Show us your c.b./ham radio install
Discussion in '2.5 Gen Tundras (2014-2021)' started by parallax, Jul 8, 2018.
  1. Jul 8, 2018 at 8:03 AM
    parallax
    parallax [OP] Professional Zamboni stunt driver
    Oregon
    2018 White Tundra Crewmax SR5 5.7 TRD 4x4
    Dash camera
    Hey friends, looking for pics of c.b. or ham radio installs on 2014+ tundra's,,, trying to figure out where i can put a VHF transceiver while doing minimal damage. since most y'all are smarter than me, i know i will be amazed at your ideas.
    Zero One Actual and Rider0120 like this.
  2. Aug 15, 2018 at 4:54 PM
    vader7071
    vader7071 New Member
    Dothan, AL
    2018 SR5
    I've got a 2018 I am wondering the same thing. I am trying to figure out how to install my HF and quad band rigs.
  3. Aug 15, 2018 at 6:06 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Almost went full install but opted for something easier. Does ok. Not really a cb nut or anything. Usually take with me on long trips or camping
  4. Aug 15, 2018 at 6:42 PM
    COTundraRoamer
    COTundraRoamer New Member
    Dustin
    Denver, CO
    18' Platinum CM
    Fox 2.5 DSC front, Fox 2.5 DSC rear. JBA UCA. SCS Ray10 custom powder coated on 285/75r18 Duratracs.
    Same here. Doing this soon and leaning towards a Stryker unit because of its size. Curious to see what others have done.
    parallax[OP] likes this.
  5. Aug 15, 2018 at 7:57 PM
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    Icom IC-7000 & Yaesu FTM-400XDR
    Midland MXT-400 GMRS
    All the antennas - going to change...
  6. Aug 15, 2018 at 9:04 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    This is a great thread. I have racking my brain for ideas on how to mount a radio.
    I found this guy on instagram, deserteunner_s, and he makes this mount/cover. I freaking love how it looks and it puts the radio on what I would consider wasted space. Guy said he can make them for race radios or any other single din radio. Is asking $350 though, with leather and matching stitching, just haven’t been able to justify it yet.
  7. Aug 17, 2018 at 12:17 PM
    vader7071
    Dothan, AL
    2018 SR5
    Wow, $350? Looks good, but turns the housing into a heat box for your rig. Great for aesthetics, but I'd be worried about the added heat by using this
  8. Aug 17, 2018 at 3:39 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i'm going to be putting my yaesu FTM-400 in two spots. the brain is going to get mounted down in the cavern of the center console with some holes cut out for the fans so it can vent. the faceplate is going to go up on the headliner console. i'll be popping out the panel with the map clip so i can retain the sunglass holder. i'll get the mic extension cable, run it down the a-pillar, across the dash then out at the same place i hardwired my midland cb which is near the cup holder in front of the shifter.
    currently researching some ways to replace the stock radio antenna with the cb antenna. i don't ever use the radio so it feels like a nice, clean mounting location. it's a massive PITA to go to though. found a guy who makes a mount for land cruisers and we traded a few emails. he doesn't think it's possible in a tundra which, of course, makes me want to do it more.
    debating on location for HAM antenna. had thought about drilling a hole in the roof for a nmo mount which would cause it to come up through the middle of the roof rack. not sure that's going to be ideal because of possible interference from the rack cross bars. input would be appreciated. so, i may mount it to the side of the rack like i did with my FJ but be smarter and use a motorized one.
    138thBatista and parallax[OP] like this.
  9. Aug 17, 2018 at 3:56 PM
    the_midwesterner
    Luis
    None, yet....
    Curious to see what you come up with. I’ve thought the same thing too, since the map holder is basically useless. I’m looking to run the Icom 5100A, which also has a remote faceplate. My concern is if you add weight, that map holder is only held in by small plastic clips, so I’m interested to see if they will hold the load.
    Have you see this for an antenna mount? It comes with the option of an NMO Mount pre-wired and installed. Not sure how I feel about drilling into the cab though. If you have a roof rack, that means you already drilled right?
    YotaMan, parallax[OP] and Black Wolf like this.
  10. Aug 17, 2018 at 4:13 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    in my FJ, i epoxied a chunk of 2x4 to the roof. i then mounted the faceplate mount to the 2x4 taking the load off the plastic and the headliner. i'll probably do something similar. i just need to take it apart and take a look.
    yes, the prinsu cab rack that's coming will require me to drill into the roof. i drilled the FJ's roof for the HAM antenna and never had a problem. silicone sealant and these bulkheads are my friends.
  11. Aug 19, 2018 at 1:26 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Sub’d
  12. Aug 19, 2018 at 4:48 AM
    Lars
    Lars
    Cedar Creek Texas
    This is under the passenger side rear seat. I plan on moving it to the back wall (where the lug wrench and bottle jack mount) now that I've done the rear seat fold down mod, I just need to cut a piece of 1/12 to go across the back wall, and attach it to the truck.
    Who makes this tail light? I want a pair of red S2 Sport LED Pods for brake lights. ;)
  13. Aug 19, 2018 at 7:15 AM
    the_midwesterner
    Luis
    None, yet....
    Evil offroad - Hyperlinked.
  14. Aug 19, 2018 at 5:15 PM
    Lars
    Lars
    Cedar Creek Texas
    There's no going back now! This year's crop has been good on the Antenna Farm.
    Please disregard the garage. We're getting ready to move.
  15. Aug 19, 2018 at 5:36 PM
    You can connect that transceiver to a mounted antenna too for longer reach. Pic'd is my Midland 75-785 hand held. I've got a CB mounted in my center storage console too.
  16. Sep 12, 2018 at 4:54 PM
    vader7071
    Dothan, AL
    2018 SR5
    Here is my antenna mounts. Still got to get parts for the radio install
    4x4_Angel and K6BRY like this.
  17. Sep 12, 2018 at 10:13 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I don't have it anymore, but I used to have a hand-held that I connected to a magnetic mount. Worked perfectly while on the trail.
  18. Sep 12, 2018 at 11:59 PM
    K6BRY
    K6BRY New Member
    2017 Black Tundra TRD 3/1 Lift Sittin' on 34s
    @vader7071 Where did you get those antenna rail mounts from?
  19. Sep 13, 2018 at 4:27 AM
    vader7071
    Dothan, AL
    2018 SR5
    MyFj08 likes this.
  20. Oct 1, 2018 at 1:30 PM
    Lars
    Lars
    Cedar Creek Texas
    I'm not sure common mode chokes work when they're not air wound... If that works though that's awesome!
  21. Oct 1, 2018 at 3:53 PM
    vader7071
    Dothan, AL
    2018 SR5
    Ckeckout Http://k0bg.com this guy has some SERIOUS knowledge when it comes to mobile installation. Plus I have seen that type of choke in many other places
  22. Oct 1, 2018 at 4:01 PM
    vader7071
    Dothan, AL
    2018 SR5
  23. Oct 1, 2018 at 5:19 PM
  24. Oct 1, 2018 at 5:30 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    That guys is one of the biggest mall crawler posers on IG. Full LT build and he never wheels it
    dcsleeper408 likes this.
  25. Oct 1, 2018 at 6:59 PM
    the_midwesterner
    Luis
    None, yet....
    Indeed he is. Also, long travel is only in the front. The rear is stock leaves and blocks I believe.
    Still a neat concept though. I like how it utilizes effectively useless space and flows into the dash well. Never been a fan one just bolting things onto dashes.
    zcarpenter92 and dcsleeper408 like this.
  26. Oct 22, 2018 at 10:28 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
  27. Oct 22, 2018 at 10:28 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    I WILL DO ANYJTHING FOR THAT SFIFT KNOB
  28. Oct 23, 2018 at 8:00 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Wow! I didn't know people were still into CB radios.I had one when I was a teen and had a blast with it.
  29. Oct 23, 2018 at 12:09 PM
    brayan975
    brayan975 El PINGU
    Brayan
    Miami
    2016 Black Tundra
    2 Inch Wheel spacers Red plastic dip emblem Red tailgate letters Rock Lights RGB pod lights Bull bar with LED bar
    @vader7071 WHO MADE UR SIDE VINYL ITS AWESOME??? [​IMG]
  30. Oct 23, 2018 at 2:17 PM
    SpeshulED
    In the last picture what mount are you using for that FireStik?
