Shut off bluetooth question
Discussion in '3rd Gen Tundras (2022+)' started by MarkO, Sep 20, 2022.
  1. Sep 20, 2022 at 10:43 AM
    MarkO
    MarkO [OP] New Member
    Mark
    '19 Limited TRD
    Is there a way to shut off bluetooth? My '22 commandeers my phone's bluetooth but unfortunately I need my phone's bluetooth connection to run my survey equipment. Vary annoying.
  2. Sep 20, 2022 at 11:06 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    If I am understanding this correctly, you should be able to remove your Tundra from the list of Bluetooth devices on your phone.
  3. Sep 20, 2022 at 5:27 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    If you need phone paired to survey equipment while truck is running, disconnect phone in Multimedia system under blue-tooth, you can always reconnect when you need it.
  4. Sep 20, 2022 at 7:06 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    The Bluetooth only gets slaved to the truck to enable wireless CarPlay (uses both WiFi and Bluetooth due to amount of data being transferred).
    So you can disable it on the screen and run your survey equipment then reconnect when needed
