Show your Tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by G-manCO, Nov 13, 2017.
  1. Nov 13, 2017 at 6:52 PM
    G-manCO
    G-manCO [OP] New Member
    Geoff
    Erie, CO
    '17 TRD Pro CMT
    I am looking to add a hard folding tonneau bed cover to my truck and wondering if any out there use the factory rail system? Any bakflip mx4 or gator fx5 users? What do you like about your covers?
    Thanks for the help.
    Zico and TLH13 like this.
  2. Nov 13, 2017 at 7:15 PM
    Borgs
    Borgs New Member
    PA
    I have MX4. Not thrilled. Leaks, dents easily on bed side, and rivets are rusting already (got it in May). Dropping the rails and the low profile also make it impossible to install the awesome Voo Doo bed racks, or similar designs from other vendors. I should have gone with Extang.
    TLH13 and Sunnier like this.
  3. Nov 13, 2017 at 7:23 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I have the Bak revolver x2, so far so good ,been 3 months
    Rica25 and jpfleming like this.
  4. Nov 13, 2017 at 7:34 PM
    BayRunner
    2017 Tundra Platinum
    I use the Rugged Hard Liner II. It's a tri-fold liner and doesn't get much simpler. Installed out of the box in 10 minutes. It can come on and off in minutes and keeps the water out. I've been very pleased with it. Also, since it sites on top of the bed/tailgate, no mods to the rail system is required. Built in LED lights that are battery operated providing a little light when needed.
    al415, TLH13, diablodalton and 9 others like this.
  5. Nov 13, 2017 at 7:52 PM
    G-manCO
    Geoff
    Erie, CO
    '17 TRD Pro CMT
    With the Bak, x2 did you have to remove the factory rail system? Can you remove the whole cover quickly if needed?
    TLH13 likes this.
  6. Nov 13, 2017 at 7:53 PM
    G-manCO
    Geoff
    Erie, CO
    '17 TRD Pro CMT
    Thank you for sharing your experience! Definitely going to look at the extang now.
    Steelerjax likes this.
  7. Nov 13, 2017 at 8:18 PM
    Borgs
    Borgs New Member
    PA
    Or this one...
  8. Nov 13, 2017 at 11:05 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    It was a different brand name when I bought it, but I think its now called the Retrax Powertrax PRO MX
    Low profile, electric, comes with two remotes, locks in any position. Its a great cover.
  9. Nov 13, 2017 at 11:52 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    Roll-N-Lock. Powder coated aluminum roll up tonneau. Had a few drops of water make it in by the tailgate after running it through the car wash. Besides that, no issues at all.20171114_003915.jpg 20171114_004132.jpg 20171114_004059.jpg
  10. Nov 14, 2017 at 6:12 AM
    froggy78
    froggy78 Loco Moco Bastrd
    JP
    SF Bay Area
    1794 TRD
    I have the MX4. I did not buy the drop down brackets, but, I did find similar enough brackets at home depot for about a dollar. I did try that one I bought and it will work to drop the factory rail system down. I have had it since last summer. I never noticed any leaks and if it does it is very little. This is my first bed cover so i don't have anything to compare it to. I can snatch it off in about 10 mins or less.
  11. Nov 14, 2017 at 6:37 AM
    Sooner77
    Sooner77 New Member
    Todd
    Tulsa, OK
    2017 Cement TRD PRO
    Predator Pro Step Bar, BackFlip MX4, XPEL Paint Protection Film, Husky X-ACT
    I have the MX4, love the look and function of these covers but I wouldn't do it again. Very slight tiny size hail storm beat the crap out of the panels, other parts are looking worn, and the drop deck rails cause problems with other attachments.
    TLH13, equin, dooododoo and 2 others like this.
  12. Nov 14, 2017 at 6:51 AM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    I have the Extang solid fold 2 and I really like it. It uses the factory bed rail system and you can still move/access the tie downs. It keeps things dry, I just have a small leak around the tailgate (but that’s not the cover). It would be very difficult to dent the material it is made from. It does sit above the bed, so some people might not like that look. I don’t mind it, the extra inch in the back almost adds to the the bulldog like stance of the truck!
  13. Nov 14, 2017 at 7:11 AM
    Borgs
    Borgs New Member
    PA
    Agreed on all fronts. While I haven't had any damage on the top of the cover yet, I have several dents/impressions on the inside surface of the cover. Really a weak material. As a whole, I have the cover only a few months, but it already looks as if it's been on the truck years. Rusting, fading, and the rubber is really worn despite using AERO 303 a lot. I am not looking forward to what it will look like a year from now.
    TLH13, Rica25 and Sunnier like this.
  14. Nov 15, 2017 at 11:24 AM
    G-manCO
    Geoff
    Erie, CO
    '17 TRD Pro CMT
    Anyone have the Extang Encore Tonno?
  15. Nov 15, 2017 at 9:46 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Interested in this. Do you have a pic? From what little I've seen of the Bakflip brackets, they just look like a rectangular piece of metal with 2 holes in them. The difference in price to add these is $100. Seems like one could make something work just as well but much cheaper.
    edit: price difference is $50, still seems to high for those brackets.
    TLH13 likes this.
  16. Nov 15, 2017 at 10:08 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    i have this same one and for the money it's hard to beat. I think i paid under $600
    TLH13 likes this.
  17. Nov 15, 2017 at 10:52 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I've got some generic Amazon special I picked up new for 60 dollars. Then I cut if to fit my toolbox. I'll eventually get around to putting a less saggy one in. As mine has stretched alot since putting it on last year. But I do open and close my cover several times a day. Probably more than anyone should with a cheap cover. It's far from water proof. But it keeps things hidden from prying eyes. And snow stops that great MN snow. Oh and when it rains I can measure how much it rained with how big of a puddle I've got on the the middle of my cover lol.
    TLH13 and MooneyMadness like this.
  18. Nov 16, 2017 at 2:31 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I have this one and agree. I get a little water through the tailgate when washing , just waiting until warmer weather to apply a tailgate seal. I agree it would take a heck of an impact to dent.
    TLH13 and G-manCO[OP] like this.
  19. Nov 16, 2017 at 7:35 AM
    froggy78
    JP
    SF Bay Area
    1794 TRD
    Yep, just bring one of the bolts with you to HD or Lowes and you will see.
    TLH13 likes this.
  20. Nov 16, 2017 at 7:38 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I have one of those and will be looking to get rid of it soon.... I'm less than impressed.
    TLH13 likes this.
  21. Nov 16, 2017 at 9:13 AM
    Borgs
    Borgs New Member
    PA
    You have a BakFlip, or the Rugged?
    klc123 and Rica25 like this.
  22. Nov 16, 2017 at 9:23 AM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    If money isn't an issue I recommend Diamondback covers. It would take a meteor to dent it.
  23. Nov 16, 2017 at 10:06 AM
    Ely010606
    SPARKS, NV
    Yes i did, you can remove it fairly quickly once you have installed it, would go out pretty quickly , heres a picture of how far down it will go.
    TLH13, equin, K6BRY and 3 others like this.
  24. Nov 16, 2017 at 10:07 AM
    Sunnier
    Sunny
    San Diego, CA
    Tom, why don't you like the Rugged Hardliner II?
    TLH13 likes this.
  25. Nov 16, 2017 at 10:17 AM
    Sunnier
    Sunny
    San Diego, CA
    Thanks to those of you that posted negative reviews of the M4, I've decided to knock that one off my list.
    I'm down to comparing Extang and Roll-N-Lock.
    The vendor's YouTube videos make the Roll-N-Lock look pretty bad-ass at theft protection. But some of the on-line reviews from purchasers mention leaking. I've figured out there's a gap built inside at both corners of the Tundra tail-gate, so maybe this isn't to do with the protection of the cover.
    I'm hoping for more info from members that have had either of these installed for more than a year. Security on the Entanglement EnCore and weather protection on the Roll-N-Lock are my question. Thanks in advance!
    TLH13 likes this.
  26. Nov 16, 2017 at 10:41 AM
    tomsinamerica
    Tom
    Wilmington, NC
    it's super flimsy, it's a pain in the ass to fold back as you have to collapse the hold downs, trifolds generally suck as you lose 1/3rd of the bed above the rail.
    On top of that, mine is de-laminating, it leaks like a sieve... i think that's about it for now. I mean, if i picked one up for $100 or so then it's a good deal, but there are WAY better options for not that much extra money. When i replace mine, i'll be giving this one away, i'd feel guilty asking for money for it.
    G-manCO[OP] and Sunnier like this.
  27. Nov 16, 2017 at 10:42 AM
    tomsinamerica
    Tom
    Wilmington, NC
    Rugged...
    Borgs[QUOTED] likes this.
  28. Nov 16, 2017 at 10:45 AM
    Sunnier
    Sunny
    San Diego, CA
    G-manCO[OP] likes this.
  29. Nov 16, 2017 at 4:32 PM
    Tundra Fan
    Toby
    It would be easy if I knew the dimensions of the bracket. Does anyone have them that could give me the length, width, metal thickness, and measurement of holes?
  30. Nov 16, 2017 at 8:24 PM
    multimile
    multimile New Member
    2020 Crewmax Cement
    Extang Solid Fold 2.0, still able to use the factory rail system because it sits on top of the bed. Doesn’t have that flush look like other covers, but overall happy with the appearance. Have only had it on a couple days, so the verdict is still out on long term satisfaction.
