Smoke on Start Up
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Ders, Dec 25, 2021.
  1. Dec 25, 2021 at 4:28 PM
    Ders
    Ders [OP] Washington
    Washington
    2014 Tundra
    MKW Chrome Off-Road Wheels 275/65R20 Tires Bilstein 5100 Middle Setting In the Front, 1/2 Block in the Rear Highway Products Gull Wing with Roof Rack Tracks Protech lumber rack LED headlight and foglight bulbs 30% Front window tints Boost Auto Tow Mirrors
    Ok I realize this is a pretty well discussed topic. But i’m a bit paranoid about it. My 2014 5.7 has 160k miles on it. And on start up it steams or smokes more than i’d like. First thing in the morning I assume it’s steam from condensation. But i’m here in Arizona for the holiday and it seems to do it every time I let the truck sit for over a few hours. I’s been 50-60’s and even low 70’s each day. What I don’t get is my father in laws 2018 Silverado does less smoke/steam than mine and less often and i’ve been following his truck alot down here.
    My concern is because it does it not only in the morning but like 5pm after it was driven at noon.
    This is a video of the hottest day about 68deg 30-40% humidity and it was not the first start if the day but it was sitting a few hours
    I should add I towed 1500miles from WA to AZ no overheat, no issues, no loss of coolant. Maybe a little oil loss (1/8 qt) but it not have been as level of settle as long when I checked it, so I doubt it really lost any. i did have a running hot condition over the summer towing 7k lbs up a gravel hill in 4hi. The needle went a bit over half. But not into the red.
  2. Dec 25, 2021 at 4:34 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    not going to be much help, but i dont see any video
  3. Dec 25, 2021 at 4:35 PM
    Ders
    Washington
    2014 Tundra
    Here’s the video
    https://youtu.be/xLnMq1_qXS8
    i’m just concerned because it seems to happen every time
    i will try another video here tomorrow from a better angle as well
  4. Dec 25, 2021 at 4:36 PM
    Ders
    Washington
    2014 Tundra
    Yeah my bad. I forgot it
    Danimal86[QUOTED] likes this.
  5. Dec 25, 2021 at 4:38 PM
    Danimal86
    Daniel
    Sacramento, CA
    i was expecting worse. to my untrained eye looks normal to me.
    Does the exhaust have any different kind of smell or color?
  6. Dec 25, 2021 at 4:40 PM
    Kung
    KG, VA
    Same; looks totally normal to me. :notsure:
    Tundra14Platinum likes this.
  7. Dec 25, 2021 at 4:44 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    I don't think that is smoke. Does it smell like smoke burnt oil or something?
    My 14 does that all the time and I live in FL.
  8. Dec 25, 2021 at 5:01 PM
    boss sauce
    boss sauce New Member
    2014 dc tundra
    Mine looks the same
  9. Dec 25, 2021 at 5:23 PM
    Ders
    Washington
    2014 Tundra
    It does smell what I would call “strong” it’s not pleasant to put your nose in. But It does not smell like syrup or oil.
    i think it smells stronger when it’s colder out. Also goes away when the engine warms up
  10. Dec 25, 2021 at 5:31 PM
    Ders
    Washington
    2014 Tundra
    Most days?
  11. Dec 25, 2021 at 5:40 PM
    boss sauce
    2014 dc tundra
    If it’s a little chilly out, also smells like gas a little
  12. Dec 25, 2021 at 5:40 PM
    boss sauce
    2014 dc tundra
    Mine is a 2014 with 45,000 miles
  13. Dec 25, 2021 at 5:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The bumper cap falling off bothers me more than the smoke.
  14. Dec 25, 2021 at 5:55 PM
    Ders
    Washington
    2014 Tundra
    Ha! Yeah I know, don’t worry thats fixed!
    joonbug[QUOTED] likes this.
  15. Dec 25, 2021 at 5:57 PM
    Ders
    Washington
    2014 Tundra
    I’ll try and get a better video tomorrow. It’s usually a bit more dramatic
  16. Dec 25, 2021 at 7:26 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Mine looks the same, looks pretty normal to me.
  17. Dec 25, 2021 at 7:40 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Dollars to donuts, that's steam from a cold exhaust system.
  18. Dec 25, 2021 at 7:42 PM
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Looks fine
  19. Dec 25, 2021 at 7:43 PM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Condensation, like all are saying. If it were oil it would not dissipate into the atmosphere and stop as quickly. Watch other vehicles that you know have been sitting like overnight and starting in morning, same thing.
  20. Dec 25, 2021 at 7:49 PM
    15whtrd
    15whtrd Mr. Blonde
    It may be time for a pcv valve though
    Mater likes this.
  21. Dec 25, 2021 at 8:54 PM
    Ders
    Washington
    2014 Tundra
    Just replaced the PCV about 5k miles ago. Also have been doing Seafoam intake foam once a year, and seafoam in gas tank and crank case before each oil change
    15whtrd[QUOTED] likes this.
  22. Dec 25, 2021 at 11:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’s just condensation that sits in the muffler. Nothing to worry about.
  23. Dec 26, 2021 at 8:48 AM
    Ders
    Washington
    2014 Tundra
    It did do it again this morning. 62deg and 70% humidity
    i guess that seems too warm for me for it to do that. But then again i’m used to high 30’s this time of year.
    thanks for all the comments If I see a more dramatic start up i’ll update this.
  24. Dec 26, 2021 at 2:21 PM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    Absolutely means your Tundra is on its last leg. Trade it now!!
    Oh, I mean it is absolutely normal. You’re fine.
  25. Dec 28, 2021 at 6:35 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    My jeep GC, 04' Tacoma and my Tundra do the same thing where I live on cold startups. I say you're A ok.
  26. Jan 11, 2022 at 6:52 AM
    Southshore30
    Southshore30 New Member
    2018 Limited Crew Max
    That’s steam. Smoke would have come out instantly and not dissipated, it would drift up
    Cock-A-Doddle-Do likes this.
  27. Jan 11, 2022 at 6:55 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Normal- stop overthinking it!
