Skid Plate Install Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by runCMD, Apr 14, 2019.
  1. Apr 14, 2019 at 1:06 PM
    runCMD
    runCMD [OP] BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    so while waiting for my new ball joints to come in the mail, I tried to install the skid plate I picked up from @InfernoPRO. I can’t get them on and assuming it’s due to a piece that’s from my lift kit? Can’t get the front to sit all the way up. Do I just need longer hardware?
  2. Apr 14, 2019 at 1:42 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    What lift do u have?
  3. Apr 14, 2019 at 1:45 PM
    runCMD
    bought it from the dealer with it - not sure but I'm pretty sure I have Tuff Country UCAs :)
  4. Apr 14, 2019 at 1:55 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Probably gonna need spacers and longer bolts. Think ready lift sells a kit
  5. Apr 14, 2019 at 2:07 PM
    runCMD
    It does indeed look like I have a diff drop - just ordered the kit. Will probably just leave the full skid plate off until it comes
  6. Apr 14, 2019 at 2:12 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    If you don’t have a diff drop installed, it should fit without spacers. From the pictures it looks like you don’t have it lined up all the way. The ears on the outside of the skid should be on the outside of your sway bar brackets. Make sure that the bolts in the front are aligned perfectly with the holes in the frame. Took me a little bit of messing around with it before it would go in straight. I ended up laying on my back under the truck with my fee towards the bed. Then I could essentially use both hands to line it up while my leg supported the back end.
  7. Apr 14, 2019 at 2:21 PM
    runCMD
    interesting, i checked and i do have a diff drop, but it also looks like i might not have been lined up - i thought i looked and it was that way on both sides. not sure i want to get under there again with all the other work i have left to do today on the truck
  8. Apr 14, 2019 at 2:32 PM
    runCMD
    At first I thought the block above the sway bar might be aftermarket and the main issue but it looks like this diff drop spacer might be actually the main culprit.
  9. Apr 14, 2019 at 2:44 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Remove the sway spacer. And use some washers to accommodate the diff drop. Or remove the diff drop
  10. Apr 14, 2019 at 2:57 PM
    runCMD
    If I did that I suspect having my 3" coil spacer would be a problem. I don't think I want to remove pieces of my lift which is now necessary for my 35s, here's hoping the readylift kit solves my issues.
  11. Apr 14, 2019 at 4:11 PM
    KnuckleHD
    Yep, the skid plate spacer will solve your problems. Easy fix. Just a pain to get half way through and find out you need another.
    On a side note, not sure why hardware comes with the spacer kit but if you end up not needed the stock, middle bolt (5mm Allen), let me know.. I need a new one and don’t want to buy a whole new hardware kit.
  12. Apr 14, 2019 at 4:17 PM
    runCMD
    will do
  13. Apr 14, 2019 at 5:24 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Buy or fabricate some spacers for the gap. Buy some aluminum spacers and drill them out for the bolts
  14. Apr 24, 2019 at 12:16 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I bought the readyLift TRD pro skidplate spacer kit. Works well
  15. Apr 24, 2019 at 11:09 AM
    runCMD
    Same - worked out great. I had the same critiques I saw someone else voice - would have been nice to have more instructions and for the price I think having a middle square support structure like the stock it comes with would have been nice other than a little spacer. Seems like $50 is a little steep for some longer hardware and some spacers but I'm no expert and it's not all that much anyways. Happy to pay it for ease of not having to measure and buy separate pieces.
    Tundyfundy likes this.
