slip yolk issues/help!!
Discussion in '2nd Gen Tundras (2007-2013)' started by Dustin808, Jul 23, 2016.
  1. Jul 23, 2016 at 12:50 PM
    Dustin808
    Dustin808 [OP] New Member
    Dustin
    2008 Midnight blue Tundra Limited
    3" leveling kit 20" MOTO METAL wheels (MO961's) 305/55/20 (33") NITTO TRAIL GRAPPLERS True dual exhaust(custom built) Fabtech BullBar W/LED lights Custom Black Housing headlamps Custom LED tail lamps (Smoked) Fabtech Blacked out grill (Goes over existing grill not a replacement) PIONEER Head unit ( GPS,NAV,IPOD,Bluetooth,DVD,MP3,CD, etc...etc...) Tundra shadow light replacement for the standard door light. HID conversion on low beam side custom drilled and used LED button lights (amber) for the Bull BAR and used as a DRL (X4) 3" Recessed LED back up lamps custom fit into the rear bumper.
    OK I have a 08 limited 5.7 4X4
    Issues is the famous "clunking" while taking foot off of brake coming from a stop. No I know generally its the slip yolk not properly lubricated. My question is there are no zerk fittings to lube it just the U-Joints. It has a plastic boot over it. Now from what I read is this was common for the 2wd tu dras not 4X4's is this true? Also read that the tranny fluid lubes the slip yolk? That sounds a bit off as I know these take 2 totally different lubrication profiles. Can any one assist on how to properly lubricate my slip yolk??
  2. Jul 23, 2016 at 1:35 PM
  3. Jul 24, 2016 at 9:24 AM
    Dustin808
    Dustin
    No one??
  4. Jul 24, 2016 at 3:21 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There are TSBs for "the clunk" for both the 2wd and 4wd (TSB-0147-11) trucks. It's a bad yolk casting and the correction is to replace the entire driveshaft. If you want to grease the slip yolk splines, it has to come apart and be done by hand. Given the age of your truck, it may be out of warranty. Your next move might be to try to score one from a '12 or newer truck, or one from a truck that has had the fix (replacement).
    Dustin808[QUOTED][OP] likes this.
  5. Jul 24, 2016 at 5:18 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Dustin, I just had the shaft replaced for the same issue. Fortunately for me they replaced it @ no charge, as my warranty had ran out, but brought it to their attention when I was under warranty and everything was documented. Give Toyota a call, hopefully they will take care of you as this is a widespread problem. I don't know about the yoke, the TSB replaces the whole shaft. Good luck
    Dustin808[OP] likes this.
  6. Jul 25, 2016 at 7:49 AM
    Dustin808
    Dustin
    Thanks guys for the help I'm reaching out to my local dealer now
  7. Jul 25, 2016 at 7:56 AM
    Dustin808
    Dustin
    Even after your warranty ran out they replaced it at no cost??
  8. Jul 25, 2016 at 8:39 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    rons23 had his concern documented at the dealer prior to the expiration of his warranty so that there was documentation. I've done the same with mine as the condition in my truck is intermittent and the tech was not able to reproduce the clunk while he had the truck.
  9. Jul 25, 2016 at 9:26 AM
    Dustin808
    Dustin
    Gotcha well I have an appointment to see how much this is gonna cost me tomorrow wish me luck
    NewImprovedRon likes this.
  10. Jul 25, 2016 at 3:48 PM
    rons23
    Ron
    Kill Devil Hills
    Yes as stated above, the saving grace was I went to them with my concern, and they told me it was normal,Not!. So I was under full warranty when I brought it to their attention. They decided to cover it. Hope you get taken care of.
