Should I?
Discussion in '2nd Gen Tundras (2007-2013)' started by Weezy, Feb 11, 2023.
  1. Feb 11, 2023 at 2:40 PM
    Weezy
    Weezy [OP] New Member
    2013 SR5 Crewmax
    Just bought a 2013. I don't know if trans fluid had ever been changed. Do I dare change it? It shifts good, but heard it could make slipping problems if it's been to long.
  2. Feb 11, 2023 at 2:54 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Doesn't hurt, if you wanna keep it a while
    Weezy[OP] and Black Wolf like this.
  3. Feb 11, 2023 at 2:57 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Drain and fill, see how it reacts and go from there.
  4. Feb 11, 2023 at 3:09 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    I've had my 13 for a couple years. It shifts fine. I'm on the fence about changing the trans fluid. I REALLY want to change it, but I also REALLY need the transmission to keep working.
    Mr Badwrench likes this.
  5. Feb 11, 2023 at 3:13 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Change it ASAP.
    FWIW those are old wives tales from when fluid wasn't what it is today. The stuff would varnish over years of service, leave deposits on sealing surfaces which there are hundreds in a modern auto trans. Then when fresh fluid was added, the high detergent nature of the fluid could dissolve the buildup on those same sealing surface creating an internal pressure leak. With drop in pressure to clutch drums / brake bands, the trans begins to slip and fry the clutch material. That same oil would be yellow and smell like turpentine if drained before the trans had burned up. The tale is real, but those days are long gone and there should be no fear of fluid changes.
    Weezy[OP] likes this.
  6. Feb 11, 2023 at 3:18 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    How many miles? I have a 2013 and I had mine changed at 70.000 but I also tow as well.
    It is ALWAYS better to have clean fluid rather than dirty fluid.
    Notarobot likes this.
  7. Feb 11, 2023 at 3:24 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    +1.
  8. Feb 11, 2023 at 3:59 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Again. Drain and fill. Note that this is not a complete flush-and-fill. Don't do that. Drain and fill which is about 4 quarts of fluid. You can do it again in 30,000 miles. And then again in 30,000 miles. Drain and fill.
  9. Feb 11, 2023 at 4:49 PM
    Notarobot
    2013 CM
    I'm at 102k (dd). What fluid is recommended since it will be an unknown mixture?
  10. Feb 12, 2023 at 1:22 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Toyota WS if you want to go by the book.
    I use Maxlife ATF on all my Toyota's and have been fine.
    Notarobot[QUOTED] likes this.
  11. Feb 12, 2023 at 2:23 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Mine had it's first change at 174k, the chap that did it (who only does transmissions) recommended I go back in 30k. A reason he gave as being that it might be overkill but it'd be a sight cheaper and easier than a rebuild on this model...Long story short, time ran away from, got to 245K, it chucked a code nearly two weeks ago, I thought a fluid change might solve it but no she's worn out and I've just had to give him the OK to rebuild her. He was surprised that I had put nearly 1/4 million miles on this model transmission, A760E, without any previous grief. Ordinarily I wouldn't have a remanufacture on a box with that many miles but it comes out about the same money as one from a junkyard with high miles and little guarantee of lasting. I could be looking at as much as a $3K bill...
    TLDR: Change oil and filter now and then do it every 30k as a previous poster mentioned.
  12. Feb 13, 2023 at 9:33 AM
    Weezy
    2013 SR5 Crewmax
    Ok am just was wanted to know if anyone has had any problems. Have heard the tales. Thank you
  13. Feb 13, 2023 at 12:15 PM
    KeepOnTruckin
    Randy
    I've been using Amsoil in another A760... 3 years, 30k miles, no issues.
    There is a lot misinformation carried over from fluids used in the 1960, 70, 80's and by the 90's things were improving significantly.
    The EPA stepped on the manufactures to make their vehicles make less waste and walla WS fluid comes to market for the Asian Warner fleet of transmissions. The new lifetime fluid also removed the dipstick so the fluid didn't get dumped at the first sign of color change when it can in many situations live for 100 to 150k.... Because our strainer is just that, I have to edge my bet towards 30k fluid changes starting no later than 100k, and keep with it.
    JM2C
  14. Feb 13, 2023 at 1:17 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I did a drain and fill at 220K. The only thing I noticed was that for the first few days the shifts were really distinct, you could really feel it shift up and down. After about 2-3 days it was back to shifting like it was supposed to and no issues since then. Runs like a top now.
  15. Feb 13, 2023 at 1:23 PM
    Mr Badwrench
    Mr Badwrench New Member
    How many miles are on it? If it is high mileage (200k) I'd probably leave it.
  16. Feb 13, 2023 at 8:51 PM
    KeepOnTruckin
    Randy
    Why?
    Mr Badwrench[QUOTED] likes this.
  17. Feb 14, 2023 at 10:10 AM
    Mr Badwrench
    I've had bad luck doing it. I've ruined a Ford C6 transmission and a TH350 in my blazer. Both were 150k+. I just cringe at putting detergent hydraulic oil in a high mileage auto transmission now.
  18. Feb 14, 2023 at 10:27 AM
    KeepOnTruckin
    Randy
    My post above addresses this very topic!
    The oils from the past suck! And ya that did happen back in the day. Those transmissions (material design and composition internal sealing material) are from the 1970's... It's a new era and oil is 100x better.
    The risk today is near zero. That wasn't true in 1985!
  19. Feb 14, 2023 at 10:54 AM
    Mr Badwrench
    If the old oil was relatively clean, I'd probably be more likely to try it. Like dislodged plaque in an artery, I'd be afraid to dislodge any (if any) build-up.
