Sleeping in bed with a camper shell?
Discussion in 'Tonneau Covers, Caps and Shells' started by 1Tundra5, Jul 3, 2024.
  1. Jul 3, 2024 at 8:17 AM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    So I’m looking for cheap way to travel more and spend less.
    Was wondering if sleeping in the bed with a camper shell and rolling down the rear glass window to let ac in, would be a good idea? Would the ac be enough to cool back there? Anyone try this?
  2. Jul 3, 2024 at 8:23 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Probably not... Plus you'd have to be careful about exhaust fumes and CO2.
    I'd think your best bet would be to insulate w/some of that styrofoam garage door stuff (especially on the top). Maybe look at rigging some kind of fan to get air flow (and I'm thinking more in terms of sucking hot air out in lieu of blowing already warm air in) :notsure:
    1Tundra5[QUOTED][OP] and mayan like this.
  3. Jul 3, 2024 at 8:30 AM
    40man
    40man New Member
    I have done it a lot in my old Tundra. Plenty of air flow, but I usually kept the car off and used a couple of fans. Kinda cramped in the 5.5 bed, but works on an angle. Did a lot of ski trips this way too using a small propane "flameless" heater. Kept the heater in the cab with the rear window down and front camper shell window removed. Worked awesome.
    Spent many nights in an old f150 doing the same. Longer bed was nice. Was great when I was young and didn't have means for hotels all the time.
  4. Jul 4, 2024 at 7:40 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    In the old days guys would inflate an inner tube between the cab glass and the cap
    slider. This keeps cold air and snow from falling in. Never tried it myself. I slept in the
    back of my ‘87 F150 for several years but up north it cools at night generally. Never
    used ac as you suggest. To me biggest factor is trying to find airflow when I camp.
    1Tundra5[OP] and thomez like this.
  5. Jul 4, 2024 at 8:14 AM
    c&wsinbad
    c&wsinbad Pay yourself FIRST!
    Clark
    Copperas Cove, Texas
    2024 Magnetic Gray Metallic 1794 w-Saddle interior
    BAKFlip MX4
    My great concern would be carbon monoxide from the engine running.
    opfor and 1Tundra5[OP] like this.
  6. Jul 4, 2024 at 9:30 AM
    blenton
    blenton New Member
    I’ve slept in the bed with a camper shell. It works just fine, but as others have said , I wouldn’t run the vehicle while you are sleeping. That could be a good way to get un-alived. A power bank (I have a Milwaukee setup) and a fan would keep you from running down the battery. If you have slider windows on you shell, slide em open s bit for airflow.
    Wallygator and Tripleconpanna like this.
  7. Jul 4, 2024 at 9:35 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Never leave it running, ever. Run it to warm it up or cool it down, shut it off.
  8. Jul 4, 2024 at 10:28 AM
    40man
    40man New Member
    Yes, I forgot to mention this. I used two plus bicycle tires on my 2nd gen. Cut and glued together with gorilla glue and tape. Only kept 1 valve. Dont need much pressure for a seal. Only use when needed. Not sure how it would work as a permanent installation but works decent. I have two tubes available to do it again.
    However, I just installed 3M paint protection on cab window and will be installing this:
    https://www.amazon.com/dp/B0BM91B5ZL/?coliid=I1ABZ9FDZYOFD4&colid=3T5OH62AU8LJG&th=1
    Someone else on a tundra thread said they installed it and it works great without touching paint. I put the paint film on the cab as extra protection. The idea is I can roll my window down and have a sealed passthrough or rolled up to keep separate. If the seal is good I'll keep the fold down window out permanently. Will be a good setup for the dogs.
    Planning to add a 120v fan in the camper as well as something like this as well to get more airflow into the camper to keep the pups cool:
    https://www.amazon.com/dp/B081W8MDZP/?coliid=IHEO4G7TMM7YV&colid=3T5OH62AU8LJG&th=1
    Or a headrest specific fan like this:
    https://www.amazon.com/sspa/click?ie=UTF8&spc=MTozOTcwOTYzMzMwNTY1OTQ3OjE3MjAxMTM4NDM6c3Bfc2VhcmNoX3RoZW1hdGljOjIwMDAxNjQ0NzczNzQzMTo6MTo6&url=%2FElectric-Passenger-Portable-Rotatable-Regulation%2Fdp%2FB07VB9QHWP%2Fref%3Dsxin_16_pa_sp_search_thematic_sspa%3Fcontent-id%3Damzn1.sym.5439bf72-3da4-45fb-a22b-ecb711485806%3Aamzn1.sym.5439bf72-3da4-45fb-a22b-ecb711485806&crid=3UVY43AFUZZKN&cv_ct_cx=headrest+fan&dib=eyJ2IjoiMSJ9.TCPBfkCw1ppGdKGs-YFh2FvUEk1UIDjcwVa-yrjFbkAxsBOXMW-eWgFqA8Nt_LlSIbJMI6H_nVcJzW2pDehOxw.qJg2xYT5hYB1BW1ZIeMbf_96RyrTjuwrrNK3blZa1Cs&dib_tag=se&keywords=headrest+fan&pd_rd_i=B07VB9QHWP&pd_rd_r=eccd8439-815b-4e6d-b6bd-104d5f0b71a4&pd_rd_w=Sg15D&pd_rd_wg=ChVD8&pf_rd_p=5439bf72-3da4-45fb-a22b-ecb711485806&pf_rd_r=4RAWFJB4PJMZKZ053PNV&qid=1720113843&s=home-garden&sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D&sprefix=headreat+fan%2Cgarden%2C175&sr=1-2-364cf978-ce2a-480a-9bb0-bdb96faa0f61-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9zZWFyY2hfdGhlbWF0aWM
