Sluggish acceleration
Discussion in '2nd Gen Tundras (2007-2013)' started by MarcoD, Mar 5, 2022.
  1. Mar 5, 2022 at 8:23 PM
    MarcoD
    MarcoD [OP] New Member
    Dallas, TX
    2010 Silver Tundra SR5 5.7L 4x4 CM
    My 2010 Toyota Tundra SR5 5.7L with 139k miles and it feels sluggish at times when accelerating.What can I do to make it more responsive when I hammer it down? I’m literally having to press down harder on the gas than I normally do. Also my fuel economy is not up to par if you know what I mean. Whatever the issue I may be having affects both the performance and fuel economy.
    Things I’ve done so far… Fuel injection service, throttle body clean, spark plugs changed over 35k miles ago, I change air filters every 15k or every 3 oil changes. Performance only improved slightly after getting some of the above done.
  2. Mar 5, 2022 at 8:27 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Did you clean the MAF sensor while you were in there cleaning out the throttle body?
    hANNAbONE and frichco228 like this.
  3. Mar 5, 2022 at 8:28 PM
    MarcoD
    Dallas, TX
    I generally know that these trucks don’t have the best fuel economy but I know for sure I’m not getting what I should out of it. It may be running rich on fuel as there is a fuel smell that comes out of the tailpipe. When i fill up for gas, the distance to empty (DTE) that I get is 302 miles. When I use to get in the upper 300 through the mid 400 mile range with DTE, the acceleration was so much better.
  4. Mar 5, 2022 at 8:29 PM
    MarcoD
    Dallas, TX
    I don’t believe I had the MAF sensor cleaned. I’ll definitely check into that
  5. Mar 5, 2022 at 8:31 PM
    TILLY
    Massachusetts
    Use the proper cleaner for the sensor when cleaning it or you can damage it, good luck.
  6. Mar 5, 2022 at 8:32 PM
    BMET
    BMET New Member
    2018 Tundra Limited
    I noticed a drop in my mpg, not really the power though. I changed my air filter which really didn't look all that dirty, but what an improvement. I probably wouldn't be a believer if it had not happened to me.
    k0diak8o8 likes this.
  7. Mar 5, 2022 at 10:10 PM
    poop_bubbles
    poop_bubbles New Member
    There isn't much to change on these engines, assuming it is stock. Try the very obvious basics like air filter, spark plugs, check for any engine codes and repair what's necessary.
    Otherwise, "hammering" the gas and getting worse MPG generally go hand in hand.
    MarcoD[OP] and BMET like this.
  8. Mar 9, 2022 at 2:16 PM
    MarcoD
    Dallas, TX
    Well you guys, the weird thing about this situation is that on some “good” days the truck runs good performance wise. This may not make sense to you guys but it’s what I’m noticing. It has its sluggish days and days where it really wants to go. This other day when I hammered it down, I felt it lurched forward and took off like a jack rabbit other days it’s not that responsive. I’m working on getting the MAF sensor cleaned.
  9. Mar 14, 2022 at 6:51 AM
    BMET
    BMET New Member
    2018 Tundra Limited
    Op - any improvement? Has this been an ongoing issue or did it just come up? If the latter, I am wondering if you got some bad fuel.
  10. Mar 14, 2022 at 7:10 AM
    hANNAbONE
    hANNAbONE T U N D R A M A
    Des Moines / Dull Moan, Iowa
    still lookin' for my first one
    Go to a different fuel station.
    (*I usually go to the station that the police use...with all the gas they burn up there is always fresh petrol for the rest of us....
    TTund16 likes this.
  11. Mar 14, 2022 at 7:29 AM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    I had this issue with my old LX470. It seemed to be a throttle issue, where it needed to warm up a bit, then it would suddenly break loose. It felt bogged down until it would have a sudden surge of power. Never did figure it out after cleaning throttle body, replacing MAF, spark plugs, etc. Sold it as is to a guy with more free time than me to figure it out. Please post when you find the solution, I'm curious what the cause is.
  12. Mar 16, 2022 at 1:31 PM
    Rw429
    Rw429 New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    I would suggest trying premium fuel, although right now is expensive to say the least and get an induction/ fuel system service done. Some argue it is not necessary but if all else fails it can only help resolve this issue.
    TTund16 likes this.
  13. Mar 16, 2022 at 2:12 PM
    TTund16
    TTund16 New Member
    Gas or gas station problems typically resolve after one tank. I've had that happen and my Tacoma was sluggish and switched gas station and it was back to normal. Kind of hard to get a bad gas consistently but something to consider.
    Find a nice and not very old Chevron or Shell and try one tank just in case.
  14. May 19, 2023 at 1:59 PM
    Brian44cc
    Brian44cc New Member
    I sure would like to know if anyone found a resolution to this issue. I have the same problem in a 2011 Tundra. I've replaced the fuels pump, MAF sensor, cleaned the throttle body. The only easy fix I've noticed is removing the ground from the battery for 5 minutes, and reconnecting it.
    The problem is completely random.
  15. May 19, 2023 at 6:36 PM
    BMET
    BMET New Member
    2018 Tundra Limited
    Reading your post reminded me of my old 280Z. Some days it was a race horse and other days it was mediocre. Long story short, could it be the fan clutch? Just throwing that out there.
  16. May 19, 2023 at 10:18 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check your drive belt, make sure half of it isn't wrapped around the clutch fan.... speaking from experience. lol
  17. May 20, 2023 at 5:54 AM
    bft305
    bft305 New Member
    2016 tundra limited
    So ideas that might help, dump some B12 Chemtool in the gas tank, that might clean out some gunk. Maybe a sticking brake caliper???? When it feels sluggish after a drive then carefully touch each rim. If it is hot then you know which wheel is the issue. Had one freeze on me once and definitely took a hit on fuel economy/ performance. Good luck and hope you figure out the issue!
  18. May 20, 2023 at 8:42 AM
    blenton
    blenton New Member
    Is your vehicle a flex fuel engine? The alcohol percentage is known to climb to e85 territory when running standard e10 stuff. Since ethanol is less energy dense, it starts dumping fuel in to the motor, running poorly, with decreased fuel economy. Resetting the battery would sometimes alleviate the problem short term but I think you have to hard reset the sensor/computer value via the dealer or tech stream (or maybe a good scan tool?). I'm not 100% sure on the requirements for resetting it as I don't own a flex fuel vehicle and have never had to do it.
    Also, if you live in a high altitude state and have 85 octane available to you.. the truck hates it. It works, but feels very sluggish in warm weather.
