Slow Leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by alpinepro4, May 18, 2020.
  1. May 18, 2020 at 8:52 PM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    So my truck has developed a slow leak. Looks to be coming from the transmission. Dealer ship said it was a loose plug, they torq it to spec and said problem fixed. Yeah right! Seems to me it coming from the seal. Should I be worried? This fix is above my pay grade.
    95967AF7-CE8C-441B-8921-F579591B3260.jpg AE5B3807-8DDA-4D4A-8D1F-F59D1884BF0B.jpg
  2. May 18, 2020 at 8:54 PM
    TheBeast The Beach
    can you remove the cover and see where it's coming from ?
  3. May 18, 2020 at 9:04 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That’s actually the transfer case you’re looking at there. It’s really hard to tell from your picture where the leak is from, but it doesn’t look very oily above the drain plug. I’d suggest wiping it clean, use some brake clean if needed. Then keep a close eye on it for the next week.
    TheBeast likes this.
  4. May 18, 2020 at 9:13 PM
    alpinepro4
    Pat
    I wiped it clean a week ago. Smells like gear oil. I looked at pulling the shield off. Looks like I end up pulling the bolt that sandwiches the transfer case. I will climb under it tomorrow and see if I can pull the plate off.
  5. May 18, 2020 at 9:31 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Check your fluid level. Refill if needed And Torque down the drain plug.
    If all that is ok. Wipe it all down clean. After a few miles check the seal along the transfer case.
  6. Jun 19, 2020 at 3:01 PM
    alpinepro4
    Pat
    I took the shield off and found the slow leak. Leak is where the drive shaft meets the transfer case. I don’t have the tools to fix this. Don’t know what causing the leak. I also noticed oil all over the skid plate. Anyone know what my problem is so I can tell my mechanic?
    5CFEB506-E1F7-41D5-A5C4-06857D28E52D.jpg 892D8637-DC7D-470E-8DED-C09C6997F658.jpg 26A991ED-1A45-453C-AB6F-998A5CE2CBFF.jpg 3AD54C60-8898-41C9-8B12-098382A8A25D.jpg AC9FCC5B-3ABC-4CE4-B140-BC66F134D9F5.jpg
  7. Jun 19, 2020 at 3:32 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Shaft output seal could be the culprit...just spit-balling ideas...
  8. Jun 19, 2020 at 4:25 PM
    alpinepro4
    Pat
    That looks to be the culprit. I found a thread a member had started on this very problem. It was shaft output seal. Mine has been leaking for awhile now. Good to know what it is.
    HulkSmurf14[QUOTED] likes this.
  9. Jun 25, 2020 at 3:48 PM
    alpinepro4
    Pat
    My slow leak turned into a transfer case pull. Dealership is going to crack open the case and replace all the seals. Then they reseal the case, let cure for 12 hours then fill and load test. Hopefully all is good then. Glad this is under warranty. And will be buying an extended warranty. If I had to pay out of pocket I am guess at least a grand.
    HulkSmurf14 likes this.
  10. Jun 25, 2020 at 4:20 PM
    HulkSmurf14
    2014 Tundra Limited
    Great news! Keep us posted!
  11. Jan 31, 2023 at 7:54 PM
    WaStateTundra
    WaStateTundra New Member
    2014 4WD 1794 Attitude Black 170k miles
    Have the same exact symptoms, what was your verdict?
  12. Mar 1, 2023 at 7:38 AM
    alpinepro4
    Pat
    Dealership pulled and resealed the transfer case. Truck is still under warranty so that was nice. Very uncommon issue.
