Slipping transmission?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rsolano87, Jun 19, 2023.
  1. Jun 19, 2023 at 7:28 AM
    Rsolano87
    Rsolano87 [OP] New Member
    Randolph
    2024 tundra trd off road
    Westcott design pre load collar lift
    So I just bought my 21 limited 5.7 it’s got 23k on it. I took it out for a few hour trip and ended up in amazing CA traffic. I noticed at bumper to bumper speed if there was a larger distance between myself and other car and I accelerated really lightly to bridge the gap, the truck felt like it would slip (as in transmission slip) I know with the 6 speed tranny life is a little different, but is that “normal”? Or has anyone felt what I’m describing?
  2. Jun 19, 2023 at 8:03 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Sounds normal. I've been in the same situation where i'm easing in acceleration with traffic and sometimes when letting off the gas, it'll do a somewhat noticeable feeling shift into 2nd. I can almost replicate it on demand.
    Rsolano87[OP] likes this.
  3. Jun 19, 2023 at 8:15 AM
    Rsolano87
    Randolph
    exactly !
  4. Jun 19, 2023 at 8:15 AM
    Rsolano87
    Randolph
    Okay well good to know I’m not solo here
  5. Jun 19, 2023 at 8:28 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Every type/brand/trim of a vehicle can behave differently compared to what you're used to. I went from a 2015 honda civic with CVT to a 2014 Tacoma v6 4x4 to my current 2020 Tundra. Each vehicle had different characteristics to it that makes you think.
    If you feel the transmission is truly slipping though and you're worried about it, you're in warranty still. But since I can feel it holding that first gear longer before shifting, IMO it sounds normal from what you're describing.
  6. Jun 19, 2023 at 8:46 AM
    Retired...finally
    Mine acts similar at very slow speeds and light throttle. It's as if it's deciding which gear it needs to be in.
    clay5313, Jaypown and Rsolano87[OP] like this.
  7. Jun 19, 2023 at 9:56 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Sounds like you need a new transmission. I'll take this bad one off your hands ;)
  8. Jun 19, 2023 at 10:00 AM
    Rsolano87
    Randolph
    hahah love it!
    Cruzer[QUOTED] likes this.
  9. Jun 19, 2023 at 10:18 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I'm not an expert in Tundra transmissions, but most modern vehicles utilize adaptive learning transmissions and "learn" shift patterns based on driver behavior. I've always been told when buying a used vehicle to give the vehicle some time to learn your driving habbits versus the previous owners. Whether it is in my mind or not, I've noticed that my transmission shifts smoother than the first day I bought it (it was used).
  10. Jun 19, 2023 at 12:03 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Yep, normal. It's one of the things that's always bugged me about the truck, like it drops to a lower gear unnecessarily.
  11. Mar 6, 2024 at 4:48 PM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Thread revived. My 2018 does it. My 2009 tacoma did it also until they re flashed the transmission.
    Does anyone knows about any Trans TSB?
  12. Mar 7, 2024 at 4:09 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Yup mine does it too..
  13. Mar 7, 2024 at 4:19 AM
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    Next time you hit traffic like that put the truck in sport mode and see if it feels different. The trans will probably stay in first gear longer in sport. For what it's worth, mine is a little clunky when its cold but only for a few minutes.
    Rstreight and PolishedTRD like this.
  14. Mar 7, 2024 at 4:19 AM
    Retired...finally
    :burnrubber:
  15. Mar 7, 2024 at 6:02 AM
    Rstreight
    Rstreight New Member
    Ron
    South Texas
    2021 MGM Platinum 2WD
    Yep normal....my 21 platinum does it when she's cold, feels like a long pause between 1st and 2nd.
    In heavy slow traffic I will drop her down to s2, just remember to up shift when traffic starts moving again or you'll wonder why she's running 5k at 30mph :)
