SiriusXM issue
Discussion in '3rd Gen Tundras (2022+)' started by raylo, Jan 21, 2023.
  1. Jan 21, 2023 at 1:06 PM
    raylo
    raylo [OP] not so new member
    Frederick, MD
    When I go to listen to SiriusXM on the trial (I have not added the Tundra to my existing account that I have for other vehicles) and I can't get to the main sequential listing of all the channels. All I get is a screen of channels that are "recommended for you" and another for "favorites". I want to scroll through the main list and set my own favorites. The Tundra infotainment manual shows such a screen, but I can't find that on my truck. What am I missing? BTW, I have I have had SiriusXM... well, just XM in the early days... in my vehicles for at least 20 years so not my first rodeo.
  2. Jan 21, 2023 at 1:48 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Did you setup a profile for you in the Toyota infotainment? Or using a guest profile? You need to make sure you have your account setup first
  3. Jan 21, 2023 at 1:51 PM
    raylo
    Frederick, MD
    Yes, did that at the dealer. SXM works fine. It's just that I am limited to about 10 channels that are "recommended" and "favorites". There is the option to log out and continue as a guest. Maybe I'll try that and see what happens. And then try logging in again.
    The other thing I find odd is that on all of my other systems, whether factory or aftermarket, the touchscreen presents some number of persistent soft preset buttons that you use to set your presets. Don't have this on my Tundra screen that I can tell. In SXM it has the icons for the recommended and favorite channels arranged on the screen
  4. Jan 21, 2023 at 2:21 PM
    xc_tc
    xc_tc New Member
    I need to check but I thought there was a list or a category search if you hit the back arrow on the upper left part of the screen.
    Here’s someone messing around with the radio: https://youtu.be/PrrvVHC8RU8
  5. Jan 21, 2023 at 3:08 PM
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    The best I can tell, there is no screen that lists all channels. However if you are listening to Sirius XM and the channel info is shown in the lower right, if you touch that it will open the tuning screen which will should allow you to either directly enter a channel number or tune from channel to channel using + -. It is similar to the AM/FM radio side but no scan button.
    raylo[OP] likes this.
  6. Jan 21, 2023 at 3:23 PM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    I can’t pull up a list either. Best I can do is the damn icons. Kinda bummed about it but it’s free trial… XM gonna die out someday anyways
  7. Jan 21, 2023 at 3:26 PM
    raylo
    Frederick, MD
    I don't mean to view the list but to be able to tune sequentially from channel 1 to the end. And save presets along the way. When I hit the steering wheel channel button it just cycles through the favorites. SXM not going to die, IMO.
  8. Jan 21, 2023 at 3:30 PM
    xc_tc
    xc_tc New Member
  9. Jan 21, 2023 at 3:31 PM
    raylo
    Frederick, MD
    i don't get that screen.
  10. Jan 21, 2023 at 3:35 PM
    xc_tc
    xc_tc New Member
    Does it look like this? Should be able to touch this area to get the screen to change
  11. Jan 21, 2023 at 3:36 PM
    xc_tc
    xc_tc New Member
    missed the pic
  12. Jan 21, 2023 at 3:51 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    You can find the all channel button if you scroll down on after you hit the siriusxm button, it won’t stay scrolled down and when you pick a channel you can’t go back to the list you need to go through the steps again it’s a bad setup. I put a bunch of stuff on favourite and just click though those channels with the arrow <>
    Sets are: music/siriusxm/scroll to all channels
  13. Jan 21, 2023 at 4:30 PM
    raylo
    Frederick, MD
    This is the answer. For whatever reason it comes up playing a station and you have to touch the channel that is already playing to get to the tuning screen. Doesn't make a lot of sense, but mystery solved. LOL.
  14. Dec 19, 2023 at 5:23 PM
    _multirotor_pilot
    _multirotor_pilot New Member
    Yes. That was completed when I picked up the truck
