Skid plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by Blackbetty, Mar 19, 2017.
  1. Mar 19, 2017 at 5:28 AM
    Blackbetty
    Blackbetty [OP] New Member
    Is rci the only company that's making a skid plate with an access door for the oil filter? I don't want to take it off every time for an oil change. Plus I had to put spacers up there with my diff drop.
  2. Mar 19, 2017 at 6:47 AM
    Cfincke
    San Antonio
    I just installed a TRP Pro skid plate, it has an access door for changing the oil filter also. I did run into a few problems since I also have a diff drop. I have to add some spacers to the skid plate to clear the differential support arms (where the diff drop is) and get a couple longer bolts. If I hadn't gotten a great deal on the used TRD Pro skid, I would have gone with the RCI.
    @Sean266 has the RCI and a diff drop without any issues
    MotoTundra and T-Rex266 like this.
  3. Mar 19, 2017 at 7:33 AM
    Blackbetty
  4. Mar 19, 2017 at 7:43 AM
  5. Mar 19, 2017 at 8:12 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't know if RCI is the only co. making them but I'm really happy with mine ( I have the diff drop). For what they are, the price is really good too IMO.
  6. Mar 19, 2017 at 8:22 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Just an FYI If you're worried about a diff drop and spacers on the skid, I saw a post from @jberry813 that they don't make a difference on the cv angle of gen 2/3 Tundras anyways... I have my kings set at 3" up front and that guy knows his stuff so I didn't bother putting on the diff drop I bought.
  7. Mar 19, 2017 at 8:24 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    That's 2 different plates, right? Skid+transfer case plate?
  8. Mar 19, 2017 at 8:25 AM
    Yep.
    I have the fuel tank skid too
    dcsleeper408, JH5370 and BlueBottle like this.
  9. Mar 19, 2017 at 8:40 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Bud built makes some good skids.
    Also p&p engineering released there full set recently.
    BlueBottle and 831Tun like this.
  10. Mar 19, 2017 at 9:35 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Is that a 38gal alum skid?
  11. Mar 19, 2017 at 9:48 AM
    No. I don't have a 38g
    BlueBottle likes this.
  12. Aug 20, 2017 at 10:39 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    Did you choose the steel or aluminum option? Fixing to place an order and I don't know which one to choose?
  13. Aug 21, 2017 at 6:49 AM
    Aluminum
  14. Aug 21, 2017 at 6:57 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    I have the Buds. Great stuff but those RCIs look good too.
    dcsleeper408[QUOTED] likes this.
