Sliders
Discussion in '1st Gen Tundras (2000-2006)' started by Wes_heppy, Mar 28, 2021.
  1. Mar 28, 2021 at 8:20 PM
    Wes_heppy
    Wes_heppy [OP] Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    Looking at putting sliders on my 03 AC. I know there are some specific ones for this truck but these are significantly cheaper, made by a reputable company, and the right length. I can weld so that is not a problem. Anyone know if there is someone that has used these before? I would assume the price is because the are kind of simple but they would still do what they are designed for. There is also a 78” option. @Darkness @FirstGenVol
  2. Mar 28, 2021 at 8:44 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've never seen those ones. If you do go with them I would add plates to the frame where you weld the tubes on, that way you don't risk poking a hole in your frame and you'll have a stronger mount.
  3. Mar 28, 2021 at 8:52 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Ok good info thank you.
  4. Mar 29, 2021 at 5:49 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Wes_heppy I've see those discussed before but never seen anyone attempt them. If you can weld, and they are the right measurements, then give them a shot!
    Wes_heppy[OP] likes this.
  5. Mar 29, 2021 at 7:16 AM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Okay I think I will do that!
