Skunkworks DCSB
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Jun 6, 2023.
  1. Jun 6, 2023 at 7:29 AM
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    8/11/2023
    Just bought this 2015 Limited DC. Need to fly up to Portland, OR next week and drive it back home.
    chugs, Ryuu and 2mchfun like this.
  2. Jun 6, 2023 at 7:30 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Gantry
    I need to build one of these
    https://youtu.be/S55DvPpfcjM
    Building Materials:
    11: 2x6x10 (wood at Lowes sucks)
    2: 2x12x8 (accidentally bought 2x12x10)
    1 ton Chainfall
    2x2 Angle iron
    1" steel rod
    Casters
    Additional chain
    Screws (GRK 1/4" x 2.5")
    Wood glue (got waterproof since it'll be stored outdoors)
    Thompson's Water Seal
    Will need to make it detachable in order to fit in the backyard.
    6/9/2023
    Got these casters from Amazon, pretty fricking beefy. Pretty much all steel. A box of 4 was pretty heavy.
    6/11/2023
    Went to HF and picked up this miter saw. Not looking for the best. I just need it to cut straight and cut angles.
    Then I went to Lowes and got wood, glue, and screws. Gonna let the wood sit outside for a week and start putting shit together next week.
    6/19/2023
    Made the uprights today. Used nearly the whole bottle of glue and most of the screws already.
    Gonna need a belt sander to make the bottoms flat.
    9/16/2023
    Took a lot longer to build than I thought it would. I applied Thompson's Water Seal so that it can last through the winter outdoors.
  3. Jun 6, 2023 at 7:30 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    How to: Drop the frame
    (Notes to self)
    • order more jack stands
    • order engine hoist mounts
  4. Jun 6, 2023 at 7:30 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Short Bed Install
    I'll be chopping the frame underneath the bed where the C-channel frame straightens out. This will force me to relocate the rear cab mount, which will be right above the forward leafspring hanger.
    With the frame moving forward I will need to chop into the cab to allow this rise in the frame to fit underneath the cab.
    The rise in the frame actually curves inwards. I will need to fab some sort of rising block and a beam to go across before I cut out the bottom of the cab.
    Found footage from a back halfed CM Tundra with the rear cut out.
    Based on this the RED box is where the body mount would be and the BLUE box is where I could run a tube to fortify the cab.
    I guess I'd need to brace the top of the cab body mount to the brace
    Looks like these are the parts:
    Rather than cut, I think I'll find the pinch welds and drill them out to remove whole.
  5. Jun 6, 2023 at 7:30 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Boxing the Frame & LCA mounts
    Collecting some ideas.
    • Would like to use dimple dies to reduce added weight and actually increase rigidity
    • I like how this crossmember is welded onto the frame
    • I also like the notches to allow water to drain out
  6. Jun 6, 2023 at 7:31 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Atlas Transfer Case
    6/11/2023
    Went under the truck to see how the stock TC was clocked. This view shows the front drive shaft coming out of the TC.
    So now I know it is positioned like this. 4 o'clockish
    I'll unbox the Atlas TC next week to see how it needs to be clocked and also need to figure out how to mate it with the transmission. Making a homemade adapter will be super fun :rolleyes:
    6/19/2023
    Took some measurements and started drawing things out. I wish I could do CAD but this will do.
    This is the Atlas doubler that mates with the transmission. It has a Jeep/Dodge female 23 spline input shaft. Atlas doesn't make an input shaft for Tundras.
    This represents the transmission tail housing with the male 22 spline output shaft sticking out:
    This represents the spud shaft (spline adapter) I need to get custom made:
    The grey piece is the custom 2.25" thick aluminum adapter I need to make by hand. The black squiggly line is a coil spring to keep the spud shaft from moving in and out.
    The adapter will probably look like this. The transmission tailhousing is octagon shape and is about 10.25" wide. The Atlas is circular and is about 8" wide. The inner holes are for bolting the Atlas to the adapter, while the outer holes bolt to the transmission tailhousing.
    10/18/2023
    Thanks to @snivilous recommendation I finally have a shop that is going to machine the spline adapter (aka spud shaft) out of 300M. Mofo will be strong!
    I've purchased transfer case punches in preparation for making a wood version of the TC/Transmission adapter.
    However, I have not been able to find an M10x1.25 transfer screw so I ordered a bunch of bolts with the plan of making my own. Will cut off the hex side, place the threaded section into my drill press chuck, then use my grinder to create a pointy tip while the drill press is spinning. The tip should center itself.
    When I ordered my Atlas TC I really didn't know all of the components so I winged it. I ended up with CV yokes for the front and rear output since they didn't have the flange yokes that fit the Tundra. Little did I know at the time was that it didn't matter if the flange yoke didn't fit the Tundra because I would have to get my drive shaft customized anyways and could put a matching non-CV yoke on it.
    Why am I changing it in the first place?
    These CV yokes stick out a lot, which would result in shorter drive shafts, especially the front, which will create steeper angles. I've also read that the 2 pins that secure the U-joint are weaker.
    Here's the current yoke.
    I'm changing it out to this 1350 flange yoke, which looks like the Tundra flange but is not a match so the flange yoke on the driveshaft will not fit.
    This Neapco N3-2-1579 will replace the ones on the driveshaft
  7. Jun 6, 2023 at 7:31 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Fuel Tank Tuck
    With the bed off the truck I can finally get a better look at what I have to deal with.
    • I'll need to move the fuel tank towards the rear diff so that this hump doesn't end up underneath the bed when the frame is chopped and moved forward.
    • I will need to cut into the cab where it hangs low. This is a supporting structure so I will need to make a long C notch
    • I'll probably get rid of this crossmember and replace it with one that goes under the tank and back over the drive shaft.
    Once I can get the fuel tank lifted up I can then have a crossmember that would beneath the fuel tank then back up and over the driveshaft and exhaust to the other side of the frame.
    This crossmember will be where I mount my fuel skids to. The goal is to have 3/16 fuel skids at the same level as the bottom of the frame.
  8. Jun 6, 2023 at 7:31 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Body mount swap
  9. Jun 6, 2023 at 7:31 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Reinforce sliders
    - brace ends
    - gusset middle
  10. Jun 6, 2023 at 7:31 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Relocate rear shock mounts
  11. Jun 6, 2023 at 7:31 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Skid plates
  12. Jun 6, 2023 at 7:32 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Project: Rear diff truss and armor
  13. Jun 6, 2023 at 7:32 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Placeholder13
  14. Jun 6, 2023 at 7:32 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Placeholder14
  15. Jun 6, 2023 at 7:32 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Placeholder15
  16. Jun 6, 2023 at 9:08 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Placeholder16
  17. Jun 6, 2023 at 9:08 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Placeholder17
  18. Jun 6, 2023 at 9:08 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Placeholder18
  19. Jun 6, 2023 at 9:08 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Placeholder19
  20. Jun 6, 2023 at 9:08 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Placeholder20
    Sunnier likes this.
  21. Jun 6, 2023 at 9:11 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
  22. Jun 6, 2023 at 9:21 AM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    :spam:
    This better be good, after all those "spoilers"
    I kid, getting popcorn and mountain dew like Colton is, waiting for the show to begin.
    Fobroader and Taco-Spike like this.
  23. Jun 6, 2023 at 9:22 AM
    RobertD
    Robert
    DFW, Texas
  24. Jun 6, 2023 at 9:31 AM
    Taco-Spike
    Two Trucks
    Title change: First greatest reveal in 2.5 gen history
  25. Jun 6, 2023 at 9:32 AM
    TaquitoBandito
    Joel (AKA Bif)
  26. Jun 6, 2023 at 9:42 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Well this was anticlimactic.
  27. Jun 6, 2023 at 10:10 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Changed the title :rofl:
  28. Jun 6, 2023 at 12:43 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Skunkworks love it
  29. Jun 6, 2023 at 12:52 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    And here I wish I could do the opposite, put a 6.5' on my CrewMax!
  30. Jun 6, 2023 at 12:58 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    That's doable. I'll trade you beds if you're on the west coast :D
    snivilous and Sunnier like this.
