Show Me Your Ditch Light Wiring
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dsptundra, Jan 15, 2022.
  1. Jan 15, 2022 at 10:34 AM
    Dsptundra
    Dsptundra [OP] Still a new member...
    Austin TX Area
    2021 Silver Limited CM
    Working on wiring up my ditch lights. Currently brackets and lights are bolted up and my Trigger Six Shooter is installed. Now I am trying to figure out the best way to route my lights wires across the firewall to the Six Shooter. Also looking at the best way to route the wire along the hood hinge.
    Anyone with some photos or recommendations from their installs they can share?
    pvn.beluga likes this.
  2. Jan 15, 2022 at 10:50 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I don't know how different the hoods are between 2nd and 2.5 gen but here's how I did mine. On the drivers side is power for my ditch lights, the light bar in the grill, and the engine bay lights all run to my relay system on top the fuse box just like yours. on the passenger side, I ran the wire for my front grille camera because I was getting some insane noise and feedback with the camera run along the power wires for my light bar. all the wires I fished through the internal structure of the hood to keep it looking pretty clean. I don't know how much that helps you :confused: but hopefully it does.
    Dsptundra[OP] likes this.
  3. Jan 15, 2022 at 10:55 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I’m not near my truck, but I ran the wires down next to the hood hinges, and popped off the felt piece and tucked the wire behind there all the way across. This piece:
    Dsptundra[OP] and AZBoatHauler like this.
  4. Jan 15, 2022 at 10:58 AM
    AZBoatHauler
    So.Arizona
    This is how I did mine as well.
  5. Jan 15, 2022 at 11:06 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Not the prettiest but functional. I have several wires that run across the top of my firewall so I put loom to keep things neat and less "straggly". My switch is a cheap one but gives my lights 10 different strobe patterns so I can use them as emergency flashers should the opportunity call for it.
    20220115_125528.jpg 20220115_125323.jpg 20220115_125315.jpg 20220115_125440.jpg
  6. Jan 15, 2022 at 3:51 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Exactly how mine is routed as well.
  7. Jan 15, 2022 at 5:04 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    First photo was when I installed the ditch lights, ran wire through firewall and had a dedicated switch.
    Second photo isn’t as clear to see how I ran my wires, but no more relays since I installed my Auxbeam switch panel. Hood bulge light bar, ditch lights, and lower bumper light bar are all ran into my terminal.
    Could get a better photo tomorrow.
  8. Jan 15, 2022 at 6:02 PM
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    No wiring help here, just curious about the Trigger system. How do you like the Trigger system? I’m thinking that’s the route I wanna go.
  9. Jan 15, 2022 at 6:40 PM
    biebs96
    PA
    can you elaborate on your inspection sticker? :rofl:
  10. Jan 15, 2022 at 6:48 PM
    AZBoatHauler
    So.Arizona
    Sure can. :D
    biebs96[QUOTED] likes this.
  11. Jan 16, 2022 at 9:40 AM
    Dsptundra
    Austin TX Area
    Haven’t really used it yet. These lights will be the first items connected. Sir far the app has been good and actual install was easy.
  12. Jan 16, 2022 at 12:00 PM
    Dsptundra
    Austin TX Area
    Thanks for the ideas all. Install is complete!
    I dropped the felt firewall thing and used gaffer tape to hold the wiring along the top of the firewall and then reinstalled the felt trim piece. Excess wire was zip tied near the battery for future adjustments.
    First time I have ever done wiring like this but with the shrinking crimp connectors and some additional shrink tubing is was pretty easy.
    JackWagon and pvn.beluga like this.
