Single switch two relays
Discussion in 'Lighting' started by icodeintx, Apr 25, 2023.
  1. Apr 25, 2023 at 7:08 PM
    icodeintx
    icodeintx [OP] New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    Is it safe to trigger 2 relays (light bars) with a single switch? I'm thinking since the switch and relay side is low volt/amp then it shouldn't be a problem.
    Thoughts?
  2. Apr 25, 2023 at 7:09 PM
    Safe
  3. Apr 25, 2023 at 10:20 PM
    blenton
    blenton New Member
    You can get a double pole single throw (DPST) switch. It has two circuits linked to a single switch.
    icodeintx[OP] likes this.
  4. May 14, 2023 at 10:34 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    100% safe to use either a DPST or SPST switch for simultaneously energizing coils on two separate relays.
    The #85/#86 pin relationship will not care how many others you’re playing with.
