Shuttering under heavy braking
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pudge, Aug 17, 2019.
  1. Aug 17, 2019 at 5:31 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    The last couple months I have noticed that once my brakes are warmed up, (after a new stops) that there is a good bit if shaking. I mean the steering wheel and seats shaking. Not just under heavy braking but slower stops as well. To me that has always meant my rotars are warped. But it doesn't happen the first few stops. I guess the rotars could deform as they heat up. Is there a recall or TSB for this? I have the platinum warranty so if so it should be covered. Anyone else have this issue.
    I will say that I have not pulled the wheels off or inspected my pads. I have 38k miles on the truck, mostly short drives, very little towing.
    mambo143 likes this.
  2. Aug 17, 2019 at 8:57 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Watch this video. It is about wheel spacers, wheels and rotors. The guy goes into great detail on things that cause wheel and brake vibrations. The only thing I would add to this person‘s video would be to torque the wheels off the ground at 30 foot pounds like he says, place the wheels on the ground and increase by 25 foot pounds. Roll the truck back-and-forth, repeat until the correct torque spec is reached. Clean mounting surfaces on the rotors, hubs, wheels and proper wheel torque is a must.
    Have fun out there and drive safe
    mambo143 and Pudge[OP] like this.
  3. Aug 17, 2019 at 9:05 PM
    Pudge
    CT
    Thanks, I didn't even think to check the lugs, I did a rotation about 3k miles ago and retorqued after 500 or so miles. I still can't get my mind away from my rotars being warped though.
  4. Aug 17, 2019 at 9:26 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    My truck does the exact same thing.
    I had the rotors turned at Oriellys and it calmed it down for a few days. After that the symptoms came back just like before.
    I plan on replacing the rotors and pads soon. Sucks too cause the pads have tons of life left in them which is why I haven’t put it as a high priority thing.
  5. Aug 17, 2019 at 9:26 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    After reading your comments, I can see that adding a wheel spacer between the rotor and rim doubles the mounting surfaces that must be perfectly mated. This torquing process sounds like it’s designed to reduce the possibility.
    If there were, even a minor imperfection, cause by uneven mating surfaces or, say different torque on one part of the mating surfaces vs another, this might not show up under low stress conditions, but with heavy braking, that much more tension is placed upon the mated surfaces. This could cause a bit flex and movement, that could feel like a shimmy.
    the Most common cause would be the rotors, but this could cause movement as well.
    I just replaced my brakes and rotors and mated new wheel spacers to new rotors for that reason and so far don't have that issue, but this conversation reminds me me its time to check the lug nuts.
  6. Aug 18, 2019 at 2:45 AM
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    Mine is a 2018 with 13K and I just started noticing it on mine as well. Thought maybe it was just my luck with the rotors, but appears to be something else. I'll check my lugs, just in case.
  7. Aug 18, 2019 at 4:55 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    (1) Inspect and clean all mounting surfaces. It may be necessary to remove rotors to inspect hub surface to be absolutely sure, but I would try step (2) below before removing rotors.
    (2) Torque wheel lug nuts to specified torque in two to three steps in a "star" pattern using a quality torque wrench. Unlikely you need to follow the full technique of the video unless you have spacers, but the first torque step should be with the wheel OFF the ground (insures best chance at "centering" the lug nuts).
    (3) If you still have shudder, you will probably have to replace rotors. Unless the surface is extremely rough, turning is typically a waste of money. Turning removes material from the rotor making warping more likely when the casting design is "light". Shops do it to increase the bill and guarantee best result on brake job. Brake pads quickly conform to mild phonograph surface.
    Rex Kramer likes this.
  8. Aug 18, 2019 at 6:26 AM
    KFed
    KFed New Member
    East Tennessee
    2018 Tundra Crewmax TRD Sport
    Tinted windows, Black badge overlays, ProZ hard bed cover, 32" grille light, 30" lower bumper light,...
    Funny seeing this thread show up. I just picked up my truck from the body shop after 6 weeks of it being repaired. Had to make a hard stop and thought the wheels were falling off. Such a violent vibration throughout the whole truck, steering wheel etc. I will check the lug torque specs. I only have 25k on the clock and the vibration is random. Wasn't there before sitting at body shop.
  9. Aug 18, 2019 at 10:15 AM
    JohnLakeman
    Toyota's seem prone to rotor warping imo. It never was a problem on my 86 4Runner, but that was before the days of fleet fuel efficiency.
    I first observed rotor warping on my wife's new 97 Avalon. After demonstrating how her anti-lock brakes worked, mild shudder was observed afterward. Stupidly ironic, but I concluded that hard braking in that instance was the cause. Maybe the guys at the body shop drove your truck like they stole it? :facepalm:
    Turning the front rotors did successfully cure the problem on the Avalon. Warped rotors are such a common complaint with Tundras, I would try torquing the lug nuts and save the cash instead of rotor turning, but that's just me.
  10. Aug 18, 2019 at 1:33 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    DUDE! If this is on an insurance claim for repair I would recommend going back and telling them!
    If they are at all reputable they will contact your insurance and have it sent somewhere to diagnose and/or replace the brakes. They'll probably want to replace the rotors only but I would show up with some new OE pads and have them put on at the same time.
    Remember, after a collision the repair is done to return the truck back to pre collision state.
  11. Aug 18, 2019 at 2:22 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    My wife's Lexus RX 350 does the same thing.smooth until you get the brakes hot then shake you to pieces. I'm going to turn the rotors and see how long it takes to warp again.
    Pudge[OP] likes this.
  12. Aug 27, 2019 at 12:16 PM
    megatundavid
    megatundavid New Member
    David
    Norcal
    2014 Tundra crewmax 4x4
    Magnusen supercharger and Bullydog tuner TRD PRO Grille with ENVE Grill insert. ICI Magnum front bumper with LED driving lights Radium Engineering dual catch cans 2018 factory LED headlights Firestone airbags with in cab controller Banks catback exhaust system Baer Brakes front drilled and slotted brake rotors All seats have had seat covers most of their lives Ready Lift 6" suspension lift 18" KMC wheels with 35" Cooper STT PRO's AMP Research power side steps Spray in bed liner IPT modified valve body for transmission Factory tow mirrors Light tint on front windows Hypertech speedometer calibrator. Husky floor liners.
    Pretty common tho mostly on the 1st gens. Toyota has seemingly underbraked most of their trucks anyways. Going to 4 wheel disc has helped immensly. I had it start on my 14 after towing and having to panic stop. I got Baer drilled and slotted rotors for mine and have had no issues since
