Side charging AR?
Discussion in 'Guns & Hunting' started by Chuck1188, Dec 6, 2021.
  1. Dec 6, 2021 at 6:29 PM
    Chuck1188
    Chuck1188 [OP] New Member
    Charles
    2016 TUNDRA BLACK SR5 CM 4WD
    Anyone do a side charging AR pistol?
    Looking for some feedback…pros/cons etc.
    Any recommendations on dealers?
  2. Dec 6, 2021 at 7:53 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Not a pistol, but I put together a side charging 7.62x39 for my dad. Used a PSA AngryJoe-14 lower and a Bear Creek upper. They didn't use shims (edit- between the barrel nut and shoulder on the barrel) when they assembled it, so the barrel was loose even with the nut tight. After adding shims and cleaning it up a bit, it has run very well.
    I plan to get one of their left side charge uppers to build a straight pull bolt action.
    Chuck1188[OP] likes this.
  3. Dec 6, 2021 at 7:57 PM
    Chuck1188
    Charles
    Ive heard of bear creek. Recommended by a buddy of mine. Pretty good prices from my little research
  4. Dec 6, 2021 at 8:03 PM
    Windsor
    Homeless in Oregon
    Some.
    Prices are decent if they have it in stock.
    Just be sure to go over it before using, or you'll end up like me, wondering why it can't hit a 12x12 piece of paper at 100m. I will say that their customer service is pretty good. Had a set of shims en route to me the day after I contacted them about the issue at no charge.
  5. Jan 4, 2022 at 10:14 AM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    Friends don’t let friends buy ANYTHING from Bear Creek Arsenal. Absolutely no quality control and parts with tolerances all over the place. Most of them are barely even safe to operate.
    You really shouldn’t shim a barrel to an upper. I highly recommend finding a better set of parts to assemble the upper. If you need help, you can PM me and I can help you find better stuff that still remains at a decent price.
    JimBeam, kittyhawk and alb1k like this.
  6. Jan 4, 2022 at 6:38 PM
    Windsor
    Homeless in Oregon
    Some.
    I'm actually ordering two more next payday. One that I will turn to a straight pull bolt action, one that will end up a SBR.
  7. Jan 4, 2022 at 7:28 PM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    What the heck are the shims for. If the barrel did not fit the upper receiver then one or both are Way out of spec. A good upper and a barrel with a milspec barrel extension shouldn’t need Shims, besides that could cause some head spacing issues.
    There’s a guy on YouTube Kotaboy32, he runs a bore scope through a BCA barrel and it was fracking horrible, it looked like it was finished with a couple of rocks by a one eyed monkey.
    Hurricane likes this.
  8. Jan 4, 2022 at 7:44 PM
    Windsor
    Homeless in Oregon
    Some.
    The fit of the barrel into the upper is not the problem. The problem is the barrel nut for the free floating handguard is cut too deep. Same alignment shims used by Aero to clock the barrel nut to get proper torque while aligning the gas tube with the holes.
    The shims go between the barrel nut and the shoulder on the barrel, NOT between the barrel and the upper.
    kittyhawk likes this.
  9. Jan 4, 2022 at 7:50 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Check out cbc industries……see if they have what you’re looking for. I believe it’s a veteran owned company that employs veterans. I built mine with their parts and was very impressed with the quality and fit and finish. Very fairly priced and really good customer service.
  10. Jan 4, 2022 at 7:58 PM
    kittyhawk
    Dave
    Ok I was thinking you were talking about the barrel not fitting not the handguard.
  11. Jan 4, 2022 at 8:10 PM
    Windsor
    Homeless in Oregon
    Some.
    My apologies for not clarifying that in the initial post. It is 100% an issue with the barrel nut and NOT a spec issue with either the upper or the barrel itself.
    kittyhawk[QUOTED] likes this.
  12. Jan 4, 2022 at 8:17 PM
    kittyhawk
    Dave
    Copy that, glad you got it all worked out.
  13. Jan 10, 2022 at 3:21 PM
    JimBeam
    JimBeam Moderator Staff Member
    South Carolina
    2015 Limited
    The inherent risks that comes with buying cheaply made parts just ain't worth it to me to save a few bucks
    I'd save awhile longer and buy something from a quality manufacturer
    Hurricane and KK6PD like this.
