Small thunk noise after cold start when shifting 1>2
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stig, Sep 18, 2017.
  1. Sep 18, 2017 at 7:52 AM
    Stig
    Stig [OP] New Member
    Checking if anyone else has experienced this before getting it checked at the dealership
    I have a 2017 4x4 with less than 1500 miles. All stock as far as mechanical goes. At some point around 1000 miles, I started to notice an odd sound.
    When I cold start and leave my house, during the first shift from first to second there is a thunk sound. I can also feel it through the gas pedal. I am very light on the accelerator since I'm in a neighborhood. The shift always happens in a slight right turn.
    I've noticed it at least 5 times but not sure if it does it every time. Ivehicle only noticed it during this situation. Never when warm or any other shifts.
  2. Sep 18, 2017 at 8:27 AM
    Video record it n post it
  3. Sep 18, 2017 at 8:30 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    14burrito likes this.
  4. Sep 18, 2017 at 8:37 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    ^^^ this
  5. Sep 18, 2017 at 8:41 AM
    X3. Some 3rd gens do it, and some dont. Mine might and I just don't feel it :notsure:
  6. Sep 18, 2017 at 8:52 AM
    Borgs
    Borgs New Member
    PA
    Mine does this too! Driving me mad. Same spot every time I pull onto the main street in my neighborhood. It's a subtle little thunk.
  7. Sep 18, 2017 at 8:54 AM
    MistrRoboto
    Virginia Beach, VA
    It's ABS. I just did some testing around work and it was reproduced over and over, and normally right around a shift point. Admittedly, I don't normally feel it, because the sound of the door auto lock draws my attention. Start your car, lock the doors, and then drive off, and you will feel it every time at 15 miles per hour
  8. Sep 18, 2017 at 8:59 AM
    Borgs
    Borgs New Member
    PA
    Makes complete sense. I usually lock the doors - especially with the kids inside - before leaving the drive way. Interesting. Thanks so much.
  9. Sep 18, 2017 at 9:08 AM
    Stig
    Thanks all for the replies. Glad I don't have to let the clowns at the dealership look at it.
  10. Sep 18, 2017 at 10:45 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Weird that you posted this, but I'm glad you did, since mine does this too. I was just thinking when it happened this morning that I should probably ask about it. My doors lock when I shift out of park, so when this noise (and vibration) happen, it's noticeable. Glad it's nothing to worry about.
    exactly
  11. Sep 24, 2017 at 7:23 PM
    j2007
    j2007 New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    Thanks for this thread. My 2017 just hit 1000 miles and I’ve noticed it doing the same thing. Always after a cold start and always at low speed shortly after starting driving. I’m glad to know it might just be an ABS test. I was worried it was the 1st-2nd shift in the transmission.
  12. Oct 12, 2020 at 8:02 AM
    BECKTX
    BECKTX New Member
    Cement TSS
    My 2020 is making this sound at 7mph after every cold start. I am going to have it looked at but would the ABS check happen at 7mph? My concern isn’t high because this happens every time I start up and not throughout a drive. Seems normal but annoying. I have never experienced this sound in any other truck I have owned.
  13. Oct 12, 2020 at 9:12 AM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    My 2020 does the same around 7-8mph. Pretty sure it's the ABS
  14. Oct 14, 2020 at 7:17 AM
    d4ivg3i2j
    d4ivg3i2j New Member
    J
    Mine did this ever since the very first drive off the dealership lot. Cold start, first 20/30 feet, a subtle "bonk" that you can feel in the pedal. There have been numerous threads and almost all of them result in the determination that it's not a bad thing.
    I hardly notice it anymore. Just like the fine high pitched whine from the TRD intake that you get when applying the accelerator.
  15. Oct 14, 2020 at 8:34 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    It’s normal. My ‘18 does the same exact thing. Nothing to worry about.
  16. Oct 15, 2020 at 10:37 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    Mine does the same thing. Glad to hear it’s normal and nothing to worry about.
