Should I jump on this?
Discussion in '2nd Gen Tundras (2007-2013)' started by BuckWallace, Jan 18, 2019.
  1. Jan 18, 2019 at 8:19 AM
    BuckWallace
    BuckWallace [OP] Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    As some of you may know, I semi-reluctantly got rid of my 2018 Tundra after a cam tower repair gone bad and got my wife into a new Highlander. I was originally planning on looking for a 1st gen Tundra to replace my 2018, but I came across a low-mileage early 2nd gen with the 4.7L (I don't want to deal with cam towers again, and we'll only be towing a light pop-up tent trailer or light trailer) that I may go check out tonight. Is there anything I should look out for on these? I know rust was an issue, but we don't use salt here in Oregon so that usually isn't a big issue here. Any info would be much appreciated!
  2. Jan 18, 2019 at 8:06 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    So I checked out a 2007 double cab with the 4.7 this evening. It's a one owner with only 66k miles on it and looked really clean. The owner, an 84-year-old man, had a file folder with a record of every single thing he's ever had done to it. It has been in a couple "fender benders", but it has a clean title and he said there was never any frame damage and I couldn't see anything to indicate otherwise. He's asking $17.5k, and high book on these is $17.7k. However, he hasn't had the timing belt done yet. Like I said, it only has 66k miles on it, but the maintenance schedule calls for a timing belt replacement at 90k miles or 9 years, and this is 12 years old so that's an added expense I'd have to cover for peace of mind.
    Any advice? Should I jump on this? I was originally planning on getting a 1st gen with a little more miles, but this seems like a potentially good deal.
    Sunnier likes this.
  3. Jan 18, 2019 at 8:12 PM
    15whtrd
    15whtrd Mr. Blonde
    Go drive it. Sounds nice to me. Offer 15?
  4. Jan 18, 2019 at 8:14 PM
    FXFormat
    FXFormat New Member
    Damn, don't know how you can go from a 5.7 back to a 4.7 ...i have no input here, but i have 180K on my 5.7 and it's bone dry, transmission leak = bad, oil leak = just about 99% of German cars and they still run.
    Maybe try to find an older 5.7, or at least a 4.6, my 4.7 in my Land Cruiser is soooo slow, she's a beast off road though, more than the Tundra will ever be.
    Black Wolf and OR18TRD like this.
  5. Jan 18, 2019 at 8:19 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I definitely noticed the difference in power, but the throttle actually seemed more responsive on this compared to my 2018.
    I did drive it and it was really nice. He said he's pretty firm on the $17.5, and I really don't think that's unreasonable being a low mileage one-owner truck with detailed records. It's just the timing belt job cost that concerns me.
    Black Wolf and 15whtrd[QUOTED] like this.
  6. Jan 18, 2019 at 8:20 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    4.7s don't have the cam towers, only the 3UR-FE (5.7 and 4.6).
    Black Wolf and OR18TRD[QUOTED] like this.
  7. Jan 18, 2019 at 8:22 PM
    I would not want a lower powered engine in a heavy truck. It has to work harder for everything else
    Black Wolf and FXFormat like this.
  8. Jan 18, 2019 at 8:23 PM
    FXFormat
    FXFormat New Member
    4.7 known issues are cracked exhaust manifolds, awful awful job to replace them, and of course you have to do the timing belt/wp. Other than that, the motor is good for at least 500K miles with proper maintenance.
  9. Jan 18, 2019 at 8:27 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I had a 2005 Titan, so I know ALL ABOUT cracked manifolds :frusty:. But thanks, that's good to know—I did not know that about the 4.7s. I didn't hear any exhaust leaks from this truck, however.
    Black Wolf likes this.
  10. Jan 18, 2019 at 8:35 PM
    FXFormat
    FXFormat New Member
    lol hop on over to ih8mud and you'll see how many complains of ticking exhaust manifolds, labor to replace them is like 13 hours in the books, but realistically it's about a 2 day job. I have leaking manifolds and have absolutely no intention of replacing it. One more thing on the timing belt, you don't have to do it, i've got friends and families with 4.7 motor that are too cheap to do the TB/WP job and they've got well over 200K miles on their vehicles. They don't break, the only time i hear of them breaking is after they were replaced, i've opened up a customer's timing belt at 350K and it looked good still. He bought his sequoia new and never changed the TB, he came in because the water pump was leaking and making awful noises.
    My land cruiser has 208K miles on the original belt and wp, my LX470 is at 140K miles on original belt and pump as well. As a mechanic, i can assure you these belts are not gonna break unless a pulley or something seized inside and destroy the belt or rodents got inside and chew it up.
  11. Jan 18, 2019 at 8:43 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    On a side note, I was pretty impressed with the space in the back of the double cab. Sure, it's nowhere near what my Crewmax was, but I put my daughter's rear-facing seat in the middle and it fit just fine.
    Black Wolf and 15whtrd like this.
  12. Jan 18, 2019 at 8:46 PM
    TheBeast The Beach
    I dunno man, I say keep looking for a clean gen 1. V8 power and great for those tight trails.
  13. Jan 18, 2019 at 9:06 PM
    15whtrd
    15whtrd Mr. Blonde
    True but it is a much bigger engine bay so it may be easier to work on.
  14. Jan 18, 2019 at 9:09 PM
    15whtrd
    15whtrd Mr. Blonde
    :anonymous: My Sequoia has 160k on the original belt. I have the parts. Just busy and lazy
    Black Wolf and BuckWallace[OP] like this.
  15. Jan 19, 2019 at 4:34 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Offer him his $17,500 if he gets the timing belt replaced.
  16. Jan 19, 2019 at 4:41 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    ^^^ is exactly what I would do. I think that job is about 800-900 if you pay to have it done. I would tell him that it's due and ask for help by either dropping the price by that much or having it done prior to you buying it. If he doesn't have the money to do it, then maybe offer a deposit that would cover the cost of the job to get it done. It sounds like a well maintained, documented truck with a fair price. I would certainly be happy with it.
  17. Jan 19, 2019 at 4:45 AM
    Borgs
    Borgs New Member
    PA
    A couple fender benders, and he is expecting high KBB? No way. I’d offer low KBB. He’d still make out much better than if he tried to trade it.
  18. Jan 19, 2019 at 5:22 AM
    This^^^^
    rebmo likes this.
  19. Jan 19, 2019 at 6:11 AM
    Doesn't appear to be a bad deal but even though the timing belt could last for years, we don't know that for sure, I would still try to get owner to come down a bit when you tell him the timing belt will need to be replaced.
  20. Jan 19, 2019 at 9:42 AM
    Dr_Al
    Dr_Al New Member
    Al
    The exhaust manifold issue is overblown. Most of the 4.7L engines are in 1st gen Tundras. What people are hearing is the rubber seal in the steering shaft between the cab and engine bay. Being rubber it breaks down and eventually it rots away. It's right next to the left exhaust manifold. I don't know if the second gens have the same seal or not but I know about a half dozen people who replaced perfectly good manifolds (usually with cheap aftermarket shorty headers) thinking they were going to fix the problem. As someone else has said it's not a fun job to replace them. On the 1st gen you actually have to unbolt the engine mounts and lift the engine up to remove them.
    I wouldn't pay that much just because it has low mileage. However I don't know the area so prices may be higher. Around here there's lots of Tundras so you have a lot to choose from. Real rusty 2nd gens can sell for as low as $8k. About twice that for one in excellent shape. That's a truck that has never had any body work done to it and less than 100k miles. Being 10 years old you are correct. The timing belt, the two pulleys, and water pump (because you are right there) need to be done and I would only use OEM parts.
    You don't need to buy them from Toyota as Aisin sells them to places like Rock Auto. If you're handy you can do it yourself. There's a couple tricky things to deal with. The bolt on the crankshaft is usually torqued down and difficult to break free. Also there's a bracket that the (I think) the AC pump mounts to that has a couple bolts that can be a little difficult to remove. But there's plenty of people who have documented it on-line to show you how to do it.
  21. Jan 19, 2019 at 9:51 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    This. Trading in will be much less.
    The owner cannot expect retail. Is he going to finance you? 90% of his prospective buyers will need financing. Retailers can offer full financing. Buyers getting their own financing will not get near asking price from bank or credit union., especially that year vehicle.
    I hope you didn't tell him you have the cash. Maybe you can mention only what bank may lend you and some cash.
  22. Jan 19, 2019 at 10:28 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Agreed. Only use Aisin TB kits. Also use Toyota tstat. I just did the timing belt in my 06 for the 3rd time and the job is cake. AC bolts arent even difficult unless you dont want to lay on the ground. Everything is easily reached. PS and Alt unbolt and lay against the fender well.
    15whtrd likes this.
  23. Jan 19, 2019 at 1:08 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I called the guy today and expressed my concerns about paying high book with the accident history and the fact that it needs a timing belt job. He was a super nice old guy but didn't want to budge on the price. I told him to call me if it doesn't sell (it's already been for sale for 1.5 months) and he decides to come down on the price. Anyway, the search continues....
    15whtrd, Trooper2 and HappyGilmore like this.
  24. Jan 19, 2019 at 1:17 PM
    Trooper2
    JR
    I would be very surprised if he gets within 2k of that price. It will be for sale a long time.
  25. Jan 19, 2019 at 3:40 PM
    Whocares
    Whocares Member
    Regarding the steering shaft rubber boot replacement, there is no need for lifting the engine. Its actually a pretty simple repair.
    https://youtu.be/9zf3NMW5L3w
    But yes, replacing that little rubber boot completely mutes any engine ticking noises that might creep into the cabin.
    https://www.ebay.com/ulk/itm/122657624217
    OR18TRD likes this.
  26. Jan 20, 2019 at 8:52 AM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
  27. Jan 20, 2019 at 9:00 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I want to know rather conclusively about the transmission fluid service as well as the differential fluid.
  28. Jan 20, 2019 at 9:02 AM
    Trooper2
    JR
    Looks really clean. 5.7 is solid. Most of the cam tower leaks are not that bad. Bench seat and column shifter, some like the extra seating many like the console. The shell is great adder if you want or needing one.
  29. Jan 20, 2019 at 1:03 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    So I'm looking at it now and both cam towers are very slightly seeping... I definitely wouldn't open it up to fix it, but it's a little concerning after my experience with my 2018. Should I bail on this?
  30. Jan 20, 2019 at 1:09 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    I believe, but could be wrong, the first Million Mile 2nd gen Tundra was a 4.7, yes?
