Should I get heavier spring rate on my 6112s?
Discussion in 'Suspension' started by Jwood562, Feb 21, 2021.
  1. Feb 21, 2021 at 6:16 PM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Hi guys,
    I currently have 6112s on the top setting. Spc ucas, 5160s in the rear with 1.5” toytec shackles. That’s the extent of my suspension work.
    I added 18” methods and 35” ridgegrapplers.
    I have add a roof rack, numerous other accessories. I’m getting ready to add about 100lb front steel bumper.
    With the added weight of the above mentioned parts should I get a heavier spring for my 6112s? I found the eibach 800lb replacements
  2. Feb 21, 2021 at 6:19 PM
    Elduder
    Elduder New Member
    800 will be too much. 700 is the typical app for bumpers, I believe even the heavy duty stuff from OME and Ironman are still like 740ish, which is a lot.
    Jwood562[OP] likes this.
  3. Feb 21, 2021 at 6:21 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    What spring rate does the 6112 come with?
  4. Feb 21, 2021 at 6:22 PM
    Jwood562
    2013 Tundra 4x4
    Ok good to know, so I should be looking for 700lb?
    what rate came on the 6112s from bilestein?
    please forgive my ignorance but how do I find them from different manufacturers? I only found the eibach part number by someone’s for sale thread
  5. Feb 21, 2021 at 6:27 PM
    Elduder
    Elduder New Member
    I cant say for sure as I've heard it is both 600lb and 650 lb. Vendors even have them listed at different ratings as well.
  6. Feb 21, 2021 at 6:28 PM
    Elduder
    Elduder New Member
    Yes, 700 would be good. You could also run it on the stock springs and see how you feel first.
  7. Feb 21, 2021 at 6:33 PM
    Jwood562
    2013 Tundra 4x4
    that’s what I will probably do first.
    I will take measurements also before and after adding the bumper and give it some test drives
  8. Feb 21, 2021 at 6:35 PM
    Elduder
    Elduder New Member
    There may be labeling on your springs that will tell you the rate.
    Jwood562[QUOTED][OP] likes this.
  9. Feb 21, 2021 at 7:13 PM
    I called Bilstein directly with my 6112’s and they said the only spring rate they offer is 650 lbs.
    This info is about 4 years old, so something could have changed.
    Jwood562[OP], Elduder and TundraLaw like this.
