Side Mirror Replacement
Discussion in '3rd Gen Tundras (2022+)' started by Eric_1980, May 25, 2023.
  1. May 25, 2023 at 7:48 PM
    Eric_1980
    Eric_1980 [OP] New Member
    I broke the glass on the drivers side mirror. Anyone know if the glass can be replaced or if I'll have to replace the entire assembly?
  2. May 25, 2023 at 7:55 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    On the older gens it was pretty easy to swap glass... You just put a sturdy flat blade item (hard plastic if possible) under the glass, between the glass and the housing, and pry straight up. The glass would then come right out. Not sure if your gen would be the same, but here is a video showing how the glass is removed and re-mounted.
    https://youtu.be/OhKT3rYwIwA
  3. May 25, 2023 at 8:18 PM
    99ways2die
    99ways2die New Member
    I've taken mine off while installing puddle lights; the mirror glass comes right off, like in the previous gens...even easier I'd say.
  4. May 25, 2023 at 8:22 PM
    Eric_1980
  5. May 25, 2023 at 9:23 PM
    99ways2die
    RE: video posted.
    That's one quick way of shattering the mirror - use metal to prop/force mirror off at your own risk...I simply pulled it straight off with my fingers (apply as even pressure all around as you can).
    (look up more/other vids for removal procedure)
  6. Jun 28, 2023 at 7:28 PM
    Eric_1980
    So the replacement was super easy but removing the old mirror is different than in previous generations. You need to slide a flat head screwdriver behind the mirror from the bottom edge (there's a little channel) and it pops right off. Then just disconnect the wires for the heater/BSM, reconnect to the new mirror and pop it on.
    Mattedfred likes this.
  7. Jun 28, 2023 at 11:09 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Q? (never thought about it) Where is the sensor for the BSM? On the back of the mirror glass?
  8. Jul 16, 2023 at 6:06 AM
    Eric_1980
    I'm not sure where the sensor is. The warning light is built into the mirror glass and the connector is on the back side.
  9. Jul 16, 2023 at 12:02 PM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Sensor is back behind the rear fender of the vehicle. It is not part of the mirror.
  10. Jul 31, 2023 at 6:55 AM
    mikeyp128
    mikeyp128 New Member
    Michael
    2023 Toyota Tundra 1794 TRD
    Do you recall how the black and red wires re-connect to the replacement mirror (which wires goes to which terminal on the replacement glass)? It's not marked and I took mine off at night (it was hanging by the wires and didn't want to drive home with it hanging)
  11. Feb 29, 2024 at 3:42 PM
    NatetheGreat
    NatetheGreat New Member
    Eric_1980 would you be able to elaborate a little on how you popped it out with the channel? I have tried pushing gently and prying within the channel and the mirror does not seem to want to release.
  12. Mar 3, 2024 at 4:25 PM
    Eric_1980
    Sorry for the super slow reply. I don't. I also disconnected mine without marking them I guessed and it worked. I wonder if it works either way.
  13. Mar 3, 2024 at 4:27 PM
    Eric_1980
    Honestly I can't remember exactly, but I do recall it being really straightforward.
  14. Mar 23, 2024 at 7:06 PM
    Pmcseq
    Pmcseq New Member
    2008 Sequoia
    Have you had any luck? Mine is on so tight, when I pry it upward it looks like the bottom plastic of the whole side mirror enclosure is going to snap.
