Skid plate creaking
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TundraJeff305, Aug 14, 2021.
  1. Aug 14, 2021 at 9:54 AM
    TundraJeff305
    TundraJeff305 [OP] New Member
    Jeff
    2021 TRD Pro
    I know this is a real thing I’ve seen it posted on Facebook and YouTube. My truck has 9k miles and recently a creaking noise started up front mostly backing out of driveway and over bumps. There no tire rubbing and nothing loose so I’m fairly sure it’s the skid plate. Has anyone dealt with this? If so whats the best fix? Sounds like the dealership just tightens the bolts which I’ve already done.
    Thanks
  2. Aug 14, 2021 at 9:59 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    I believe some put rubber bushings between the plate and frame where it bolts up
    TundraJeff305[OP] likes this.
  3. Aug 14, 2021 at 10:23 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    rubber washers will take care of it
  4. Aug 14, 2021 at 5:16 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Very common. Search feature is your friend. Mine comes from the aluminum - steel interchange towards the back of the plate.
    avssuc and TundraJeff305[OP] like this.
  5. Aug 14, 2021 at 5:20 PM
    Do any of the aftermarket plates do this? I have a creaking as well pulling in and out of the driveway. I have the RCI skid. It could be the TRD front sway bar bushings too. :notsure:
  6. Aug 14, 2021 at 7:27 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    I think that may be over-torqued bolts on the plate.
  7. Aug 14, 2021 at 10:07 PM
    AZBoatHauler
    So.Arizona
  8. Aug 14, 2021 at 10:14 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Rubber washers or foam tape around contacts and most importantly is properly torqueing each bolt. I haven't heard a peep after both of those steps.
  9. Aug 15, 2021 at 12:15 AM
    French Avocado
    Utah / Wyo
  10. Aug 15, 2021 at 5:37 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I have had RCIs on two trucks now and no noise from them what so ever.
  11. Aug 15, 2021 at 6:14 AM
    I'm thinking sway bar bushings maybe?
  12. Aug 16, 2021 at 7:15 AM
    scout495
    scout495 New Member
    This is the fix. $2 dollars in rubber washers and 30 minutes of your time. I was maddened by the sound for 4 years until someone on here posted the above info. Refer to comment #20 for the nuts and bolts of it. Three different Toyota service depts couldn't figure it out for me.
    AZBoatHauler[QUOTED] likes this.
  13. Aug 16, 2021 at 2:48 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    It is the Skid Plate mounting points, most likely the rear ones. Trust me, I have seen this movie. Place rubber bushings/shims between the bolts and the skid plate, as well as between the frame. Your noise will disappear like presto.
    COTundra23 likes this.
