Sierra 5.3 vs Tundra 5.7
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hoff, Mar 20, 2020.
  1. Mar 20, 2020 at 1:04 PM
    Hoff
    Hoff [OP] New Member
    2021 TRD OFF ROAD CREWMAX
    I Traded my 2017 Sierra for a 2020 Tundra off road. The Seirra had the 5.3. Both trucks equipped with 6 speed transmission. My question is this. The Tundra with larger engine and more horsepower on cruise control will shift down a gear on the same roads where the Seirra would stay in the 6th gear. The Tundra has only 300 miles on it maybe that’s a factor. Or is this a normal Trans Engine setup on the Toyota Tundra.
    Rica25 likes this.
  2. Mar 20, 2020 at 1:15 PM
    TXTundra2722
    2015 Black Tundra
    You're comparing apples to oranges here so I'm not really sure what you are asking.
  3. Mar 20, 2020 at 1:17 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon!
    Rica25 and Hoff[OP] like this.
  4. Mar 20, 2020 at 1:19 PM
    Hoff
    My question is why is the Tundra with the bigger engine shifting down a gear when I think it shouldn’t. Is it normal or do I need to have it checked out.
    Rica25 likes this.
  5. Mar 20, 2020 at 1:19 PM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    I traded my GMC sierra for a Tundra as well. The GMC is designed around fuel economy so the shift points are different. The sierra also comes with a 3.08 rear end..Two different animals.
  6. Mar 20, 2020 at 1:21 PM
    MatthewPTguy
    Eugene, Oregon
    I’d say it normal.. mine does the same on steeper inclines...
    59nascar and Rica25 like this.
  7. Mar 20, 2020 at 1:22 PM
    Hoff
    I believe my Seirra had the 3.42.
    Rica25 likes this.
  8. Mar 20, 2020 at 1:43 PM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    Even still, your/our Tundra’s are geared way lower than even 3.42. I believe all the off-roads are 4.30.
  9. Mar 20, 2020 at 2:16 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Different shift tables.
    59nascar likes this.
  10. Mar 20, 2020 at 2:21 PM
    HappyTraveller
    HappyTraveller New Member
    Smalltown, Virginia
    02 Tacoma-13 4Runner-19 Crew
    Differential gear ratio.
    Mickeydog and Rica25 like this.
  11. Mar 20, 2020 at 2:21 PM
    Totally normal. The tundra is designed around work performance first, fuel economy secondary.
    Legit question.
  12. Mar 20, 2020 at 8:24 PM
    Newm
    Newm New Member
    KC
    You mention while using cruise control. That might be the bigger factor than gear ratios or horsepower and torque figures. I would guess that it's more a result of Toyota's aggressive/delay throttle in coming to an incline.
    59nascar, Hoff[OP] and ColoradoTJ like this.
  13. Mar 20, 2020 at 9:09 PM
    TomyTun
    TomyTun New Member
    CA
    None
    Very good point with CC. Every Toyota I’ve owned in the last 5+ being 3 Camry’s for work and 1 Tundra for personal use all do this. Take CC off when facing and incline or decline. Problem solved.
    Rica25 likes this.
  14. Mar 20, 2020 at 9:21 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    The Tundra transmission gyros. It helps brake with motor when going down hill. Once you hit the brake pedal it shifts to a lower gear. Very smart feature.
    Rica25 likes this.
  15. Mar 20, 2020 at 10:19 PM
    ND90
    ND90 New Member
    2019 Limited Off-road
    You have to remember they are both very different animals, gear ratio, transmission gearing, computers, etc
    Rica25 likes this.
  16. Mar 21, 2020 at 7:07 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    True indeed. They don't let you play engineer with the rear axle ratio...you get 3.91 w/4.6L, 4.10 with 5.7L, or 4.3 with 5.7L tow package. If you buy a used Tundra, you don't have to worry about getting stuck with an economy 3.08 axle in your work truck. Toyota makes the performance decisions; transmissions shift early maintaining power and torque, gas mileage sucks for simple daily transportation, but they do let you pick the color.
  17. Mar 21, 2020 at 7:17 AM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    Sounds like its totally jacked up to me. Make sure to stop and get some toilet paper on your way to the dealership.
    59nascar, Rica25 and texasrho83 like this.
  18. Mar 21, 2020 at 7:21 AM
    Hoff
    Why do you need some
    cheehab[QUOTED], Rica25 and Newm like this.
  19. Mar 21, 2020 at 7:27 AM
    Linuxmale
    Linuxmale 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    That’s completely normal. In every way the Tundra is set up for power, not efficiency. ( which is why I got one ) Try driving some of the new ten speeds, they lug their engines in the name of 2-3 mpg and can make the truck feel underpowered even though they aren’t.
  20. Mar 21, 2020 at 7:30 AM
    Hoff
    In a truck I really don’t want more speeds than six. Especially with a powerful V8.
    Rica25 likes this.
  21. Mar 21, 2020 at 7:38 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Mine did that. Annoying as fuck. Truck was fine, but give it the world's smallest incline and it'd drop to 4th. A supercharger fixed the problem.
    Hoff[OP] and Rica25 like this.
  22. Mar 21, 2020 at 8:30 AM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    A friend of mine had to rent a 2019 Ford f-150 2 wheel drive with the 5.0 and the 10 speed auto and it seemed to be hunting gears all the time.I live in a rural area in Tennessee and alot of hills.I went with him to pick up his Sequoia from the body shop.He has a 2005 Ford f150 with 150,000 miles that started knocking and is looking at getting another Ford .He know I'm a Toyota man and my 2000 tundra has 387,000 plus miles.
    Cpl_Punishment and Rica25 like this.
  23. Mar 21, 2020 at 8:33 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Tundra's 6-speed trannies are geared so high they essentially have 2 overdrives.
  24. Mar 21, 2020 at 8:42 AM
    Cavalrysr5
    Cavalrysr5 New Member
    Jared
    2020 tundra cavalry blue sr5
    Like others have said... They aren't trying to get the mpg so they don't lug it...
    Try driving a Tacoma and then come back it's horrible in hilly areas.
    Turning 2500 to 3k won't hurt a thing
    Hoff[OP], Tundra_361 and Rica25 like this.
  25. Mar 21, 2020 at 8:43 AM
    Ericsopa
    Ericsopa Old man and the sea
    Both 5th and 6th gears are overdrive gears, greater than 1:1. Also in play is an artificial intelligence factor that learns how you drive, as you drive. CC works hard to maintain the set speed, whereas you, while manually controlling the throttle, most likely will let the speed slip down a bit on a hill, either purposely or mindlessly. And actually, lugging the engine will not save you any in gas mileage, anyway, and may well reduce the engine's longevity.
  26. Mar 21, 2020 at 8:53 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I’m curious about your overall impressions of the Tundra vs the Sierra. I considered a Sierra before I bought my Tundra.
  27. Mar 21, 2020 at 9:05 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Some factors may be missing.... for example weather conditions, road conditions etc... I have experience with an 07 5.7 Tundra SR5 2wd and an 08 5.3 Sierra SLE 2wd and traveling through desert and higher terrain including climbing and descending from 5,000ft.. I can tell you they're both very different with wind speed resistance and how it impacts speed, the Tundra would downshift to maintain a certain speed or just over it, while the Sierra would wait much longer to compensate for the wind shift and resistance, but would cut acceleration just below the cruise speed. On steep climbs I've felt the Tundra sort of lunge itself forward more aggressively than the Sierra, I've found myself cutting off the cruise on certain sweeps vs the Sierra. Sierra appears more composed and calm, the Tundra seems more eager and full of energy. Suspension wise in that time I felt more tossed around in the Sierra than the Tundra...... Just my take on it.
    Hoff[OP], Rica25 and tttrdpro like this.
  28. Mar 21, 2020 at 10:06 AM
    soobaroo
    soobaroo New Member
    Gene
    2019 Tundra SR5
    It is completely normal. I had a truck with a manual and a Forester with a CVT so the downshifting on hills annoyed the hell out of me at first.
    Rica25 likes this.
  29. Mar 21, 2020 at 11:16 AM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    It's toyota's cruise control algorithm. That's the one thing I've dinged them on for years. Speed drops by 1 mph, downshift, speed goes over by 1 mph, upshift. My F150's could drop by 3-4 mph before a downshift It makes a huge difference in the total amount of shifting during cruise operation.
    Take off cruise and you'll see it won't shift nearly as much.
    DvilleMafia and Rica25 like this.
  30. Mar 21, 2020 at 11:56 AM
    Ardakota
    Ardakota New Member
    2020 Tundra TSS
    I too just traded a 2017 sierra 1500 5.3 3.42 yesterday for a 2020 tundra 5.7 4.30 two totally different feeling animals same trip from dealer 23 mpg on gmc 16 mpg on tundra but I knew that I bought mine for the power and thats what the tundra delivers where the gmc delivers MPG your not going to get both.
