Should I easily be able to spin the tires in the rain?
Discussion in '2.5 Gen Tundras (2014-2021)' started by daylorb, Mar 13, 2019.
  1. Mar 13, 2019 at 7:20 AM
    daylorb
    daylorb [OP] New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    This is the first pickup I've ever owned, CrewMax 2016. I find that in any amount of rain I can easily spin the tires from a start, certainly can do a nice fishtail as well.
    Tires look like they have plenty of tread left on them, so my thought is that they I should just expect this from a truck with a light back-end, or the tires really are more worn-out then I can determine.
    I have no problem getting new tires if that will help, been sniffing around the Conti Terrain Contacts which seem to have really good wet performance.
    But maybe I'm just a lead foot and this is to be expected with any tire?
  2. Mar 13, 2019 at 7:22 AM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    There’s a learning curve when driving a truck in the rain for the first time, as the vehicle has considerably less weight in the rear.
    Rex Kramer, JohnLakeman and 15whtrd like this.
  3. Mar 13, 2019 at 7:23 AM
    AlmightyCrash
    Crash
    San Leon, TX
    I’ve seen many people toss a few bags of sack-crete in the back to help with this. Others have used railroad ties.
  4. Mar 13, 2019 at 7:24 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Do you have VSC turned on? If so, if would be hard to spin the wheels with it engaged.
  5. Mar 13, 2019 at 7:31 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    A pickup will always suck a bit in the rain but you can mitigate that with quality set of tires and have very good wet traction.
    I dont mean a set of mall crawler "bro" tires that "look bad ass" commonly seen around here. I mean a set of good road tires like the continental or michelin defender ect
  6. Mar 13, 2019 at 7:37 AM
    daylorb
    Austin, TX
    2016 Limited 4X4
    Go Pack!
  7. Mar 13, 2019 at 7:38 AM
    daylorb
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    I will check. I'm definitely spinning them - the dash traction light flashing, car fish-tailing. Don't get me wrong, growing up in Wisco this is pretty common in snow and entertaining, but not in traffic with kids in the car...
    TXMiamiFan[QUOTED] likes this.
  8. Mar 13, 2019 at 7:42 AM
    15whtrd
    15whtrd Mr. Blonde
    I find playing with the air pressure helps too. I keep the front somewhere around 36-38 psi and the rear between 28-32 PSI. At least for my stock tires this has been a good formula for me. But the back end is easily broken loose on a truck in general.
  9. Mar 13, 2019 at 7:46 AM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Haven't done that yet with mine. I don't doubt I could, but I never hammer the gas on mine.
    My opinion would be to adjust your driving style.
  10. Mar 13, 2019 at 7:51 AM
    15whtrd
    15whtrd Mr. Blonde
  11. Mar 13, 2019 at 7:51 AM
    FUBAR
    FUBAR New Member
    2019 Tundra TRD crewmax
    I had the Continental tires on my Tacoma and they were great in the rain. I only put about 3500 miles on them before I traded for the Tundra. Those will be the next tire I put on the Tundra unless the price goes up. You may want to check with Discount Tire Direct to see if their prices are cheaper. They will beat Tire Racks prices too.
    daylorb[OP] likes this.
  12. Mar 13, 2019 at 7:53 AM
    daven
    daven New Member
    2019 Tundra Double Cab Limited
    I just picked up my Tundra yesterday, and the roads were wet as well. I noticed the exact same thing, easy to loose traction in the back end.. What is VSC, not aware of this feature..?
  13. Mar 13, 2019 at 7:54 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    With Tow/Haul mode on and traction control off, I can spin tires through the intersection, down the street and up the neighbours lawn in the rain.
    panicman, mtntop, TWJLee and 4 others like this.
  14. Mar 13, 2019 at 7:56 AM
    TXMiamiFan
    Jose
    Traction Control. Sorry.
    VSC = vehicle stability control
    Inquiringone likes this.
  15. Mar 13, 2019 at 8:11 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Same here...but you can feel the VSC pulsing the brakes to get wheel speed back under control...Always makes me grin...;-)>
    B
  16. Mar 13, 2019 at 8:22 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    When was the last time you rotated your tires? They may appear to have a lot of tread left but if they are wearing uneven, there is less surface contact with the road and you’ll notice them spinning much easier.
  17. Mar 13, 2019 at 8:28 AM
    Mnorris1206
    08 tundra
    Haha my 35x12.5x18 ko2 bro tires do very well in train and snow :rofl:
  18. Mar 13, 2019 at 8:52 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Normal. If you jump the throttle a bit coming off the line it's easy to do. Even my '06 300hp F-150 4-speed could easily spin the tires in the rain. There is simply no weight over the rear wheels.
  19. Mar 13, 2019 at 9:18 AM
    daylorb
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    About 3k miles ago, but they are due. Thanks.
    KnuckleHD[QUOTED] likes this.
  20. Mar 13, 2019 at 9:23 AM
    KnuckleHD
    I usually run BFG KO2s which I love but they are notorious for uneven wear if not rotated routinely. I was experiencing the same thing last “winter” when it would rain. Rotated the tires and problem solved.
  21. Mar 13, 2019 at 9:31 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Yes, worse when it's snow or ice.
    Too bad tundras don't offer AWD mode. My previous truck (2016 Chevy Silverado) had AwD mode, it was awesome in rain . Didn't slip going up hill. Even on cheap sicks Bridgestone tires
  22. Mar 13, 2019 at 9:35 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Certain tires do it no matter what... if you live in a continuously wet climate, I'd get myself some "better in rain" rubber
    JohnLakeman likes this.
  23. Mar 13, 2019 at 12:22 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Exactly.
    Select your tires to fit where you drive and your driving style. For example, aggressive tread AT tires are unlikely to have the best traction on wet, hard surfaces; the rubber compound in them will be harder to resist wear on rugged terrain. Tires are rated according to several parameters including the softness of the rubber compound which translates into wear tolerance or surface adhesion. If you use your truck primarily on the street, look for tires that provide good scores for street use.
  24. Mar 13, 2019 at 12:29 PM
    B737
    Jersey Shore
    but... but... they wont look as "cool"!!! maybe a sweet "cold air intake" or "exhaust" will do....
    JohnLakeman[QUOTED] likes this.
  25. Mar 13, 2019 at 12:29 PM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    okqBVGk+TRmuerisM8DElg.jpg I have those tires on my truck. Best E rated tire I have ever owned. They have been unstoppable in the snow here in Vermont.
  26. Mar 13, 2019 at 12:46 PM
    Britrider750
    Britrider750 Old dude with cool truck.
    Ron
    Clayton, North Carolina
    2017 TRD Off Road
    All weather Tundra floor mats, spray bed liner Extang Trifecta 2.0 tonneau
    That’s a goot one.
    (Said in my Arnold Schwarzenegger accent)
  27. Mar 13, 2019 at 12:48 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Haha yes, welcome to something called torque.
  28. Mar 13, 2019 at 1:57 PM
    daylorb
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    Just went outside after the rain stopped. Current tires are Bridgestone Duehler H/L.
    It sure seems that after reading reviews on the Conti A/T it looks like a pretty darn good road tire as well. Tread pattern is not that aggressive, gets good noise rating/etc.
  29. Mar 14, 2019 at 3:33 AM
    Redhorse
    Redhorse New Member
    Maryland
    2019 White Limited Off-Road DC
    Truxsport tonneau
    Coming from a Tacoma the Tundra is so much better in the rain. A combination of more weight and much nicer OEM tires. The Michelin LTX A/T2’s perform well in the rain and in the little bit of snow we had.
  30. Mar 14, 2019 at 6:48 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    We have been getting a ton of rain in Phoenix lately.
    After reading threads similar to this one, I have started to turn on the VSC when driving on wet pavement; particularly since my KO'2 have almost 60K miles and are getting close to needing replacement.
    Even with the VSC on I can still wash-out my rear-end, but it takes decidedly more effort.
