silver State transmission fluid
Discussion in '1st Gen Tundras (2000-2006)' started by Captain Andy, Aug 26, 2025 at 2:20 PM.
  1. Aug 26, 2025 at 2:20 PM
    Captain Andy
    Captain Andy [OP] New Member
    Tuesday
    2002 Tundra 90K miles pristene condition, new owner
    none
    Brand new owner of 2002 Tundra-not yet picked up. I arranged to have the transmission serviced and was told that they used Silver State full synthetic fluid. Is this compatible with Toyota's recommendation? I know it's a Colorado Petrolium product. Any thoughts pro or con?
    Thanks, Captain Andy
  2. Aug 26, 2025 at 2:28 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Check your owners manual, it'll say the type of transmission fluid to use. There were three types used across the first gens, and I can never remember which got what.
  3. Aug 26, 2025 at 2:46 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    The fluid TYPE is your focal point, not the brand. In your 2002, it must be DEXRON II or III
    Upshot Knothole likes this.
  4. Aug 26, 2025 at 3:02 PM
    Captain Andy
    Tuesday
    none
    Thanks, Black Mamba
    I'll check to see if what they used comports with dexron II or III. It probably does since they work almost exclusively with Toyotas. And thanks for that list of fluids.
    The Black Mamba likes this.
  5. Aug 26, 2025 at 3:41 PM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    It can technically be any DEX fluid. All Dextron fluids are backwards compatible. You can always use a higher number, not a lower number. And don't buy into "universal" fluids that work with everything. 2000-2002 use Dex3 or higher, 2003-2004 use Type T-IV, and 2005-2006 use Type WS.
