Sieblers 01 AC Build
Discussion in '1st Gen Builds (2000-2006)' started by Siebler, Jan 11, 2021.
  1. Jan 11, 2021 at 10:28 PM
    Siebler
    Siebler [OP] Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Just a picture dump at moment. Got it pretty stock, shitty re-paint on the hood but overall well cared for.
    Currently have done (outside wear item replacements):
    Monstaliner
    King Coilovers /Camburg Arms
    285 75-16 Wrangler Duratrac's
    @SouthPaw Retro's
    DIY Rear Bumper
    DIY Sliders
    Vinyl Floor
    Coverking RhinoHide front/rear covers
    des2mtn, Bassetdad2, SouthPaw and 4 others like this.
  2. Jan 28, 2021 at 1:36 PM
    Siebler
    CJ
    Eastern Oregon
    Rear Bumper build
    Brackets and first tube
    Main hoop1
    Aligning hoops
    Both main hoops
    Deciding I liked bent verticals
    Mostly together
    Some plate
    Hitch tacked in
    TygerTundra, Voss and des2mtn like this.
  3. Jan 28, 2021 at 1:51 PM
    Siebler
    CJ
    Eastern Oregon
    Sliders
    Cut and positioned the 2" square inner. 87" length on these is where i landed.
    Bent up
    Test fit before full welds and plate
    Starting plate
  4. Sep 9, 2021 at 9:43 PM
    Siebler
    CJ
    Eastern Oregon
    Vinyl floor and Coverking RhinoHides
    des2mtn and FrenchToasty like this.
  5. Sep 13, 2021 at 11:08 PM
    TygerTundra
    TygerTundra New Member
    '07 Limited DC
    Do you have pictures of your bare floor, before you put the vinyl in by chance?
  6. Sep 14, 2021 at 5:17 AM
    JustJake
    JustJake New Member
    2006 AC
    How does the vinyl floor fit? Any install tips to share?
    How do you like the CK Rhino hide covers?
  7. Sep 14, 2021 at 3:46 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Impressive fabrication. Would love to put a pair of sliders like that on my '06 DC.
  8. Sep 15, 2021 at 9:16 PM
    Siebler
    CJ
    Eastern Oregon
    Ill see what I can find, May have deleted what I had. Any specific thing your trying to figure? Its a lot like.my Taco floor which has been exposed for years so may be able.to help
  9. Sep 15, 2021 at 9:21 PM
    Siebler
    CJ
    Eastern Oregon
    It fits OK, not perfect but im.happy. Do it when hot out, i waited on mine but my buddies t100 last winter was a bitch because the vinyl is stiff.
    Also i trimmed wide around the front console even being careful because he also jacked his up there so really take time and trim at last possible moment. Im personally just gonna swap a Sequoia console to cover my mistake.
    Dont try to add sound deadener under seat mounts or try to bolt the seat through vinyl, didnt make these mistakes on this truck but have seen it before and I cross threaded front seat mounts on the Taco way back when I put in my Beard seats. Its not a fun/easy fix.
    On the CK.covers they are pretty cool, at 20% off i justified but full pop was too much for me. Fit is good but not as custom as people make them out (having had custom covers before). The material is awesome and makes my seats feel more plush so id say worth it. I removed the rear seats for install and Id remove for the Floor as well to make easier if I did again (didnt realize how easy it was or how much it would have helped).
    JustJake[QUOTED] likes this.
  10. Sep 15, 2021 at 9:34 PM
    Siebler
    CJ
    Eastern Oregon
    Appreciate it, I just realized I hadnt updated the pics with the dimpled plate and all so did that. Unfortunately im just finally getting around to actually installing almost a year later because lifes been busy.
  11. Sep 17, 2021 at 3:11 AM
    TygerTundra
    '07 Limited DC
    Had seen a product called Lizard Skin in a lot of Jeeps that I had considered replacing my carpet with awhile back (like Rhino Liner but for the interior). Haven't been able to find any good pictures of a Tundra with the carpet removed to get an idea of what it would look like though.
  12. Sep 17, 2021 at 9:09 AM
    Siebler
    CJ
    Eastern Oregon
    I wouldnt do it and I have a Monstalined exterior... love the stuff but at 200.00 the Vinyl/carpet is way easier and covers things liner wont like sheetmetal gaps on the rear seat platform. These trucks are far from being a tub like a Jeep.
    TygerTundra[QUOTED] likes this.
  13. Sep 19, 2021 at 3:23 AM
    TygerTundra
    '07 Limited DC
    Thanks. I had a feeling that was going to be the case.
    On another note, how are you liking your Monstaliner, and how is it holding up? Paint is way down on my list of things to do, but I've been thinking about a textured exterior myself. Seems finding someone to apply it correctly is key, which I'd be worried about in my area. Would love to do the LineX, but the cost is so much higher it's hard to justify.
  14. Sep 21, 2021 at 8:29 AM
    JustJake
    JustJake New Member
    2006 AC
    Did you have to use a heat gun to stretch it any? My back corner looks bad.
  15. Sep 21, 2021 at 9:10 AM
    Siebler
    CJ
    Eastern Oregon
    I didnt but I did wait for a 95+degree day to do it after having done my buddies t100 in middle of winter. That corner looked.like.it was gonna be bad for me too until it got hot in sun. Had the heat gun ready but never used
  16. Sep 21, 2021 at 10:07 AM
    JustJake
    JustJake New Member
    2006 AC
    Thanks. I'm going to let it sit for a few days before I try to shape it with heat.
    Besides the 2 rear corners, I'm pleased with how the vinyl turned out.
    Siebler[QUOTED][OP] likes this.
  17. Dec 1, 2021 at 10:52 AM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    That flooring beats any floor mats lol. Great work
    Siebler[OP] likes this.
