mar 7, 2025 at 7:38 PM
    I got a Dorman unit on clearance from RockAuto for $47 or something.
    But if your idle changed while pinching, valve is OK.
  16. Mar 7, 2025 at 8:07 PM
    PNW15
    WA
    2006 DC V8 4WD
    The idle did change. Pretty subtle but I guess that's why you turn off the A/C. Must refrain from unloading the parts cannon...
  17. Mar 8, 2025 at 12:30 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    The rock sells a Rein unit for $35. Rei gets good reviews on the Bimmer and VW forums. I believe they are a division of Continental.
    PNW15[OP] likes this.
  18. Mar 8, 2025 at 1:59 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    You could add some atp at205 to see if the stem seals need it.
    Try plugging off the ps valve vacuum ports, to eliminate it.
    Also I wouldn't call it a warm start at 1.5-2.5 hours. I'd reserve that for 15-45min.
    Since it happens after an elevation change, is yhe ambient temps low enough for condensation to occur in the exhaust? Do other vehicles in the area also have any white smoke?
  19. Mar 8, 2025 at 5:38 PM
    PNW15
    WA
    2006 DC V8 4WD
    Ok, did it again today. This time, same drive but the truck sat for 5 hours, it puffed an acrid cloud of unburnt something on startup. Probably 35-40 degrees fahrenheit out.
    No other vehicles do it. Including the GX470 that was parked next to me for the same exact amount of time.
    Never had it do it after being parked so long, but it's usually parked for long periods down in town. Maybe the warm start thing doesn't matter and it's about how hard it's driven?
  20. Mar 14, 2025 at 4:14 PM
    PNW15
    WA
    2006 DC V8 4WD
    Okay so, I got a daylight video.
    Same drive, same ish temperature, 3.5 hours parked.
    This time I drove 70 or under and the truck only downshifted to 4th one time, otherwise I drove relaxed.
    Still smoked. More blueish? You can see in the second half of the video the normal condensation and rich exhaust that most cars exhibit. But there is this instant plume of smoke, almost like it's sitting in the exhaust...
    Haven't found my obd reader yet and truck hasn't been getting driven much...
  21. Mar 14, 2025 at 6:03 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Looks bluish.
    Did you ever cap the vacuum ports to eliminate the p/s idle valve as a possibility?
    Otherwise I'd be leaning towards stem seals.
  22. Mar 14, 2025 at 6:07 PM
    PNW15
    WA
    2006 DC V8 4WD
    I did not cap them as both lines are dry.
    Dunno how the truck could go from 1000 miles of no smoke to 1000 miles of somewhat semi but not always consistent smoke depending on where driven, and have that be valve guides. Hmmm
  23. Mar 14, 2025 at 6:29 PM
    Have you checked the brake booster vacuum line?
  24. Mar 14, 2025 at 9:41 PM
    PNW15
    WA
    2006 DC V8 4WD
    I can't remember if I've pulled that one or not. Any advice?
  25. Mar 15, 2025 at 6:44 AM
    Check the brake booster for brake fluid. Remove the vacuum line from the booster and dip a skinny zip tie down inside (like doing a fluid level check) to see if you get any fluid on it. Should be completely dry. If there’s any fluid on it, then the MC is leaking into the BB and the motor may be sucking in some BF.
    shifty` and des2mtn like this.
  26. Mar 15, 2025 at 7:18 AM
    And BF will create white smoke
    shifty` likes this.
  27. Mar 28, 2025 at 8:26 AM
    PNW15
    WA
    2006 DC V8 4WD
    I plan to put some time into this this weekend, check those brake booster hoses. Then will probably tackle the timing belt job.
    I added one more good daylight video to folder. The difference this time is that it was 60F where I parked and 70F when I left home. So I don't think cold is a factor, I think it has to do with how hard I run the engine.
    Last thought. The smoke is like... Right away. I wish I could remove fuel as a variable in this scenario and see if it will pump smoke just on crank.
  28. May 14, 2025 at 12:33 PM
    PNW15
    WA
    2006 DC V8 4WD
    OK.
    So after road tripping this thing, the white smoke has subsided but blue smoke remains.
    Update on conditions where it smokes on start up:
    Any time you pull a big grade and downshift into a lower gear to do so, and then turn the truck off, and restart it 10min to 24+ hrs later. So temps don't matter... Just pull a big grade and shut it down. If you keep driving for a period of time after loading up the engine, it won't smoke, I think it gets all blown out.
    I just rechecked then lines to the PSCV, brake booster, etc all dry. I also just replaced the PCV despite it looking and seemingly functioning like new.
    I think I'm just gonna take it to my mech to ensure it's not something head gasket, rings, or compression related.
    Lastly, oil consumption seems to be up. Went 5k on the last oil change, added a quart cause I couldn't tell on the stick, it was suspicious and near the oil change interval so I changed it and barely pulled over 5 qts. That's with 7 plus 1 I added later...
    Makes me nervous that oil consumption seems to be up in conjunction with more hard driving on steep roads with a load. The very conditions that cause it to smoke on startup are probably consuming oil while running.
    Thoughts?
  29. May 18, 2025 at 6:46 PM
    PNW15
    WA
    2006 DC V8 4WD
    Took it to the mech, they insisted it was the PCV despite me having replaced it already. I was firm with them that it was not but they convinced me it's where they needed to start. What a waste of diagnostic time, and time in general.
    Added video from today.
