Size of Oil Pan Drain Plug on 2024 Tundra IF-Max Hybrid
Discussion in '3rd Gen Tundras (2022+)' started by dccrens, Jul 20, 2024.
  1. Jul 20, 2024 at 6:42 AM
    dccrens
    dccrens [OP] New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    Does anyone know what the drain plug size is?
    I am getting an oil pan drain valve and they are sized like M12 X 1.25MM, or M14-1.50. Any thoughts on the correct size? I want to go with ValvoMax or Vertex.
  2. Jul 20, 2024 at 6:49 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    The drain plug is 14mm
    22whatwedo likes this.
  3. Jul 20, 2024 at 6:54 AM
    dccrens
    Leesburg, VA
    So M14-1.50 would be the correct one?
  4. Jul 20, 2024 at 7:32 AM
    Matt2015Tundra
    2023 1794 CrewMax
    No, you need the M12 x 1.25. M12 represents the diameter of the threaded portion of the bolt, 1.25 represents the thread pitch. It requires a 14mm wrench.
  5. Jul 20, 2024 at 8:08 AM
    dccrens
    Leesburg, VA
    Ok! Thanks! Ordered.
