shoulder wear on tires
Discussion in 'Wheels & Tires' started by scturndra, Jan 15, 2016.
  1. Jan 15, 2016 at 7:22 AM
    scturndra
    scturndra [OP] New Member
    wall
    2012 tundra extra cab sr5 4.6v8
    ok I have a 2012 tundra that rides on 255/70 R18, and I am getting a ton of shoulder wear. I have researched and found that year you could get the truck with 255 or 275. But the weight of the truck is whats causing the truck to ride on the shoulders of the tire. so the question is with all the tire options out there what should I go with to keep this from happening on the next set?
    I am no expert on tires but I do know its not right.
  2. Jan 15, 2016 at 7:33 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Your problem is not tires. It is out of alignment. Depending on which shoulder your talking about, it is either positive or negative camber. Go get yourself an alignment.
    Sefferston likes this.
  3. Jan 15, 2016 at 8:17 AM
    scturndra
    wall
    I have had 7 alignments. its the outside shoulder on both front tires. If you look at the tires you can see that the shoulders are sitting on the ground. The OEM tires only lasted 25k miles and these are looking to last maybe 35K(60K) tires.
    Btw Great season for yall.
  4. Jan 15, 2016 at 8:36 AM
    mdavis
    Michael
    Rock Hill, SC
    Do you have a lift? Have you gotten a printout of your alignment specs after? @jberry813 might be able to help you.
    It was a good season. Doesn't even matter that they lost in the end. Just proud they made it.
  5. Jan 15, 2016 at 8:40 AM
    scturndra
    wall
    I don't have a lift but am thinking about getting a leveling kit for the front. I have receved print outs after the alignments. To the untrained eye,they look spot on.
  6. Jan 15, 2016 at 8:55 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Outside or inside shoulder wear?
    When was the last alignment?
    Please post last alignment sheet.
  7. Jan 15, 2016 at 9:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Do you corner aggressively? From someone else's perspective....many people don't drive as aggressively as they think they do. lol And what tire pressure are they set to?
    MT Madman likes this.
  8. Jan 15, 2016 at 9:28 AM
    scturndra
    wall
    its the outside shoulder. The inside still looks new.
    last tire alignment was a couple weeks ago. I will have to upload the sheet on Monday.
    I am running 50 psi in the tire right now. Started off at 32 OEM spec and moved to 40 then to 50.
  9. Jan 15, 2016 at 9:33 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Outside edge wear can be from the following:
    Alignment out of spec (sounds like you can probably rule that out)
    Air pressure too low (but it usually effects inside too, and you say you're aired up)
    Aggressive cornering causing the tire to tuck/roll under in turns. I'm guessing this can be a good part of it, skinny tire on a heavy ass truck.
    Sefferston and jberry813 like this.
  10. Jan 15, 2016 at 9:40 AM
    Can the wear be caused from bad shocks too? @jberry813
  11. Jan 15, 2016 at 9:47 AM
    scturndra
    wall
    they are they oem shocks with only 50k miles on the truck.
  12. Jan 15, 2016 at 9:48 AM
    jberry813
    Lake Tahoe
    What this guy said! The last one is the culprit IMO. That and too many people are ignorant when it comes to IFS alignments and assume just because the alignment sheet is in the green, they are good to go. With IFS, you should ALWAYS have a little bit of negative camber (more if you live in the mountains or coasts with lots of twisties...or drive like an asshole. I'm at around -1.5*). And with RWD vehicles, you should ALWAYS have a tiny bit of toe in. Otherwise you can watch the outsides just melt off the tire.
    Meh. Most the time not, but with anything, depends on driving style. A blown shock will exacerbate whatever the real problem is though.
  13. Jan 15, 2016 at 10:06 AM
    scturndra
    wall
    Thank you for the information and I will get the alignment sheet posted on Monday. But if I wanted to go with a Wider tire what should I go with?
  14. Jan 15, 2016 at 11:55 AM
    15whtrd
    15whtrd Mr. Blonde
    If you don't need the rear end to articulate as much how about a rear sway bar? I know this helped out tremendously on my previous 2x truck.
  15. Jan 16, 2016 at 10:52 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    This^^^this will tell us everything we need to know.
  16. Jan 17, 2016 at 9:02 PM
    Slimjim
    Slimjim New Member
    Wayne
    2016 crewmax 1794 super white
    Food for thought, I had fords eating up outside of tires. I put michelin's on the truck, no newalignment and they wore perfect.
    Anyone running Michelin's?
  17. Feb 8, 2016 at 4:36 AM
    Clint
    Clint New Member
    2010 Tundra 4wd 5.7L
    N-fab steps
    Love asking the alignment shop to align to a certain spec and getting told there must be something wrong component wise if I have tire wear. So I said if you can't get the camber between 0 and negative 1 I can take it somewhere else....
  18. Feb 8, 2016 at 6:55 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    This may not be of any relevance but check your tire pressure. Aftermarket tires may require different pressure than what is printed on the inside of your door.
  19. Feb 8, 2016 at 8:30 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    You have tire wear indicating excessive positive camber. You have a computer printout indicating rainbows, unicorns and puppies. If you are getting it aligned at the same shop, you might consider trying a different one. Either that or specifically ask them to dial in some negative camber, assuming there is room left in the adjustment.
    Adding a lift will only make this worse with the stock UCAs.
    Eclipsed & Floating likes this.
  20. Feb 9, 2016 at 2:48 PM
    Clint
    Clint New Member
    N-fab steps
    This was my sheet I paid $74 for....
  21. Feb 9, 2016 at 10:07 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Expensive piece of paper
  22. Feb 10, 2016 at 7:07 PM
    Relentless
    Eric
    Ha, should have just checked it, saw in spec and gave the truck back at no charge.
  23. Feb 11, 2016 at 5:55 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Not sure about the newer stuff, but my 02 Tundra has always eaten front tires! Been checked 8 ways to Sunday and my best guess is the fact that I have a loaded truck, lots of windy roads, and up intil recently they would chip seal the roads which was sort of like driving on sandpaper. Decent tires seem to last about 35k regardless if they are P rated or LT's. If you are highway driving it and it is eating the tires I would suspect something is wrong, if like me, about 85% of the driving is non highway, that just seems to be the way it goes at least with the 1st gens.
  24. Feb 26, 2016 at 12:14 PM
    Clint
    Clint New Member
    N-fab steps
    So it's been 1000 miles since I put the new rims and tires on. I am getting the same old shoulder wear. I went back to the alignment shop that charged me $75 to tell me my alignment was fine and told them to fix it. After some argument they agreed to dial in some negative camber. When I went to pick it up, they said the factory specs for my new tires (275/65/18) had a wider band for negative camber. So they moved it. I am attaching my old and new alignment sheets. a940386acc53178f8d38e714b36fa6ea_f5dd60c8a7d674df1c86e21ebbec4ea578e485e2.jpg
  25. Feb 26, 2016 at 12:19 PM
    Clint
    Clint New Member
    N-fab steps
    Forgot to say they tried to charge me for another alignment. I told them I paid once and you didn't do what I asked, so why should I pay now. They no charged it.
  26. Feb 26, 2016 at 12:54 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Shit, as much money as you've given them, I'm surprised they didn't just start giving them for free.
  27. Apr 30, 2017 at 5:21 PM
    Lumpycorn
    Lumpycorn New Member
    Did Clint and Saturn draft figure out the issue? My Michellins have this front tire outside wear and i think its cornering stress. Im tryingnto find tires that will be able to defend this. Any suggestions?
  28. Apr 30, 2017 at 5:44 PM
    Nor7
    I think you should invest that saved $74 into a new pair of sneakers.
  29. Apr 17, 2019 at 6:58 PM
    Elyons58
    Elyons58 New Member
    Frisco, Colorado
    2012 Toyota Tundra
    None
    Did you ever figure out why the tire was wearing more quickly than the others? Mine does the same thing even though it is in alignment (even after adjusting parameters) and with consistent rotations. Thank you in advance.
  30. Oct 13, 2022 at 2:54 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I wonder if he ever got new sneakers
    Tundra14Platinum likes this.
