Skid Plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by kwebre, Nov 25, 2020.
  1. Nov 25, 2020 at 7:19 AM
    kwebre
    kwebre [OP] New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    Looking to purchase a new skid plate from RCI but wasn't sure if I needed to order with differential drop hardware. I have a 4" pro comp suspension lift which doesn't look like it required the differential drop. Your knowledge is appreciated.
  2. Nov 25, 2020 at 7:21 AM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    You will need to physically verify if you have the drop. I assume you do based on your lift size
  3. Nov 25, 2020 at 7:28 AM
    timsp8
    NY
    I think the hardware is free if you need it. You could just get it anyway just in case you ever need it.
    frichco228 likes this.
  4. Nov 25, 2020 at 7:31 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Just pop your head under the truck and see if there is a 1" spacer installed on the front diff mounts.
    If your factory skid plate is installed and doesn't look modified or bent to hell you probably don't have a diff drop.
