Should I adjust my lift or not???
Discussion in 'Suspension' started by dhoward69, May 16, 2019.
  1. May 16, 2019 at 8:34 AM
    dhoward69
    dhoward69 [OP] New Member
    Oregon
    2017 MGM Crewmax SR5 TRD 5.7L
    Last summer I installed the Toytec Boss lift on my 2017 Crewmax. The coilovers were installed at the preset 3” position and the shackles at the 1”. Recently I noticed the lift appeared to have settled somewhat. So I found some flat ground and took some measurements from hub center to fender:
    DF: 25.75" PF: 26.25"
    DR: 25.25" PR: 25.25"
    I'm thinking of putting the shackles at the 1.5” position to help level out the stance somewhat. By doing so, what effect would it possibly have on the other measurements? Also, will the ride quality be changed much?
  2. May 16, 2019 at 8:40 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Ride quality will remain the same and wont affect the front but for a miniscule amount of weight transfer.
  3. May 16, 2019 at 11:01 AM
    15whtrd
    15whtrd Mr. Blonde
    I bet it would ride a little nicer without the coils being preloaded as much. I suggest stabbing a shim on the driver side to level the front from left to right.
    AZTundra likes this.
  4. May 16, 2019 at 11:09 AM
    G10dra
    G10dra Not a New Member
    Read thru this forum's it seem like Toyotec lift has some problems
  5. May 16, 2019 at 6:43 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    The BOSS kit is adjustable. 1/4 turn either on the passenger front down or driver front up should get you level. Also, put the shackles on the 1.5 setting. Raising the shackles should not affect ride quality.
    15whtrd likes this.
  6. May 16, 2019 at 6:51 PM
    15whtrd
    15whtrd Mr. Blonde
    Ahh shit. Missed the part about it being shackles. I pictured the front CO’s.
  7. May 16, 2019 at 7:02 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    If you lowered the front passenger side coilover 1/4 turn and put the shackles at 1.5 you would be at 25.75 all around. The driver side is always going to settle more. Weight from the driver and gas tank.
    mtndds98 likes this.
  8. May 17, 2019 at 9:12 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I have a bit of the tundra lean, seems to vary depending on where I park and if it's before or after I drive around. Doesn't bother me too much. I like to think of it as my mighty steed kneeling down to make it easier to climb in ;)
    monaco730 likes this.
