Simple Camper
Discussion in '2nd Gen Tundras (2007-2013)' started by drobb, Feb 29, 2024.
  1. Feb 29, 2024 at 11:47 AM
    drobb
    drobb [OP] The Feral Snail
    2013 Tundra CrewMax 4x4
    IMG_5331.jpg Anyone running something like this, but on a CrewMax Tundra?
    Jeff_1974 and chugs like this.
  2. Feb 29, 2024 at 2:02 PM
    Optic15
    Optic15 New Member
    SF Bay Area
    2011 White Tundra SR5
    Level kit Morimoto XB headlights & fog lights LED light bar behind bumper KMC XD wheels 18” 34” Cooper Discoverer tires Pioneer double din head unit 10” subwoofer - x2 Back up camera trunk latch
    I have a regular bed cap/camper but for something like this I know 4wheelcampers has some pretty badass ones. They come at a STEEP price though
  3. Feb 29, 2024 at 2:18 PM
    drobb
    Ya, I am trying to go superrrrr simple, yet be strong enough for Baja.
  4. Mar 1, 2024 at 9:44 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Did you get the manufacturer of that camper?
  5. Mar 1, 2024 at 10:30 PM
    drobb
    It’s made by BelAir/ USA Campers in SoCal. I guess USA campers makes them for BelAir
    Cruiserpilot[QUOTED] likes this.
  6. Mar 1, 2024 at 10:34 PM
    What kind of amenities do you want? When you say Baja, I'm assuming just exploring low speed right?
  7. Mar 1, 2024 at 10:53 PM
    drobb
    Yep… low speed exploring. I have most things needed…. Portable stove, water containers, etc. Just want to set it up simple for 7-10 days.
  8. Mar 1, 2024 at 10:58 PM
    Well that sound like you will be livin the best life!! Sounds fun.
    I'm sure you have seen what slide in campers or GoFast campers have done to Tacoma's and Tundra truck beds. I would take that into consideration when purchasing.
    Have you considered a camping off-road trailer? Set it up once for the duration and come back every day?
  9. Mar 2, 2024 at 9:39 PM
    drobb
    I have been thinking something like GoFast. I see them down in Baja often…..might give them a closer look. We just got back from zigzagging Baja, 7 days…1800 miles round trip. You see just about every setup you can think of down there :)
  10. Mar 2, 2024 at 9:46 PM
  11. Mar 3, 2024 at 2:16 PM
    drobb
  12. Mar 3, 2024 at 3:43 PM
    Pretty spendy though....
  13. Mar 3, 2024 at 4:04 PM
    2mchfun
    Why not a trailer, trailer with basic shell on truck, trailer with shell, or even trailer and soft topper on truck, trailer, or both? Just curious.
  14. Mar 3, 2024 at 4:15 PM
    drobb
    IMG_5250.jpg Here’s my current setup. I would just like something with a little more headroom for when the weather is bad. A small trailer would be nice. But exploring can get a little tricky at times.
    ColoradoTJ, CaptRussia253 and 2mchfun like this.
  15. Mar 3, 2024 at 4:16 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Found them!! Bel Air Camper shells. Seem expensive but their prices are all very similar for every model. I've got an
    8' Tundra RC. This would make a wicked base for travelling/camping.
    Custom Camper Shells (belairshells.com)
  16. Mar 3, 2024 at 4:20 PM
    drobb
    Yep….. that’s the place!
  17. Mar 3, 2024 at 4:26 PM
    drobb
  18. Mar 3, 2024 at 4:40 PM
    2mchfun
    Aluminum camper shell companies such as ARE will build you a commercial custom high rise lightweight basic shell. From there, you can add windoors, side cabinets, full rear doors, roof vent/fan, etc. Then sell your current fiberglass to recover some of the cost. Mighty look at what @Wallygator has on his truck.
    Wallygator, Terndrerrr and drobb[OP] like this.
  19. Mar 3, 2024 at 6:21 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    The trick with all these ‘custom’ manufacturers is trying to keep the costs down to rationale level. I far more understand low cost rough camping more than high end luxury Overlanding extravagance.
  20. Mar 3, 2024 at 6:33 PM
    2mchfun
    Someone has got to keep the hamster wheels spinning or else we'll all be extra rough camping.
    Wallygator likes this.
  21. Mar 4, 2024 at 1:54 AM
    Canman
    Canman New Member
    2007 Crewmax Limited
    Have you considered a rack with a RTT? All this camping stuff seems to be priced way out of my budget. You can purchase used RV, trailer for the same price or less for some of these setups. I was looking into aluminum trays, until I saw the prices. Some were upwards of US$14K. Crazy!
  22. Mar 4, 2024 at 7:05 AM
    drobb
    I’ve looked at RTTs. Not really the way I would like to go. This setup would be for just simple guys trips and still be able to use my truck as a truck since it’s my daily. I do like the contractor truck shell idea. Need to look into the options available.
  23. Mar 4, 2024 at 7:20 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Wallygator and 2mchfun like this.
  24. Mar 4, 2024 at 7:33 AM
    2mchfun
    Search ARE WEDGE DCU, lots of images there. One big advantage is you have good resale value with what you currently have and what you would be getting. Good luck!
    Wallygator and drobb[QUOTED][OP] like this.
  25. Mar 4, 2024 at 7:44 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That's bad because??
    To stay on track, the aluminum ARE truck shells are really nice and lightweight. Lighter in weight than the same size fiberglass version
    and as stated above they retain their value far better. Aluminum is cold, so it would require insulation and vapour barrier for sure in
    colder climates. Fiberglass needs a spray attached inner insulation as well, it's just a bit easier to do and a bit cheaper. Either way
    drippy ceilings in cold weather suck! Ventilation is your friend always.
    I have used Maggiolina Extreme roof tent for almost 10 yrs, on my second New one now. Started second hand just to see. Many
    advantages with good quality roof tent ( iKamper, Tepui, Autohome ) is your sleeping area is isolated from all your other gear.
    Security in a roof tent is nice, 4 and 2 legged critters. I secure my ladder to my tent at night if I have worries about it walking off.
    My Tundra is a farm truck, I camp in a Land Cruiser so that's why my opinion. I am looking at comfort of camper shell or similar for the
    Tundra, i'm getting older.
    drobb[OP] likes this.
  26. Mar 4, 2024 at 7:50 AM
    drobb
  27. Mar 4, 2024 at 7:56 AM
    2mchfun
    Thanks for the post. Bought two 5.5' dual door on top of rail bed boxes that will begin to form my DIY camper and I have been debating the mounting orientation pros and cons. I like how this guy has the door open up and a table that then folds down. I hadn't seen or thought about that solution yet. Good stuff!
    CaptRussia253[QUOTED] likes this.
  28. Mar 4, 2024 at 8:07 AM
    drobb
  29. Mar 4, 2024 at 8:19 AM
    CaptRussia253
    Ruslan
    Check the second to last page with the single cab Tacoma. Exactly the setup I want eventually.
    drobb[QUOTED][OP] likes this.
  30. Mar 4, 2024 at 8:24 AM
    CaptRussia253
    Ruslan
