Slow to cold starts
Discussion in 'Performance and Tuning' started by CarolinaToyota, Jan 6, 2021.
  1. Jan 6, 2021 at 8:45 AM
    CarolinaToyota
    CarolinaToyota [OP] New Member
    Marcus
    2015 Sequoia
    I have a 2015 Sequoia that on the initial cold start it is very slow to start. Battery is fine, starter is working fine. any suggestions?? Almost like the fuel pressure is low?..
  2. Jan 6, 2021 at 8:55 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    How old is the battery?
  3. Jan 6, 2021 at 9:04 AM
    CarolinaToyota
    Marcus
    2015 Sequoia
    only 2-3 years old. the cranking speed seems fine. but i haven't had battery checked.
  4. Jan 6, 2021 at 9:20 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
  5. Jan 6, 2021 at 9:24 AM
    CaptainGrumpus
    Maine
    Have it tested just to make sure. Advance autoparts can do a full battery analysis for free.
  6. Jan 6, 2021 at 9:32 AM
    CarolinaToyota
    Marcus
    2015 Sequoia
  7. Jan 6, 2021 at 9:39 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    I just went through the same problem and the fix was "re-learn the fuel to alcohol mixture" Dealer blamed it on bad fuel although it never ran bad. It got progessively worse as the weather got colder. One morning it took 3 attempts to start. Starter turned over fine, would shudder on start up until it seemed to get fuel. I thought bad fuel pressure switch but they checked that and was not loosing fuel pressure. They did check the cranking amps on battery and they were low, 2018 battery, but never was slow on cranking. Replaced battery before continuing with tests.
    Good luck, this is not by the way covered under an extended warranty.
  8. Jan 6, 2021 at 10:02 AM
    CarolinaToyota
    Marcus
    2015 Sequoia
    thank you! sounds to be a very similar issue
