Sliders,, kick out or no?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Clrems77, Oct 18, 2021.
  1. Oct 18, 2021 at 7:47 AM
    Clrems77
    Clrems77 [OP] New Member
    Looking for info on why you love or hate the kick out on the back of your sliders.
    Also looking for a set to purchase so if you have one that just sitting around let me know!
    Aloha
  2. Oct 18, 2021 at 8:10 AM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    First off Welcome..
    I think it depends more on the usage. If you're just mall crawl'n then ones the fit up and close to the cab (more of a step than a slider) are well suited. If you are an avid Trek'r then sliders that are more robust and protrude further from the cab are better suited. I think is just comes down to looks although the kick out sliders give you more surface area for foot placement.
    Let's not forget the 3 step sliders which have a step up on the others as they allow easy access to the front of the bed from each side of the truck
  3. Oct 18, 2021 at 8:13 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have the cali raised sliders with the kickouts and I am pretty happy with them. The kickout acts as a step to help people get in the back, or you can use them to get in the bed of the truck. Mine have already stopped a door ding on my truck as well. I think the only time the kickouts are not good is if you are doing alot of very narrow areas on trails, but you probably wont be with a beast like the tundra.
  4. Oct 18, 2021 at 8:20 AM
    TheBeast The Beach
    kickouts help you turn when on tight trails and hitting a tree or rock. It will act as a pivot point for the rear end.
    I recommend WKOR sliders.
  5. Oct 18, 2021 at 8:27 AM
    Sunnier
    Sunny
    San Diego, CA
    If you off-road in boulder terrain or where you’ll push this long wheel base through narrow gaps, picking a line through obstacles, get the kick outs. They’re not for looks, they’re functional and help keep your truck intact.
    15whtrd likes this.
  6. Oct 18, 2021 at 8:28 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I don't have sliders on my Tundra as my current needs don't align to it (and I am trying to keep weight down for towing) but after years of Taco sliders I would absolutely do a kick out if you have a truck canopy. You get all the added protection benefits plus an easier way to get to the roof!
  7. Oct 18, 2021 at 9:55 AM
    TreeRDPro
    TreeRDPro New Member
    2021 Super White Tundra TRD Pro DC
    I have sliders (without a kick out) on my FJC and really wish they had a kick out. From seeing other rigs, they really protect you from trees and big rocks on trails. Plus they act as a step to get stuff off the roof without needing to open your doors.
  8. Oct 18, 2021 at 11:18 AM
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    I prefer to have the kick out for functionality as well as the reasons stated above.
  9. Oct 18, 2021 at 12:02 PM
    Clrems77
    Thanks everyone. Looks like I’ll go with the kick outs.
    15whtrd and Sunnier like this.
  10. Oct 19, 2021 at 8:07 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    I had the kick outs on my Tacoma, and it saved me from tree damage several times. When I get sliders for my tundra I’ll be sure they have the kick out.
  11. Oct 20, 2021 at 6:39 AM
    java230
    java230 New Member
    kick out if you plan to use them, really helps on a long wheel base rig.
