Small dent repair on tailgate...
Discussion in '2nd Gen Tundras (2007-2013)' started by FunkinTundra, Apr 22, 2015.
  1. Apr 22, 2015 at 7:03 AM
    FunkinTundra
    FunkinTundra [OP] New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    I back into my garage and it is a pretty tight fit...well I left one of my little storage doors open and backed into it :annoyed::censored: Do you guys think this might be an easy fix? I was thinking I could pull off the bed liner and the little panel to get the handle assembly and see if it can be pushed out?? Its about the size of a 50 cent piece just to the right of the handle...no paint damage. Its not too big but it bugs me. Maybe a small dent repair shop?? Any info you can share would be great:) Thanks is advance!
  2. Apr 22, 2015 at 7:38 AM
    Pics?
    Probably can get a suction cup used for glass and pull it up if it's not that bad.
    FunkinTundra[OP] likes this.
  3. Apr 22, 2015 at 1:13 PM
    FunkinTundra
    Cody
    2012 Tundra 5.7 CM
    Here we go
  4. Apr 22, 2015 at 1:39 PM
    Glass suction cup may help a little. If not, you can try taking off the tail-gate liner and try pushing it out.
  5. Apr 22, 2015 at 3:38 PM
    Mike Tread lightly.
    south carolina
    I remember this fixed once with a hair dryer, towel, and some ice cubes once..
  6. Apr 22, 2015 at 4:37 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Paintless dent repair shop should be able to fix that for around $100. Be careful if you try to push it out yourself - don't use any sharp tools. Rub it with a soft blunt tool like a rubber door stopper, smooth piece of wood etc.. If it was mine I would rather spend the $100 and have it done right. (you can probably tell I have tried it myself before and learned through my mistakes)
    FunkinTundra[OP] and UPSed like this.
  7. Apr 23, 2015 at 5:41 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    X2. Via pure stupidity, I cocked-up the hood on my Jeep a few years back. Put two creases in it and one was about 4" long and 'L' shaped. Local paintless repair guy fixed me up in a mall parking lot while I sat inside the vehicle yakking on my cell. Took him a little over an hour and it was much worse than what you have.
  8. Apr 23, 2015 at 6:48 AM
    FunkinTundra
    Cody
    2012 Tundra 5.7 CM
    Thanks guys!! I will make some calls today and get this fixed....its the only thing I look at right now...I've starting backing in at work just so I don't have to look at it. haha
    T-Rex266 likes this.
  9. Apr 24, 2015 at 5:53 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    One of the shops is called Dent Magic. Same type of stuff, works wonders! They actually use some small tools to "relieve" the metal on the outside and another tool to "massage it" from the inside. Check your area and find one that will give references and has some before and after stuff to show you. We have a great guy here in the Placerville area.....shop wanted almost a grand to fix a few small dents in my 1st gen....Matt fixed them up at my shop for $120.
  10. Apr 25, 2015 at 6:53 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Let us know how it turns out. I have small dents here and there, but once I think about them, then I would have to fix them, haha.
  11. May 5, 2015 at 7:37 AM
    FunkinTundra
    Cody
    2012 Tundra 5.7 CM
    Well I ended up taking it to a place called "Dent Doctor"... they were able to get most of it out but they said the metal got stretched and would probably have to use more options to get it looking really good. So for 90$s I guess its ok... I will post a new pic up later. The day after I got it fixed someone decided to back into me and dented my chrome bumper up front just a bit. Guess its time to save for somethin new up front.
    Black Wolf likes this.
  12. May 5, 2015 at 7:45 AM
    Remember, everything comes in three's. Wait a little bit longer.
  13. May 6, 2015 at 2:57 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Lets see the after pics.
  14. May 12, 2015 at 8:54 AM
    FunkinTundra
    Cody
    2012 Tundra 5.7 CM
    Before and after... The lighting in the after pic really hides the little left over dent well.. All in all it came out pretty good and they were able to remove a couple little dents right below the big one.
    chphilo likes this.
  15. May 12, 2015 at 9:02 AM
    chphilo
    Western PA
    Looks great! If the dent is hidden by the lighting, it's not something to worry about.
  16. May 12, 2015 at 10:22 AM
    csuviper
    Broomfield, CO
    Looks great to me.
  17. May 12, 2015 at 1:01 PM
    Jack Burton
    Little China
    2013 DC 5.7L TRD/OR
    Looks good from where I'm sitting! I'd say they did a nice job for $90.
  18. May 12, 2015 at 1:31 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Looks like a great job. Looks like it should have cost more than a 90'er.
