Skid Plate Oil Filter Access Issue
Discussion in 'General Tundra Discussion' started by YotaBro, Feb 19, 2021.
  1. Feb 19, 2021 at 4:50 PM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    Lots of shenanigans.
    Hey guys, when changing the oil on my Tundra I stripped the screws on the oil filter access panel. I somehow got one out but the other 3 are stuck in there. I tossed in the towel after I purchased an extractor set (link below) but it couldn't get it out. Any advice on how to get the screws out? I tried wrapping the 5mm allen socket with a glove and couldn't get it out. If all else fails, I'll just put oil in it and drive it to a shop to remove the bolts for me. (Would prefer that as a last resort though)
    https://www.lowes.com/pd/SpeedOut-8-1-8-in-Double-Ended-Screw-Extractor/1000170531
  2. Feb 19, 2021 at 5:31 PM
    Is it the TRD skid plate?
  3. Feb 19, 2021 at 5:38 PM
    YotaBro
    Calvin
    FL
    Yes
  4. Feb 19, 2021 at 5:42 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Remove the skid plate entirely, it’s not very hard. Then you can proceed with your oil change as needed and fix the access hatch at your leisure in your shop.
  5. Feb 19, 2021 at 5:43 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
  6. Feb 19, 2021 at 5:43 PM
    Can you pull it off and see if you have any thread protrusion where you can put vise grips on them?
  7. Feb 19, 2021 at 5:45 PM
    Its not the bolts. Its the recessed allen head screws on the filter door that he has stuck.
    YotaBro[OP] likes this.
  8. Feb 19, 2021 at 5:46 PM
    This^^^^
    gosolo[QUOTED] likes this.
  9. Feb 19, 2021 at 5:46 PM
    YotaBro
    Calvin
    FL
    I was gonna try vice grips tomorrow, what're y'alls thoughts on hammering it with a star bit set and then trying to extract it out that way?
    https://www.youtube.com/watch?v=VeBmuWS6T5A&ab_channel=BLOXSTARZTV
  10. Feb 19, 2021 at 5:46 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    All of the above.
    I have yet to see or use a screw extractor that actually works. The only thing that ever does is vise grips or pliers gripping an end and manually turning it out.
    Screw extractors have always been gimmicky to me.
    RitcheyRch likes this.
  11. Feb 19, 2021 at 5:47 PM
  12. Feb 19, 2021 at 5:49 PM
    YotaBro
    Calvin
    FL
    I don't think that I can get the bolts off with a vice grip but I can try tomorrow. I'd also prefer not to take off the entire skid plate but if it comes down to that then I will.
  13. Feb 19, 2021 at 5:56 PM
    If you were local to the Clearwater/St Pete area we would get them out. Stuck screws are common in aircraft maintenance. Pull the skid plate off and see If you have a machine shop near you.... they would have them out in no time.
    YotaBro[QUOTED][OP] likes this.
  14. Feb 19, 2021 at 5:56 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Do you strip all three or are they just seized? :notsure:
    Show us a pic of your bolt heads, so we can see how damaged they are.
  15. Feb 19, 2021 at 5:59 PM
    YotaBro
    Calvin
    FL
    I wish bud, I'm at FWB/ Pensacola area. I think I might do that tomorrow. My only worry is that I don't have a breaker bar but I can jimmy rig something together to get it out.
  16. Feb 19, 2021 at 5:59 PM
    YotaBro
    Calvin
    FL
    So they were already stripped (I think from the previous owner) and I only made it worse.
  17. Feb 19, 2021 at 6:00 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Ahhhh, that makes more sense.
    I was hoping you didn't strip 3 of 4 bolts that were probably just seized
    Hope you get it off successfully.
  18. Feb 19, 2021 at 6:01 PM
    YotaBro
    Calvin
    FL
    Thanks!
  19. Feb 19, 2021 at 6:06 PM
    From my experience, most silver/chrome allen head screws are a softer material and strip easier. The black ones seem to be a litter better.
  20. Feb 19, 2021 at 6:08 PM
    YotaBro
    Calvin
    FL
    Yup, they're the silver ones, unfortunately :(
    I don't know how I start a simple oil change and manage to turn it into a 2-day process. I've worked on my own cars my entire life and this is by far the most work that I have spent on an oil change.
  21. Feb 19, 2021 at 6:09 PM
    For replacement I would get washers and hex head bolt that is a little longer and use that instead of recessed screws.
    YotaBro[OP] and BravoDeltaRomeo like this.
  22. Feb 19, 2021 at 6:17 PM
    YotaBro
    Calvin
    FL
    Any idea what size?
  23. Feb 19, 2021 at 6:20 PM
    I'm not sure. Maybe one of the guys that has the TRD might know.
  24. Feb 19, 2021 at 6:29 PM
    I am having issues trying to download the instructions but what I did find so far is that it appears to be an M6 size screw.
  25. Feb 19, 2021 at 6:33 PM
    YotaBro
    Calvin
    FL
    Ok, thanks for the info! I'll prob bring the bolt to ACE and try match something.
  26. Feb 19, 2021 at 6:58 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I have used mine a handful of times and I'm surprised it has worked. Usually I need a fast drill for it to work.
  27. Feb 19, 2021 at 7:29 PM
    YotaBro
    Calvin
    FL
    Yeah, I dont know if I am just doing it wrong or what but the one screw that I got off required a decent amount of effort to get it off. Idk if it is always like that or if dirt got into it.
