Should I tow this
Discussion in 'Towing & Hauling' started by Garvin74, May 16, 2018.
  1. May 16, 2018 at 7:37 AM
    Garvin74
    Garvin74 [OP] New Member
    2017 Tundra CM SR5
    Hey all,
    Im going to sod my yard and I am in need of 1240 sqft of sod. I Have a trailer available to me that can carry about 6000lbs. The trailer is about 3500lbs. Ill be saving about 300 bucks for delivery if I pick it up myself. I have a 17 crewmax 4x4 5.7l. I know the numbers say I can tow this. My plan would be to put about 5000lbs of sod on the trailer, 3 pallets and the other half pallet in the bed of the truck about 800 to 1000 lbs. My truck is stock with the tow package. I don't have a w/d hitch nor do I want to buy one since I don't tow this heavy on the reg. I feel like this is a bad idea because I'd be pushing the truck to its max capabilities. What do ya'll think. Easy day for the Tundra or save some grief and spend the 300 bones. I also have no idea what the tongue weight would be with this load and the max for my truck is 980lbs. Also the weights stated above are the max weight for the sod could be lighter depending on how wet it is. Thanks guys.
    Jsena likes this.
  2. May 16, 2018 at 7:45 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Make 2 trips..
    Watt maker, TheBeast, jeremyd and 3 others like this.
  3. May 16, 2018 at 7:45 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I mean, the Manual states that you must have a WD hitch if towing anything over 5k. If it were me though, it would depend on how far, you have to tow it and in what environment. If you are a flatlander, who is towing it less than 20 miles at speeds below 50MPH (you might even be able to go on the highway... I would, but I am less risk averse than most), I would go for it. However, I would not exceed the payload rating by adding the extra sod in the bed. I would just add the extra sod onto the trailer. As I imagine that the tongue weight of a 3500lb trailer + 5800lbs of sod will at least be 1k. That leaves maybe, 400-600lbs for additional sod in the bed.
  4. May 16, 2018 at 7:49 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :popcorn:
    lionix likes this.
  5. May 16, 2018 at 7:49 AM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    This ^^
  6. May 16, 2018 at 8:23 AM
    Make several trips, like @Jsena suggested.
    The sticker inside your drivers door will let you know everything you need for load ratings for that truck.
    Your tongue weight with that weight will be in the 1000-1140 lbs depending how well it is loaded. It all adds up quickly. I just read a thread on an XD forum on how a guy overloaded his Titan and bent the frame.
    Any guesses what this little bit of this rock load weighed?
    You can see I was using a LDH.
    Watt maker, Black Wolf and Jsena like this.
  7. May 16, 2018 at 8:46 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    8k ¯\_(ツ)_/¯
  8. May 16, 2018 at 8:51 AM
    With rear axle, 17200 lbs.
    Doesn’t look like much, but I was like daaaaaaammmn!
    Watt maker, Jsena, Black Wolf and 2 others like this.
  9. May 16, 2018 at 8:56 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I would have never guessed that much weight! Daymn!!!!!!!
    Anyway, do what @Jsena said and make two trips or have them deliver it. It really depends on how far you have to go.
    Jsena and ColoradoTJ[QUOTED] like this.
  10. May 16, 2018 at 9:05 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :yes:
    Making 2 trips to save $300.. pretty good deal to me..
    kenomouth64 and ColoradoTJ like this.
  11. May 16, 2018 at 9:09 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Leaves more for mods!
    ColoradoTJ and Jsena[QUOTED] like this.
  12. May 16, 2018 at 9:09 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    TheBeast and ColoradoTJ like this.
  13. May 16, 2018 at 9:10 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Have it delivered
    They will have a forklift and can spread the pallets out for you. It’s well worth it
    I sodded my place in 98. 5000 sq ft. Had them deliver and place the pallets through out the site.
    Jsena, Newm and ColoradoTJ like this.
  14. May 16, 2018 at 9:19 AM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I have overloaded my work trucks many times, but only on short drives. I know it is not the best idea, but sometimes you have to say screw it. I'm going 5 miles! But, I am fairly risky in my life. You make the decision and live with it.
    Jsena and ColoradoTJ like this.
  15. May 16, 2018 at 10:07 AM
    Garvin74
    2017 Tundra CM SR5
    Well based on what everyone has said i think I'll have it delivered. It's a 63 mile trip. I live in va beach. Just no sod farms near by. Definitely dont want to make two trips. Good thing is I told my wife what it would cost delivered didn't even mention picking it up. Thought I'd try and be the hero and save a few bucks. But that ain't worth screwing something up.
  16. May 16, 2018 at 10:13 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  17. May 16, 2018 at 10:17 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What does your truck pull Chris? The Max load
  18. May 16, 2018 at 10:54 AM
    13000 conventional
    17200 5th/gooseneck
    23200 gross combined.
    NewImprovedRon and Jsena[QUOTED] like this.
  19. May 16, 2018 at 10:56 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What’s all that mean?? I dont know what those are.. never done any type of towing
  20. May 16, 2018 at 11:02 AM
    What this means:
    13k is the max weight for receiver hitch towing, like a flatbed car hauler.
    17200 is the max 5th wheel/gooseneck trailer weight.
    23200 is the max both truck and trailer can weigh together.
    Clear as mud? Lol
  21. May 16, 2018 at 11:04 AM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    If it was 5 miles I'd say yeah you could do it it 2 trips. But at 63 miles one way, two trips.... you just spent the $300 on gas.
    ColoradoTJ likes this.
  22. May 16, 2018 at 11:06 AM
    Baja Mike
    South Bay, Ca.
    Did you at least tie it down so it doesn't go anywhere?
    :D
    Watt maker, JC303, drhntr and 6 others like this.
  23. May 16, 2018 at 11:08 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    So the 17k you were showing in above pic is
  24. May 16, 2018 at 11:26 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Conventional. He was overloaded.
  25. May 16, 2018 at 11:29 AM
    Conventional towing.
    That was trailer weight and rear axle of truck.
    Trailer 2900 lbs empty
    Truck rear axle empty 3100 lbs
    Truck axle after load 4500 lbs (so hitch weight was 1400 lbs, almost maxed out).
    So my load was 9800 lbs of material.
    Trailer weight rating is 14000.
    Now I was really close to being over the rated capacity of my class V hitch with Load Distribution by 100 lbs. if the trailer would have been loaded differently and not so nose heavy (I had two different landscaping materials on the trailer), I could have gone about 1000 lbs more.
    Watt maker and Jsena[QUOTED] like this.
  26. May 16, 2018 at 11:30 AM
    Nope
    Jsena likes this.
  27. May 16, 2018 at 11:32 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Well,
    Good thing I don’t tow shit.. i don’t want to worry about all that weight mess... since I still can’t figire it out :rofl::rofl:o_Oo_O thanx guys
  28. May 16, 2018 at 11:34 AM
    Atomic City Tundra
    Devin
    New Mexico
    Sorry, I didn't see the "with rear axle" part. I just saw 17,200 lbs and assumed that was the material weight.
    ColoradoTJ[QUOTED] and Jsena like this.
  29. May 16, 2018 at 11:38 AM
    Like I said, clear as mud. Lol
    Jsena[QUOTED] likes this.
  30. May 16, 2018 at 11:41 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Bwhahahahaha..
