sliding bed rack compatibility
Discussion in '3rd Gen Tundras (2022+)' started by TopTierToyo, Feb 12, 2023.
  1. Feb 12, 2023 at 4:35 AM
    TopTierToyo
    TopTierToyo [OP] New Member
    2022 Blueprint Tundra 4x4 Limited
    Folks, I was wondering if you had any good experience with a high quality sliding bed rack on these truck, as anything Ive found online says its incompatible.
    My plan is to put J hooks on top of the racks for 13'+ kayaks, and i need the ability to slide the racks out of the way to fit an ATV in the bed.
    Also, this might be a unicorn, but have you had experience with a sliding rack and toneau cover??
  2. Feb 12, 2023 at 5:09 AM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    I'd hang it off of the stock bedrail system with T-nuts which would let it be adjustable/slidable. Check under the caps. On my 2nd gen Tacoma with the composite bed the lip of the bed wasn't designed to be a weight bearing surface. That was nearly 10 years ago so maybe the design changed for the Tundra.
