sliding noise
Discussion in '2nd Gen Tundras (2007-2013)' started by jstx, Mar 28, 2015.
  1. Mar 28, 2015 at 1:24 PM
    jstx
    jstx [OP] New Member
    I recently bought a 2013 Crewmax, when I accelerate or turn I often hear a sliding/rattling noise coming from the backseat/rear panel on the driver side, opposite of the jack. It sounds like something is loose inside and moving around. How do you remove the rear panels to check it out? I tried using pliers to loosen the fasteners but it didn't seem to work. Anybody know how these fasteners come out? Thanks!
  2. Mar 28, 2015 at 3:09 PM
    BPRescue
    BPRescue New Member
    2015 Tundra TRD Pro
    Hopefully it isn't glass from a prior accident. I used the jack compartment for additional tools on my 2010 and recall that you had to be careful as there were openings to the rest of the cab, so it could easily be that metal hook that holds the jack in place or some other small nut, tools etc.
  3. Mar 28, 2015 at 3:11 PM
    Welcome to the forum!
    Did you buy it from a dealer? If so, I would let the shop tare into it to do it...if not, can you get someone in the back seat to help determine where exactly it's coming from?
  4. Apr 2, 2015 at 2:05 PM
    jstx
    Thanks everybody, it turned out to be a socket for the lug nuts that was rolling around! I have a quiet truck now.
  5. Apr 2, 2015 at 2:46 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I had this problem too, turned out to be my pocket knife sliding in the cup holder area in the door :crazy:
